How can I build an Excel-based warehouse file that records component purchases, tracks stock, and deducts the right quantities when I ship finished products based on each product’s technology list?
The workbook should treat stock as a dynamic report built from source documents (PW, RW, PZ and WZ), so manual edits in DocumentsPZ/DocumentsWZ will break the balances; if that happens, use the button to restore states from the beginning based on the documents [#16836495] For production, enter each product’s BOM/technology in the technology tabs, and the help sheet is used to check the raw materials needed for the 10 selected products on the production tab [#16843905] Use the dictionary and exact assortment names because spaces matter, and do not paste blindly into the technology table or the name checks may fail [#16843905] The stock column can show minimum levels, and low states are highlighted in red; quantity safeguards are also built in, but you should test whether production is blocked correctly when stock is insufficient [#16843905] Enter only positive quantities, treat empty quantity cells as zero, and note that the file was written in Excel 2016 but should work from Excel 2007 upward [#16836495]
  • #1 16819322
    fighter31
    Hello everybody,
    Generally, I would like to create / modify a file that I place to run a micro production of electronic products. For this I need a file in which I will be able to record the purchase of electronic components and mark it quantitatively. How do you remove from the warehouse ready products for construction which I used components lying in the warehouse.
    That's generally what I would like to get.
    As for the tabs, in the tabs "Extr1 technology, etc." I want to enter what product range a given product consists of. And by clicking on product shipping, I want the quantity of the assortment included in the quantities entered in the technology to leave the warehouse.
    I intend to have a maximum of a dozen products - therefore tabs with technology will be adequate.
    Indexes for shipment would like to be only those entered in cells D3 in the tab "Extr1 technology, etc.".
    Someone is able to help me in this endeavor, for processing I put a file "magazine" in which some things are done.
    The base file I mentioned is under the link: https://www.elektroda.pl/rtvforum/topic2973819.html#14359769
    I cannot return it directly because the extension is incorrect.
    I would ask experts for help.
    • mag prod.xlsx (16.26 KB) You must be logged in to download this attachment.
    marek003
    Level 40  
    Help: 801
    Rate: 488
    Know my good heart :)
    Stock levels are created on the basis of entered documents, so "manual" intervention in the sheets DocumentsPZ and DocumentsWZ will "break" the states.
    Stock levels are getting up-to-date but if something stuck, the button Restore states based on documents from the beginning will create a statement
    There are some security instruments but I don't know if the workbook is fully idiotootproof. How to check this first before you start using the file seriously. Later, however, I would advise you to enter the data correctly, i.e. if there is a quantity, then enter a positive quantity and not letters or negative values.
    I note that the empty cell at the quantity is zero for calculations.
    I wrote the file in Excel2016 but it should work above E2007, it will get older.
    • Magazyn z produkcją.zip (134.53 KB) You must be logged in to download this attachment.
    marek003
    Level 40  
    Help: 801
    Rate: 488
    fighter31 wrote:
    Hi Mark! The file works great, there is much more than I wanted, I didn't even think about recording PW and PZ and I would know when it came and went! REVELATION.
    Tell me such a thing, if the technology tab could be changed columns with rows so that it is easier to paste material and quantities with BOMA.
    The second thing is whether in the magazine tab next to the status you can add a column with minima entered for each item from your finger and in case when the stock level drops below this value, the cell color will be highlighted in red (such as Kanban).
    And one last thing, but I don't know if it can be overcome in excel so that in the case of zero or smaller than needed for production it is impossible to make a shipment and that there was an alert that it is not possible to carry out due to deficiencies.
    I still have a question about the help tab - what is it for?
    File attached
    1. The columns with rows have been replaced - but I advise against pasting because then the protection against entering the incorrect name will not work. For Excel, a space is also a character and if the dictionary does not have the same name, the program will report a technology error.
    30 assortments is not much to do by hand, the more that you can check everything.
    2. The column with the minimum is in the Dictionary. and too small states "burn" in red both in the dictionary and in the magazine tab.
    3. Quantitative safeguards are made but I am human and I could have been wrong somewhere so check for yourself if it works well. Test for yourself if you can produce something without states.
    4. The help file is now used to check the raw materials needed to produce each of the 10 products selected in the production tab. Do not interfere with the operation of this sheet - you can hide it.
    I mark it once again - I - the man wrote - and I could overlook / miss something. Before you start using the file seriously, test it in every direction.
    I treat it as fun and I am not responsible if for some error in the code the inventory would not be correct and ultimately someone would be unpleasant because of it.
    One more thing
    The magazine as such is just a dynamic REPORT. Correction of data in this spreadsheet will not work in the long run. Because after pressing "refresh states" based on source documents (PW RW PZ and WZ) will correct any corrections.
    If it is necessary to improve the stock level, it should be corrected in the source document (PW RW PZ or WZ)
    The sheets have protection but I didn't password them so remove the protection - improve the data and turn protection on again
    As I corrected the file, it seemed to me that this first file may have an error when checking the right amount of raw material during production (I did not include 10 times)
    • Magazyn z produkcją2.zip (145.61 KB) You must be logged in to download this attachment.
  • #4 16843951
    fighter31
    Thanks so much Mark!
    I will play and let Excel know how it behaves.
  • #5 16939182
    Ipeainyourtea
    Hello, I was looking for a small book storage program in a bookstore and generally this file meets my expectations. I have questions if I can add such options:
    1) DELIVERY
    a) Acceptance of PZ plus own text to enter
    b) name hints from the data in the dictionary (because we are talking here about a few thousand names sometimes, hints would help significantly)
    These two things would improve this file for me amazingly.
    PS. Change of the number of PZ and WZ to 100 from 10.
  • #6 17036407
    msk234
    File attached
    One more thing
    Mr. Mark, I have a question for this file. Shouldn't the shipping tab also include manufactured products?
  • #7 17039158
    marek003
    Level 40  
    Help: 801
    Rate: 488
    It should take into account as much as possible and at the beginning only included in the heat of corrections and facilitation I forgot to change dictionaries.
    It should be fine now but ... please check. (I used to do it a long time ago and I don't remember all dependencies)
    • Magazyn z produkcją3.zip (127.06 KB) You must be logged in to download this attachment.
  • #8 17039174
    msk234
    My question was a bit too fast because I came to the fact that I need to complete the dictionary. But in the meantime I had one more problem with the spreadsheet and despite attempts to edit the macro, I couldn't solve it. Namely, could it define the variables in such a way that they were not integers? I have a situation when for the production of a given product I use fractional parts from stock, e.g. a profile with a length of less than a meter or with a length of more than 1.5m.
  • Request to include manufactured products and expand technology positions to 100
    #9 17041265
    fighter31
    Mr. Marek, a small request, could you please extend the number of positions in product technology to 100. I have quite complex products and 30 is not enough for me.
    Thank you very much in advance
  • #10 19887711
    wieslawprugar
    I wanted to ask Mr. Marek if this excel could also keep records with units (g, ml, kg, dm3, etc.)?
    Wieslaw
  • Unitless warehouse entries by assortment name
    #11 19889115
    marek003
    Level 40  
    Help: 801
    Rate: 488
    Wieslaw
    It depends how you want to run this warehouse.
    To tell the truth, this "warehouse" is unitless, or rather "piece", but it can be assumed that it will be also individual.
    Ie: what you enter in the name of a given assortment - this will be the unit and its subsequent quantity.
    It certainly does not provide for the total counting of individual assortments by units.
    It can be like this ("artfully"):
    So, for example, the name: "Apple juice 500ml", quantity: 6 - indicates that you have 6 pieces / units of juice 0.5l - (i.e. a total of 3 liters - but the program does not calculate this, the warehouse keeps only the amount of the given assortment and whether the assortment is 0, 5l or 5dm3 or 3g it does not matter to him).
    Now, if the assortment is "Orange juice 1l" and the amount is also 6, you will have 6 liters of juice.
    The next assortment after the juice can be, for example, "Raisins 35g" and their appropriate amount, for example 8. That is 8 pcs packages of raisins.
    But this warehouse can also be run under the unit - except that you have to understand it yourself and to be sure, somehow simply name the assortment, for example:
    name of the assortment: "Potatoes in bags [kg]", quantity: 98 it is logical that we have 98 kg of potatoes in bags.
    Similarly:
    name of the assortment: "Potatoes in bags a'25 [kg]", quantity: 98 so here we have a total of 98 kg potatoes in bags a'25
    (It should be supposed to be 100 kg, because the bags according to the name "a'25" should contain 25 kg but if we weigh the bags and do not carry them in pcs, it is ok, because it may happen that on average four 25kil bags are missing in each of them 0.5 kg of potatoes, i.e. 98 kg in total). Because we have established that we run a warehouse in the units entered as the last ones in the name of the assortment.
    The same in other units, e.g.
    name of the assortment: "Juice in a barrel a'400 [l]", quantity: 1087, so we have 1087 liters of juice in some barrels, probably not fully filled
    And here it is more difficult:
    name of the assortment: "Raisins 35g [kg]", quantity: 8, so we have 8 kg of raisins in some packages. Here, however, I would add some packaging to the name of the assortment because it can actually be misleading, for example:
    "Raisins 35g in a carton [kg]" or "Raisins 35g palletized [kg]"
    I don't know if I explained clearly and if it will meet your needs.
  • Need fractional gram and 5-decimal pricing support
    #12 19889152
    wieslawprugar
    Hello, Thank you for your explanation. This is understandable to me. I am looking for a solution that would allow, however, to run the units mainly due to production. My recipes require precision and, for example, I need to enter e.g. fractional parts of a gram. In addition, ultimately I also want to generate RW / PW on products with prices (e.g. warehouse in average-weighted prices) and this is probably too far-reaching change. Likewise, unit prices would have to be entered to 5 decimal places.
    If such corrections were possible, I would be happy to discuss on priv?
    Wieslaw
  • #13 19889639
    marek003
    Level 40  
    Help: 801
    Rate: 488
    For such a thing, I suggest looking for a serious program, not a toy in excel, which at any time with the "stupid" one can destroy the historical data or even blur the data completely with the record.
    Here you need something based on databases, not a spreadsheet.
  • #14 19889816
    wieslawprugar
    Of course, I know professional solutions. But this is an excess of form over needs for my needs. I was looking to make it simpler on Excel. Nevertheless, thank you for the answers and the discussion. Greetings. Wieslaw
The discussion revolves around creating and modifying an Excel file for managing the inventory of electronic components used in micro production. The user seeks assistance in tracking purchases, managing stock levels, and recording the quantities of components used in product assembly. Key features discussed include the need for a user-friendly interface to input data, safeguards against incorrect entries, and the ability to handle fractional quantities for precise production needs. Suggestions include enhancing the file with delivery options, name hints from a dictionary, and expanding the number of product positions. Some participants recommend considering more robust database solutions for complex inventory management, while others prefer to keep it simple within Excel.
TL;DR: Excel workbook tracks inventory via documents (PZ/WZ/PW/RW) for up to 10 products and ~30 BOM rows; “Stock levels are created on the basis of entered documents.” [Elektroda, marek003, post #16836495]
Why it matters: It prevents silent spreadsheet errors by recalculating stock from source documents, not manual edits, ideal for micro-production users.
How do I record purchases and shipments in this Excel?
Use document sheets: PZ for receipts, WZ for issues, PW for production receipts, RW for production consumption. Stock states are computed from these documents. If states ever stall, use the Restore button to rebuild from the start. Quick how-to: 1. Enter PZ for incoming parts. 2. Enter PW/RW for production. 3. Enter WZ for sales/shipment. [Elektroda, marek003, post #16836495]
How do I avoid breaking stock levels by editing the wrong place?
Do not edit the Magazine sheet; it is a dynamic report. Edit only the source documents (PW, RW, PZ, WZ). “The magazine as such is just a dynamic REPORT.” After corrections, press Refresh/Restore to rebuild states. Manual edits in DocumentsPZ/DocumentsWZ will break states. [Elektroda, marek003, post #16843905]
Can I highlight low-stock items automatically (like Kanban)?
Yes. Set minimum levels in the Dictionary sheet. When actual stock falls below the minimum, cells highlight red in both Dictionary and Magazine. This visual alert supports quick replenishment decisions for small shops. [Elektroda, marek003, post #16843905]
Can the workbook block shipments if stock is insufficient?
Yes. Quantitative safeguards exist to stop shipping when required stock is unavailable. The author stresses testing before live use to confirm behavior on your data and products. “I could have been wrong somewhere so check for yourself.” [Elektroda, marek003, post #16843905]
What does the Help sheet do, and can I hide it?
Help calculates raw materials needed for each of the 10 products selectable in the Production tab. Do not modify its logic; hide it if you prefer a cleaner interface. This keeps planning accurate for multi-part builds. [Elektroda, marek003, post #16843905]
Will manufactured products appear correctly in the Shipping tab?
Yes, after an early omission, dictionaries were adjusted so shipping can include manufactured products. Update your Dictionary entries and verify flows after any changes. [Elektroda, marek003, post #17039158]
Can I use fractional quantities (grams, meters) and high-precision pricing?
The workbook is unitless and effectively counts pieces. For precise recipes (fractional grams and 5‑decimal prices), the author recommends a database-based system rather than this Excel model to avoid data integrity issues. [Elektroda, marek003, post #19889639]
Which Excel versions are supported?
The file was written in Excel 2016 and should work on Excel 2007 and newer. If you rely on macros, enable them and test thoroughly with sample data before go‑live. [Elektroda, marek003, post #16836495]
How many BOM/Technology lines can I have, and can I expand to 100?
The shared setup targets about 30 lines per product Technology. A user requested 100 lines for complex products; achieving this requires VBA and sheet range updates by the author or an Excel developer. [Elektroda, fighter31, post #17041265]
Can I increase PZ/WZ document counts from 10 to 100?
A user requested expanding PZ/WZ to 100. This is feasible with macro and range changes, but it is not included by default. Engage the workbook author or adapt the VBA with proper testing. [Elektroda, Ipeainyourtea, post #16939182]
Why does pasting names into Technology cause errors?
Validation checks require exact matches to Dictionary names. Even a trailing space counts as a character and triggers a Technology error. Enter names manually or clean pasted text to avoid mismatches. [Elektroda, marek003, post #16843905]
How do I rebuild stock if calculations look wrong or "stuck"?
Use the button labeled “Restore states based on documents from the beginning.” It reconstructs inventory from all PZ/WZ/PW/RW entries and resolves transient state issues. [Elektroda, marek003, post #16836495]
What do PZ, WZ, PW, and RW mean here?
They are the document types used by the workbook: PZ/WZ for warehouse receipts/issues and PW/RW for production receipts/consumption. The engine calculates states only from these, not from manual stock edits. [Elektroda, marek003, post #16836495]
Is the workbook "idiot-proof" for production use?
No. The author warns it may not be fully foolproof. Enter correct data types, avoid negative quantities, and test every direction before serious use. Empty quantity cells count as zero in calculations. [Elektroda, marek003, post #16836495]
Can I manage units like kg, ml, or liters within this setup?
Yes, by encoding the unit in the item name, such as “Apple juice 500ml” or “Potatoes [kg].” The system still totals pieces per unique name; it won’t auto-sum liters or kilograms across items. [Elektroda, marek003, post #19889115]
