[Solved] Resetting Coffee Quantities on Delonghi ec 860m Espresso Machine - Factory Settings Restoration
brun71 14118 4
  • #1 16912735
    brun71
    Hello, I’ve had a De’Longhi EC 860M espresso machine for a month now.I’ve got a bit confused about the coffee serving quantities… I’m looking for information on how to reset these quantities – that is, to restore the factory settings or to perform a full factory reset… Best regards and thank you for any information you can provide.
  • #2 16912784
    siewcu
    Help: 133
    Rate: 458
    What does it mean "mixed up in the amount of coffee served"? Can you specify It will be known for the future what not to do so as not to mix up and accidentally get too much on the meter.
  • #3 16912811
    brun71
    Hello again. I mean the amount (in milliliters) of water for specific drinks e.g. espresso .., cappuccino .. how can you restore these factory settings?
    Added after 5 [minutes]:
    When I start a newly purchased espresso machine according to the instructions, in view of the fact that there is no americana coffee in the menu - holding down the espresso button, I received the desired coffee, thus programming the espresso button. But if you want to return to the factory setting, the instructions do not ma ..
    nioop
    Home appliances specialist
    Help: 503
    Rate: 3338
    This model does not have a so-called reset.
    Because, to be honest, this is pointless .. You can program the amount of coffee, and if you want to change the program settings, then the second time according to the instructions. After the reset you would have to do it anyway.
    Kawa i Naprawa - Serwis AGD
  • #5 17837644
    brun71
    Nioop is right :) I'm closing the topic ...
