Securing Mikrotik Network: MAC Address Filtering for 10 LAN Computers, ARP Configuration & Tips
robsonet 9636 12
How can I restrict a MikroTik LAN so only 10 approved computers can get network access using DHCP, ARP reply-only, and firewall rules?
Set the DHCP server address pool to static-only, enable add-arp-for-leases, and make each approved computer static from DHCP Server → Leases so their ARP entries are created automatically. Keep the clients on DHCP, then set the LAN interface to ARP reply-only; if a device uses a fixed IP, remove that entry from the router’s ARP table before testing, because only DHCP-leased devices should remain there [#17070369][#17081867] With that in place, an unapproved PC will not receive an address from DHCP, and even if it configures a manual IP, the network should still not work for it [#17072093] For additional security, add a proper firewall: drop invalid traffic, accept established/related, allow only the needed WinBox/L2TP/IPsec/ICMP traffic from WAN, then drop the rest [#17072347]
  • #1 17069625
    robsonet
    I wanted to do MAC address filtering on MT, according to the assumption, I have 10 LAN computers in the network and only they should be able to connect to the network so that it is the safest.
    I did the ARP list by adding the IP and MAC of the computer and then on the Ethernet interface I marked ARP: reply-only but unfortunately I could still connect to other computers.
    I would like to ask you for help with steps to best secure this, thank you in advance.
  • #2 17069822
    ryba884
    Level 19  
    Help: 33
    Rate: 49
    Set the address-pool to static-only in the DHCP server, check add-arp-for-leases, add computers by MAC and assign them static addresses. Additionally, set the interface on which the DHCP server is ARP reply-only. It should work.
  • ARP reply-only may block WinBox access
    #3 17070227
    robsonet
    Thanks for the hint, I did as you wrote, but then I could not connect my computer to WinBox, even though it gave me an IP, not what was supposed to be only still with DHCP, maybe somewhere else some option?
    ryba884
    Level 19  
    Help: 33
    Rate: 49
    But you assigned addresses in DHCP and not computers? Computers are still to be set to dhcp. You can do it with a semi-automatic machine. First, leave the usual address pool. Log in to mikrotik and go to DHCP Server -> Leases. There, right-click to select other computers and click on make-static. After adding all computers, change addres-pool to static only. And check ;)
  • Make DHCP leases static and use static-only pool
    #5 17071921
    robsonet
    I did according to your instructions and it seems to work. A computer that is not on the list does not get an address from the DHCP pool, is there anything else you can do / set to increase security?
  • #6 17072093
    ryba884
    Level 19  
    Help: 33
    Rate: 49
    Even if he sets his address hard, the network will not work for him. The rest is a proper firewall.
  • #7 17072261
    robsonet
    I have a site-to-site tunnel configured between the headquarters and the branch in Mikrotiki and I connect to both places via client-to-site 2TP + IPSEC.
    The branch connects to the headquarters using RDP and printers transferred in the session. Users at the headquarters and in the branch are to have access to the Internet, below I paste the firewall rules analogous to the headquarters and branches. I would like to ask for help in securing both networks, I would like to do it on the principle of letting in what needs to be done and cutting out the rest.
    The rules I have are:
    /ip firewall filter
    add action=accept chain=input comment="akceptuj WinBox z zewnatrz" dst-port=\ 8291 in-interface="ether1 WAN" protocol=tcp - tutaj oczywiście nie koniecznie bo mogę wejść na Winboxa lokalnie po podłączeniu się przez VNP client-to-site
    add chain=input in-interface="ether1 WAN" src-address=xx.xx.xx.xx - tutaj adres filii i analogicznie adres centrali w ruterze filii
    add action=accept chain=input comment="akceptuj L2TP" dst-port=1701 \ in-interface="ether1 WAN" protocol=udp
    add action=accept chain=input comment="akceptuj IPsec" dst-port=500 \ in-interface="ether1 WAN" protocol=udp
    add action=accept chain=input comment="akceptuj IP sec VPN" dst-port=4500 \ in-interface="ether1 WAN" protocol=udp
    add action=accept chain=input comment="defconf: accept ICMP" in-interface=\ "ether1 WAN" protocol=icmp
    add action=accept chain=input comment="defconf: accept established,related" \
    connection-state=established,related in-interface="ether1 WAN"
    add action=accept chain=forward comment="defconf: accept established,related" \
    add action=drop chain=input comment="defconf: drop all from WAN" \
    add action=drop chain=forward comment="defconf: drop invalid" \
    connection-state=invalid in-interface="ether1 WAN"
    add action=drop chain=forward comment=\
    "defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new in-interface="ether1 WAN"
    /ip firewall nat
    add action=masquerade chain=srcnat comment="defconf: masquerade" \
    out-interface="ether1 WAN"
    I don't have much experience with rules, could you please advise me based on the above?
    ryba884
    Level 19  
    Help: 33
    Rate: 49
    I would do it like this:
    /ip firewall filter
    add action=drop chain=input comment="drop invalid" connection-state=invalid
    add action=accept chain=input comment="accept established,related" connection-state=established,related in-interface="ether1 WAN"
    add action=accept chain=input comment="akceptuj WinBox z zewnatrz" dst-port=8291 in-interface="ether1 WAN" protocol=tcp
    add action=accept chain=input comment="akceptuj L2TP" dst-port=1701 in-interface="ether1 WAN" src-address=xx.xx.xx.xx protocol=udp ipsec-policy=in,ipsec
    add action=accept chain=input comment="akceptuj IPsec" dst-port=500 in-interface="ether1 WAN" src-address=xx.xx.xx.xx protocol=udp
    add action=accept chain=input comment="akceptuj IP sec VPN" dst-port=4500 in-interface="ether1 WAN" src-address=xx.xx.xx.xx protocol=udp
    add action=accept chain=input comment="accept ICMP from WAN" in-interface="ether1 WAN" protocol=icmp
    add action=drop chain=input comment="drop all from WAN" in-interface="ether1 WAN"
    add action=drop chain=forward comment="drop invalid" connection-state=invalid
    add action=accept chain=forward comment="accept established,related" connection-state=established,related
    add action=drop chain=forward comment="drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface="ether1 WAN"
    add action=drop chain=output comment="drop invalid" connection-state=invalid
    /ip firewall nat
    add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface="ether1 WAN"
    It's still a little bit missing, but nobody here will write it for you. You can also secure traffic from the inside (in input and forward chains). I suggest you read the Mikrotik wiki, review the information regarding iptables . Have a look again packet flow .
  • #9 17072421
    robsonet
    /ip firewall filter
    /ip firewall nat
    Thanks so much for the information I will study the topic. best regards
  • #10 17081379
    robsonet
    I will come back to the topic, testing the proposed settings, I set the static IP, mask and gate at the end and the computer connected to the resources. Where else can you secure?
    ryba884
    Level 19  
    Help: 33
    Rate: 49
    Do you have reply-only mode on the interface with dhcp arp? A computer with a fixed address should not be in the router's arp table. You must remove it before testing. That way only devices that get an address from dhcp are in the arp table.
  • #12 17085933
    robsonet
    I marked it and it helped thanks.
    /ip firewall filter
    /ip firewall nat
    Back to your rules. When the connection is always from the same IP, I can enter it for ports 500,1701,4500 as you specified and when I connect with a laptop from many places by running VPN on L2TP, I do not enter this address because it is variable?
  • #13 17086899
    ryba884
    Level 19  
    Help: 33
    Rate: 49
    Yes. If you have a variable address, you do not enter it, because you will not be able to connect.
The discussion revolves around securing a Mikrotik network through MAC address filtering for 10 LAN computers. The user initially faced issues with ARP configuration, where marking the Ethernet interface as ARP: reply-only did not prevent unauthorized connections. Suggestions included setting the DHCP server to static-only, adding MAC addresses for the computers, and ensuring that only devices obtaining IPs from DHCP appear in the ARP table. The user successfully implemented these changes, preventing unauthorized devices from connecting. Further security measures discussed included configuring firewall rules to allow only necessary traffic and managing IPsec and L2TP VPN connections. The importance of removing static IPs from the ARP table before testing was also emphasized.
TL;DR: Allow only approved hosts by combining DHCP static-only + add-arp-for-leases + ARP reply-only; open 4 ingress services (8291, 1701, 500, 4500); "You can also secure traffic from the inside." [Elektroda, ryba884, post #17072347]
Why it matters: This helps MikroTik admins lock a small office LAN to known devices and harden L2TP/IPsec remote access.
  • Set DHCP address-pool=static-only to serve only pre-defined MAC-bound leases; unknown clients get no IP. [Manual:DHCP Server]
  • Enable add-arp-for-leases so DHCP fills ARP; with ARP=reply-only, only leased IP/MAC pairs pass. [Manual:DHCP Server]
  • On the LAN interface, ARP=reply-only blocks new dynamic ARP entries and spoofed hosts. [Manual:ARP]
  • Permit UDP 500/4500/1701 (IPsec/L2TP) and optionally TCP 8291 (WinBox) on WAN; drop the rest. [Elektroda, ryba884, post #17072347]
  • Order filters: drop invalid, accept established/related, then specific accepts; consult RouterOS packet flow. [Manual:Packet Flow]
How do I allow only specific LAN devices on MikroTik?
Use three controls together. Create static DHCP leases bound to each MAC. Set DHCP address-pool to static-only and enable add-arp-for-leases. On the LAN interface, set ARP to reply-only. This combination blocks unknown devices at Layer 2 and prevents rogue DHCP clients. [Elektroda, ryba884, post #17069822]
WinBox stopped working after I set static-only—how do I fix it?
You likely switched to static-only before converting active leases. Keep clients on DHCP. First convert each active lease to static (Make Static). Then change the DHCP server to address-pool=static-only. WinBox will work once your router has a static lease for your MAC. [Elektroda, ryba884, post #17070369]
Will a device with a manual static IP bypass this lock?
No, not with ARP=reply-only and clean ARP entries. If the device’s MAC still exists in the ARP table, it can work until removed. Clear that entry first. “A computer with a fixed address should not be in the router’s ARP table.” [Elektroda, ryba884, post #17081867]
What firewall rules should I use for L2TP/IPsec and WinBox?
Place drop invalid first, then accept established,related. Allow TCP 8291 (WinBox) if needed. Allow UDP 1701 (L2TP), 500 and 4500 (IPsec), and ICMP. Drop all remaining WAN input. Apply NAT masquerade for internet. These 3 UDP ports cover IPsec/L2TP. [Elektroda, ryba884, post #17072347]
Should I restrict L2TP/IPsec by source IP when I roam?
No. If your laptop’s public IP changes, restricting by src-address blocks you. Use src-address filtering only for fixed peer IPs, like branch HQ. Leave it open for roaming users, then secure via credentials and IPsec. [Elektroda, ryba884, post #17086899]
How do I quickly convert current DHCP clients to static leases?
Use the semi-automatic method in Leases.
  1. Keep a normal address pool and wait for clients to lease.
  2. In DHCP Server → Leases, select entries and click Make Static.
  3. Set address-pool=static-only and enable add-arp-for-leases. [Elektroda, ryba884, post #17070369]
Do I need add-arp-for-leases when using ARP reply-only?
Yes. add-arp-for-leases ensures only DHCP-leased IP/MAC pairs populate ARP. With ARP=reply-only, the router responds only for those pairs. This blocks devices that are not on your static lease list. [Elektroda, ryba884, post #17069822]
How do I harden from the inside (LAN to router and inter-VLAN)?
Create input rules that allow only management subnets to reach the router. Limit WinBox to trusted hosts or VPN. Add forward rules to permit only needed inter-VLAN flows. “You can also secure traffic from the inside.” [Elektroda, ryba884, post #17072347]
How can I manage MikroTik securely without exposing WinBox?
Disable TCP/8291 on WAN and manage over a VPN. Establish L2TP/IPsec, then connect WinBox to the router’s LAN address. This avoids exposing management to the internet entirely. The thread author used this approach. [Elektroda, robsonet, post #17072261]
Should I allow ICMP from the WAN, or block it?
Allowing ICMP helps diagnostics and MTU discovery. Many admins keep it permitted while dropping other unsolicited input. You can restrict it later if policy requires. Keep it after established,related and before the final drop. [Elektroda, ryba884, post #17072347]
How do I verify ARP/DHCP enforcement is working?
Clear the device’s ARP entry, then set a manual IP on that device and try access. With ARP=reply-only and no ARP entry, it should fail. If it works, remove stale ARP entries and retest. [Elektroda, ryba884, post #17081867]
How do the ‘drop invalid’ and ‘not dstnat’ rules help against WAN scans?
drop invalid removes malformed states early. The forward rule that drops new, not dstnat connections on WAN blocks unsolicited inbound traffic. Together, they reduce exposure while allowing established sessions. [Elektroda, ryba884, post #17072347]
