Creating Warehouse Database in VBA Excel: Adding Products, Quantity, and Auto-updating Date-Time
dj_wlodi_2000 3942 4
  • #1 16909530
    dj_wlodi_2000
    Hello all
    I will answer the questions right away, I'm not looking for a ready-made, I haven't used exel for 7 years and I'd rather do it on SQL and PHP :D
    I have a task not for my strength and time. I need to do in exel, which is a strange option for me, the warehouse base in which I search for the product, it falls into the box with the entire (3 columns) name, then I add the size and quantity of the order below, which then goes to the next window with orders from the customer. Plus adding a data client. Adding the date and time of your order would be fun to download automatically.
    What do I have a product search and the date automatically pops up after pressing a button on the keyboard but I would like it to be constant because it can be edited. I have to add to the sheet but I need to check the last empty cell and add another order.
    I would like to ask you to take a look and suggest how to go about it.
    How to change it to search in 3 columns?
    With Sheets ("Base")
    list = Range ("Base! A: A"). Value
    'we need a multidimensional list
    list2 = Application.Transpose (list)
    'we filter the list
    list2 = Filter (list2, Me.TextBox1.Value, True, vbTextCompare)
    'I put a filtered list into the Listbox
    Me.ListBox2.List = List2
    End With
    End Sub
    • Kopia Baza.rar (36.85 KB) You must be logged in to download this attachment.
  • #2 16920833
    dj_wlodi_2000
    I need to do a search, will anyone help?
    • Baza.rar (238.45 KB) You must be logged in to download this attachment.
  • Use range-based array loading for filtering
    #3 16925843
    adamas_nt
    Help: 1508
    Rate: 659
    Uh oh! So you have to re-program from scratch ...
    Starting with "list = Range (" Base! B: B "). Value" - the array has size = number of rows in the sheet = 1,048,576 in Excel 2007.
    I understand that the 'TextBox1' will be filled with criteria for filtering the 'ListBox2' list containing the list of articles from the "Database".
    Filtering a multi-column list was once implemented by one of the forum users. An example in the appendix. Notice the Instr / Left (contains / from left) in the code for the criteria text boxes.
    • ListBox(2)_filtr.xls (127.5 KB) You must be logged in to download this attachment.
  • #4 16926556
    lanzul
    Level 30  
    Help: 199
    Rate: 123
    Function ' Filter 'does not support "multidimensions" - if the target allows it, then divide it into three stages, separate search for each column - if not, because it is to be one-whole, then you need to find some substitute of the type: equating variables in a simple loop, e.g. ' To ... Loop 'plus array or' Find 'in a loop plus an array, etc.
  • #5 16935224
    dj_wlodi_2000
    The program is working you had to do everything from the beginning thanks for your support
