Delonghi ECAM 3500S: Grinder Adjustment for Optimal Coffee Thickness & Strength (Coarse vs Fine)
Lukas32 10638 4
  • Grind finer to improve puck formation and strength
    #1 16580445
    Lukas32
    Help: 5
    Rate: 81
    How to correctly adjust the grinding thickness of coffee? I know more or less how finely the grinder should grind, but the problem I have is the following:
    The ground coffee is too coarse and the coffee is weak, but the thickness of the disc is ok, but it falls apart and is quite wet. After adjusting the grinder so that it grinds finer, everything seems fine, but they had less. However, it comes out of the grinder more slowly, and there is less coffee and it is also weak. I can't find this "golden" middle.
    Either the disc is the correct thickness and the ground coffee is too coarse, or it is ground well and the puck is too small. Anyway, the coffee comes out weak.
  • #2 16581636
    nioop
    Home appliances specialist
    Help: 503
    Rate: 3337
    Delonghi, I will say, after a dozen or so coffees, set the right amount of dispensed coffee.
    Screw the grinder a little and sip a cup of coffee for the day.
    Kawa i Naprawa - Serwis AGD
  • #3 16582464
    Lukas32
    Help: 5
    Rate: 81
    We'll drink - we'll see.
  • #4 16583841
    ssss
    Help: 471
    Rate: 1824
    The grinding stones should be replaced in the grinder because they are already stuck, and this is the symptom.
  • #5 16690951
    Lukas32
    Help: 5
    Rate: 81
    And it was just like that. Thanks
