Is a regular LAN cable or 5 GHz Wi‑Fi N faster for transferring data from a router to a TV?
A LAN cable is usually the faster and more stable choice; Wi‑Fi speed depends on many factors, so the real throughput cannot be predicted and theoretical rates are often not reached [#16907941][#16908415] If the TV only has 10/100 Ethernet, it will max out at 100 Mbps anyway, so a normal Cat5e/Cat6 patch cable is sufficient [#16915447][#16915694] Since the router is very close to the TV, several replies recommend simply using the cable instead of Wi‑Fi [#16914728][#16916415] For Netflix 4K, about 25 Mbps is enough, so there is no need to chase gigabit speeds for the TV link [#16915694]
  • #1 16907929
    xrsxrs
    Rate: 24
    Such a simple question is more to make sure: what will I have a higher transfer speed from the router to the TV, whether via a regular LAN cable or via wifi in the N 5GHz standard? The TV supports N, and the router N, and also AC. Stability, of course, I know that it will be better on the cable, but I'm not fully informed about the differences in speeds and Google confused me a bit.
    dt1
    Admin of Computers group
    Help: 7290
    Rate: 8239
    The speed achieved by WiFi depends on many factors. LAN will usually be a better choice, especially if your TV and router support Gigabit Ethernet (1000Mbps ports).
    There are different radios having different capabilities in the AC standard, so it is not known what even the maximum possible theoretical speed of the resulting connection is. Even if it were known, it is impossible to estimate what the losses will be due to the distance between devices and radio interference. There is no answer to the question of the speed you will get between the TV and the router.
    jimasek
    Help: 3783
    Rate: 2677
    Take into account that what is written on the card or the manual must be divided by two - the transmission speed, which is often not achieved anyway when there are disturbances or the signal level is not satisfactory (two-way communication).
  • #4 16910455
    KOCUREK1970
    Help: 3835
    Rate: 5431
    xrsxrs wrote:
    What will I have a higher transmission speed from the router to the TV, whether via a regular LAN cable or via wifi in the N 5GHz standard? The TV supports N, and the router N, and also AC
    And what is more certain: 300 Mb via wifi or 100 Mb via cable?
  • #5 16910459
    lopr_pol
    Level 32  
    Help: 163
    Rate: 487
    300Mb via wifi will not be achieved, on good equipment 100-150Mb. Better cable, it is "only" 100Mb, but sure.
  • #6 16911037
    dt1
    Help: 7290
    Rate: 8239
    Stowing with a cable will always be much more sure. Anyway, your TV would probably rarely, if ever, need higher speeds anyway.
  • #7 16912543
    dt1
    Help: 7290
    Rate: 8239
    100Mbps is not the capacity of the entire network. This is the speed of the connection between the device and the switch. A switch is usually not limited to a total of 100Mbps, even if it's a hundred. In general, data on the capabilities of a given switch should be available from its specifications.
  • #8 16914118
    xrsxrs
    Rate: 24
    ok, maybe I will formulate the question differently :) : to watch Netlix in 4k, better if I connect the TV via a cable to the router or a can via wifi in 5GHz in the N standard because I can't in AC (the router is half a meter from the TV); Oh, and are there lan cables with greater bandwidth or would I have to have a different plug in the TV and router for such a faster cable?
  • #9 16914183
    cyryl85
    Help: 11
    Rate: 36
    The speed of the 5GHz and 2.4GHz network has virtually no difference, even 2.4 I think it is faster, the 5GHz network is simply more stable, but for image transmission in 99% of cases the cable is always better ... The cable is best lan cat6 . In the router, it is also worth checking if and how which port is 1Gbit and connecting through this port.
  • #10 16914619
    xrsxrs
    Rate: 24
    and you do not know if there is a 1Gbit port in this newest white UPC router
  • #11 16914728
    sebap
    Help: 538
    Rate: 1078
    What router is it?
    Since the TV is half a meter from the router, do not even think about it, just connect it with a cable. Cable connections will not be replaced by any WiFi routers, even if they are gold.
  • #12 16914745
    Heinzek
    Help: 554
    Rate: 494
    xrsxrs wrote:
    (the router is half a meter from the tv)
    And you want WiFi?
    sebap wrote:
    don't even hesitate, just connect with a cable
    Only right answer.
    So what if WiFi describes "more" how it will actually be divided into other devices, because probably some phone, laptop or other device will be used.
  • #13 16914750
    KOCUREK1970
    Help: 3835
    Rate: 5431
    Every UPC modemorouter currently has 1 Gb LAN ports.
  • #14 16915422
    xrsxrs
    Rate: 24
    and does my TV support 1Gbit if the specification says Ethernet: RJ45, IEEE802.3 10BASE-T / 100BASE-TX? Because if I can see it correctly, it would only support 10 and 100, so is there any point in buying cat6 anyway?
  • #15 16915447
    sebap
    Help: 538
    Rate: 1078
    No, only 100Mbps.
  • #16 16915463
    xrsxrs
    Rate: 24
    So it basically makes no sense for me to buy a cat.6 cable if the tv only supports 100Mb / s? (damn model Panasonic from 2017 with built-in Netflix and no 1Gbit wrrr).
  • #17 16915694
    dt1
    Help: 7290
    Rate: 8239
    But why do you need gigabit if Netflix to UHD (4k) requires 25Mbps?
    https://help.netflix.com/pl/node/306
    Connect it with the most ordinary 5e or 6 meter patch-cord and it should work - there is no need to look for problems by force.
  • #18 16915706
    sanfran
    Help: 955
    Rate: 2979
    NetFlix on the TV will go well both on WiFi and on cable.
    It's a fact that 4K TV content requires a lot of transfer, but is resistant to "slugging". I recently watched a movie on NetFlix and accidentally restarted my router. The TV (Samsung JU6510) continued to play the program for 25 seconds until the buffer was exhausted.
  • #19 16916140
    m.jastrzebski
    Help: 679
    Rate: 864
    It can and is resistant. Ake, if the router is half a meter from the TV, why limit the ratio of a small and limited WiFi bandwidth if you can let the cable go?
    You will watch 4K via WiFi, other devices working on WiFi will have worse access to the medium. In my opinion, only a cable.
  • #20 16916238
    xrsxrs
    Rate: 24
    I am not looking for problems by force, but for the optimal solution :-) ; By the way, I don't see much difference whether I connect via cable or via wifi. Take into account that the router is very close to the tv, so at 5 Ghz GHz nothing from the neighbors to go disturbs interferes because everyone has 2.4 and it is very close, so it reaches the max signal in wifi, and theoretically I can get a slightly higher speed on N than on the cable and additionally get rid of the cable. Mi Netflix, after all, whether it is on this or that, it will sometimes hang slightly and on this and that on TV shows me a maximum speed of 15Mb / s; in addition, to jump to 1080 or 4k it takes about 1 minute or more, and sometimes almost immediately. And the internet with UPC is 120th.
  • #21 16916393
    KOCUREK1970
    Help: 3835
    Rate: 5431
    On the operator's equipment for $ 20 - this is also worth recalling.
    I will also remind my colleague that this Compal (ConnectBox) has big problems at UPC (and not only at UPC Polska) - please enter the phrase "PUMA6 test" in Google and read a bit about it.
    And here is something from our backyard:
    https://forum.upc.eu/t5/connectbox/test-puma6-i-problemy/td-p/843
  • #22 16916405
    dt1
    Help: 7290
    Rate: 8239
    xrsxrs wrote:
    I am not looking for problems by force, but for the optimal solution :-) ; by the way, I don't see much difference whether I connect via cable or via wifi;
    And if you cut the link bandwidth to 25Mbps, you won't see it either, so the optimal solution is either, since both work the same. If something is clipping and freezing, it does not have to be the fault of the router TV connection.
  • #23 16916415
    IC_Current
    Help: 1499
    Rate: 2509
    As your colleagues wrote above:
    The cable is always a more stable solution and eliminates 90% of future problems. You are 50 cm, so it's easy. The bandwidth of the transmission channel is only one of the link parameters - usually not even the most important.
    Anyway, you connect the TV via WiFi, you will cut the radio band that you can use for other mobile devices (retransmissions, variable delays for WhatsApp, damaged frames, etc.). You will gain nothing on TV and you can lose in another place.
  • #24 16984057
    xrsxrs
    Rate: 24
    In general, my question came from the fact that I had problems with Netflix, i.e. buffering a movie or series that was being started up to 25% and nothing. I thought that it may be a problem with the speed and stability of the connection, etc. or, as above, my colleague indicated a defect of the UPC router. But interestingly, none of these things. It turns out that on the UPC community forum and in accordance with UPC's recommendations, the remedy for this is to simply disable IPv6 on the router (in DHCP settings), and leave only IPv4 (by phone via a consultant or via chat). Well, it helped, everything is running smoothly now. It is said that it also helps with VPN problems, network games etc. I hope this post will help other users with a similar problem.
  • #25 16984074
    KOCUREK1970
    Help: 3835
    Rate: 5431
    xrsxrs wrote:
    It turns out that on the UPC community forum and in accordance with UPC's recommendations, the remedy for this is to simply disable IPv6 on the router (in DHCP settings), and leave only IPv4 (by phone via a consultant or via chat). And it helped
    However, this does not change the fact that this equipment is very problematic and its disadvantages have not been eliminated to this day (and in my opinion they will not be, because it is a disadvantage of the chipset itself).
    And new info - the need to restart Compal (and sometimes even reset with a button) which has been working non-stop for over 2 months.
  • #26 16984671
    xrsxrs
    Rate: 24
    you are right, it does not change the fact of its defectiveness and trashiness; when it comes to resetting, I do not have such a need, maybe because I always turn it off at night (because why should it pull electricity, disrupt other bands, emit waves that are probably harmful to humans overnight).
  • #27 16984955
    AxelNext
    Help: 265
    Rate: 451
    xrsxrs wrote:
    I always turn it off at night (because why would it draw electricity, disturb other bands, emit waves that are probably harmful to humans during the night).
    I do that too :D
    As for the connection, all you need to do is connect the Connect Box to the TV with the cable attached to the Connect Box, or with another CAT5E cable.
    There is no need to combine with WiFi because the cable will always have a more stable connection.
    KOCUREK1970
    Help: 3835
    Rate: 5431
    Compal is quite ok here - if you do not use it, it reduces power consumption to a minimum (turns off LAN ports, wifi and other services).
    Its power consumption with full load is about 13W / h, on average about 10W / h, in "standby" it is about 3W / h.
  • #29 16997810
    xrsxrs
    Rate: 24
    To sum up, a cable always better than Wifi; Compal with UPC is said to have manufacturing defects; Netflix in UPC works better sometimes when it turns off on their IPv6 router. I close the topic.
✨ The discussion centers around the comparison of transfer speeds between LAN and WiFi N 5GHz for connecting a TV to a router. Users generally agree that a wired LAN connection is more stable and reliable than WiFi, especially for high-bandwidth applications like streaming 4K content. While WiFi N can theoretically offer higher speeds, real-world performance is often lower due to interference and distance. The TV in question supports only 100Mbps Ethernet, making a Cat6 cable unnecessary for its capabilities. Users also mention that issues with Netflix buffering may be resolved by disabling IPv6 on the router. Overall, a wired connection is recommended for optimal performance, particularly given the proximity of the router to the TV.
TL;DR: Netflix 4 K needs only 25 Mbps, and “Cable is always better” [Netflix Help; Elektroda, sebap, #16914728]. A short Cat5e lead gives a rock-solid 100 Mbps link, while WiFi N 5 GHz averages 100–150 Mbps but fluctuates [Elektroda, lopr_pol, post #16910459] Use the cable if the TV is within reach for maximum stability.
Why it matters: Avoiding wireless dropouts protects picture quality and frees WiFi for phones and laptops.
• Netflix Ultra HD/4 K recommended bitrate: 25 Mbps [Netflix Help]. • Panasonic TX-series Ethernet port: 10/100 BASE-TX only [Elektroda, xrsxrs, post #16915422] • Real-world 802.11n 5 GHz throughput: 100–150 Mbps [Elektroda, lopr_pol, post #16910459] • Cat5e supports up to 1 Gbps over 100 m runs [TIA-568]. • UPC Connect Box LAN ports are 1 Gbps each [Elektroda, KOCUREK1970, post #16914750]
Which link is faster for a 2017 Panasonic TV: 100 Mbps Ethernet or WiFi N 5 GHz?
A cabled 100 Mbps Ethernet link delivers stable, full-duplex throughput, while WiFi N 5 GHz peaks near 150 Mbps but drops with interference. Stability trumps the small speed edge, so Ethernet wins for consistent 4 K streaming [Elektroda, lopr_pol, post #16910459]
How much bandwidth does Netflix really need for 4 K HDR?
Netflix recommends 25 Mbps sustained download for Ultra HD titles. That fits comfortably inside a 100 Mbps wired link and most mid-range WiFi connections [Netflix Help].
Does my Panasonic 2017 model support Gigabit Ethernet?
No. Its spec lists IEEE 802.3 10BASE-T / 100BASE-TX only, so it negotiates 10 or 100 Mbps, never 1 Gbps [Elektroda, xrsxrs, post #16915422]
Is buying a Cat6 cable worthwhile if the TV port is 100 Mbps?
Cat5e already exceeds the TV’s 100 Mbps limit and costs less. Use Cat5e unless you need future 1 Gbps on that run [TIA-568].
Does 5 GHz WiFi transfer data faster than 2.4 GHz?
Both bands share the same 802.11n PHY; the 5 GHz band offers less interference, not higher raw speed. Throughput differences are usually under 10 % [Elektroda, cyryl85, post #16914183]
Will streaming the TV on WiFi slow down my phones and laptops?
Yes. The TV will occupy airtime; other wireless devices must wait, increasing latency and lowering their speeds [Elektroda, IC_Current, post #16916415]
Quick How-To: Disable IPv6 on a UPC Connect Box
  1. Log in at 192.168.0.1 with admin credentials.
  2. In Advanced → DHCP, untick IPv6 and save.
  3. Reboot the modem and TV [Elektroda, xrsxrs, post #16984057]
What problems are linked to the Puma 6 (Compal) chipset?
The Compal Connect Box uses the Puma 6 SoC, known for high latency spikes and packet loss under load—a streaming edge case that causes stalls [Elektroda, KOCUREK1970, post #16916393]
Can WiFi ever outperform Ethernet?
A top-tier 802.11ac or WiFi 6 setup can exceed 1 Gbps in lab tests, yet walls, neighbors, and distance slash real throughput. A shielded Cat6 cable still outperforms in worst-case scenarios [Cisco, 2023].
What real throughput should I expect from WiFi N 300?
Expect 100–150 Mbps under ideal conditions—about half the 300 Mbps headline because WiFi is half-duplex and overheads consume bandwidth [Elektroda, lopr_pol, post #16910459]
