Passat B6 - P2015 Error: Finding Suction Murmur Suppression Sensor in BMP 2006 Engine
bobo 44 18162 6
  • #1 16509600
    bobo 44
    Help: 28
    Rate: 196
    Hello, there was an error, suction murmur suppression sensor in the intake manifold, can anyone tell me where I will find in my car engine type BMP 2006 not CR.
  • #2 16509901
    goldwinger
    Help: 535
    Rate: 2102
    Under the hood on the right side of the head / room. valves
    It's probably jamming
  • #3 16509914
    bobo 44
    Help: 28
    Rate: 196
    Is this where the vacum pump is?
  • #5 16509935
    bobo 44
    Help: 28
    Rate: 196
    This is not the engine, those from the video are engines after 2008 from CR
  • #6 16908179
    misior1990
    Rate: 9
    Hey
    Dude, you've come to what could be the reason? I will add that I also have a BMP engine
    Regards
  • #7 16908880
    bobo 44
    Help: 28
    Rate: 196
    so check the sensor from the throttle he crashes and the throttle moves him. If everything is good let me know then I will write you what can be. Regards
The discussion revolves around the P2015 error related to the suction murmur suppression sensor in the intake manifold of a Volkswagen Passat B6 with a BMP engine from 2006. Users suggest that the sensor is located under the hood on the right side of the head near the valves. There is a mention of a vacuum pump, but a user clarifies that a linked video shows engines from after 2008, which are not applicable. Another user with a BMP engine shares their experience and suggests checking the throttle sensor, as it may be malfunctioning and affecting the throttle's operation.
