Securing Networks with Mikrotik Firewall Rules for Site-to-Site and Client-to-Site Tunnels
robsonet 4914 1
  • Mikrotik firewall hardening for VPN and LAN access
    #1 16912163
    robsonet
    I have a site-to-site tunnel set up between the headquarters and the branch in Mikrotiki and I connect to both places via client-to-site 2TP + IPSEC.
    The branch connects to the headquarters using RDP and printers transferred in the session. Users at the headquarters and in the branch are to have access to the Internet, below I paste the firewall rules analogous to the headquarters and branches. I would like to ask for help in securing both networks, I would like to do it on the principle of letting in what needs to be done and cutting out the rest.
    /ip firewall filter
    add action=accept chain=input comment="akceptuj WinBox z zewnatrz" dst-port=\ 8291 in-interface="ether1 WAN" protocol=tcp - tutaj oczywiście nie koniecznie bo mogę wejść na Winboxa lokalnie po podłączeniu się przez VNP client-to-site
    add chain=input in-interface="ether1 WAN" src-address=xx.xx.xx.xx - tutaj adres filii i analogicznie adres centrali w ruterze filii
    add action=accept chain=input comment="akceptuj L2TP" dst-port=1701 \ in-interface="ether1 WAN" protocol=udp
    add action=accept chain=input comment="akceptuj IPsec" dst-port=500 \ in-interface="ether1 WAN" protocol=udp
    add action=accept chain=input comment="akceptuj IP sec VPN" dst-port=4500 \ in-interface="ether1 WAN" protocol=udp
    add action=accept chain=input comment="defconf: accept ICMP" in-interface=\ "ether1 WAN" protocol=icmp
    add action=accept chain=input comment="defconf: accept established,related" \
    connection-state=established,related in-interface="ether1 WAN"
    add action=accept chain=forward comment="defconf: accept established,related" \
    add action=drop chain=input comment="defconf: drop all from WAN" \
    add action=drop chain=forward comment="defconf: drop invalid" \
    connection-state=invalid in-interface="ether1 WAN"
    add action=drop chain=forward comment=\
    "defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new in-interface="ether1 WAN"
    /ip firewall nat
    add action=masquerade chain=srcnat comment="defconf: masquerade" \
    out-interface="ether1 WAN"
    I don't have much experience with rules.
  • #2 17236126
    misiekx007
    I would recommend connecting to mikrotik via VPN from lan side, so distable add action = accept chain = input comment = "accept WinBox from outside" dst-port = \ 8291
    And the router firmware update (especially the one with the 8291 exposed to the world, update fixes the hole)
    Source: https://forum.mikrotik.com/viewtopic.php?f=21&t=133533
    Source2: https://niebezpiecznik.pl/post/ Szybko-aktualizacjicie-mikrotiki/
    Do you need ICMP from the WAN side? Bots will catch that something is pinging at this address.
    I did it like this, although those bigger than me would probably change something: (firewall / filter itself)
    add action = drop chain = input comment = "Drop connections from blacklist" connection-state = new in-interface = "001. WAN" src-address-list = blacklist
    add action = drop chain = input comment = "Drop invalid connections" connection-state = invalid
    add action = accept chain = input comment = "Allow L2TP Traffic" dst-port = 1701 in-interface = "001. WAN" protocol = udp
    add action = accept chain = input comment = "Allow SSTP Traffic" dst-port = 443 in-interface = "001. WAN" protocol = tcp
    add action = accept chain = input comment = "Allow IKE - Internet Key Exchange for IPSEC" dst-port = 500 in-interface = "001. WAN" protocol = udp
    add action = accept chain = input comment = "Allow NAT-T - IPSec Network Address Translation" dst-port = 4500 in-interface = "001. WAN" protocol = udp
    add action = accept chain = input comment = "Allow VPN traffic" in-interface = all-ppp
    add action = accept chain = input comment = "Allow new connections to the router from authorized networks" connection-state = new in-interface = BRIDGE_DOM \
    src-address-list = ALLOW
    add action = accept chain = input comment = "Allow established and dependent connections" connection-state = established, related
    add action = drop chain = input comment = "Drop Everything Else"
    add action = drop chain = forward comment = "Drop invalid connections" connection-state = invalid
    add action = accept chain = forward comment = "Allow new connections to the router from authorized networks" connection-state = new in-interface = BRIDGE_DOM \
    add action = accept chain = forward comment = "Allow established and dependent connections" connection-state = established, related
    add action = accept chain = forward comment = "Allow LAPTOP to remotely access the DOM network" dst-address = 192.168.77.0 / 24 src-address = 10.100.100.100
    add action = accept chain = forward comment = "Allow PHONE to remotely access the DOM network" dst-address = 192.168.77.0 / 24 src-address = 10.100.100.101
    add action = drop chain = forward comment = "Drop Everything Else"
    The address list includes the allowed LANs.
    Blacklist includes addresses downloaded using http://joshaven.com/resources/tricks/mikrotik-automatically-updated-address-list/
    The order of entries DOES matter :)
    This is a simple, unused example. I won't paste the working config, but before replacing the router and rebuilding it worked steadily :)
    Generally, I once heard the rule that it is worth allowing yourself access to the winbox, then cut everything on the inputa and forward and add the generation that you need. There is some logic to this.
    Hope I helped.
    best regards
