Two months ago I bought a DeLonghi ECAM 22.110 coffee machine. I’ve had no complaints – everything seems to be working fine – but I’ve noticed that when I select the ‘large cup’ option, the coffee is just terribly weak. It’s very watery. What could be the reason for this? By default, the settings are for a small cup holding 40ml of coffee and a large cup holding 120ml. To get a normal cup of coffee, I have to press the button for two small cups into a single mug. Everything’s fine in that case.
However, when I select the ‘large coffee’ option or ‘two large’ options, even the colour of the coffee looks more like tea, it doesn’t smell like coffee and it’s just really weak. Should I make a complaint about the machine, or is there perhaps something I can do? Could it be the coffee’s fault? I don’t know what sort I used to have; now I’m on a 5/10 rating.
Well, as I’ve already mentioned, there’s no problem at all with the small cup – the coffee’s very good.
The problem only occurs when I select the ‘large coffee’ option. Can you help?
Thanks in advance
Thanks in advance
