Passat B6 2.0 TDI - Manual DPF Cleaning vs Pressure Difference Sensor Replacement: P2002 Error
dymek112 10590 1
  • #1 16706628
    dymek112
    Help: 5
    Rate: 12
    I am thinking about cleaning the DPF manually, i.e. cutting it and pouring it with a special liquid, or replacing the pressure difference sensor.
    There is error P2002, MIL ON, the DPF indicator is on, the glow plug indicator is flashing. Sentences are divided as to the fault. I can not remove the filter, the owner drives around Europe.
    Actual values:
    Passat B6 2.0 TDI - Manual DPF Cleaning vs Pressure Difference Sensor Replacement: P2002 Error Passat B6 2.0 TDI - Manual DPF Cleaning vs Pressure Difference Sensor Replacement: P2002 Error Passat B6 2.0 TDI - Manual DPF Cleaning vs Pressure Difference Sensor Replacement: P2002 Error
    I do not know whether forced firing would make sense due to the large amount of soot.
    Any advice? A sensor, or indeed a clogged filter?
  • #2 16706888
    adam7009
    Help: 656
    Rate: 1635
    why are the sentences divided ??, you can not check the sensor?
    AUTO-ELELEKTRONIK AB
    Linowiec, Lisewo, 86-230 | Tel.: 697XXXXXX (Show)
