iPhone 7 Battery Draining Fast, Lasts 8-9 Hours - Possible Issues & Model Replacement?
Skazany1986 21915 18
Why is my iPhone 7 battery draining to empty in 8–9 hours, and what should I do to fix it or get it replaced under warranty?
Check in Settings → Battery which app or process is using the most power, then try a factory reset and set the phone up as new; do not restore from an iCloud backup because you may bring the same problem back [#16913850] The thread also points to iOS 11 as a possible cause of unusually fast battery drain, so a clean install or reverting to an earlier, stable version was suggested if the problem started after updating [#16914956][#16915680] If the phone is still under warranty, you can complain again at the service center or seller since the first repair apparently did nothing [#16915464][#16915543] If the battery health is already low or the phone shows very fast charging/discharging behavior, a battery replacement may be needed [#17949863][#17950320]
  • #1 16913741
    Skazany1986
    Rate: 25
    Hello. In August, I bought an iPhone 7, it worked ok until the beginning of December, then suddenly began to eat something very quickly. From the full charge of the battery to the discharge of the phone goes only 8 - 9 hours doing nothing on the phone where previously using the phone held the battery for 2 days. I reported this fact to the phone seller and sent it back to the site. They kept the phone there for two weeks and sent it back and it is still the same they did nothing. Could any of you know what this might be for a problem that the battery eats so quickly? And can they replace the model after the service?
  • #2 16913850
    arekb81
    Help: 135
    Rate: 746
    You go into the settings, battery tab and there shows you what consumes the most energy.
    Or resetting (restoring factory settings), and then reinstalling everything. Under no circumstances restore from the iCloud archive, because you will also restore the error that causes the battery to "eat".
  • #3 16914081
    Skazany1986
    Rate: 25
    So, should I set up a new Ipple account?
  • #4 16914956
    matrix5
    Help: 8
    Rate: 37
    It is known that after the introduction of the latest iOS 11 began to occur with the rapid use of batteries. Now Apple also admitted to this quote:
    Tim Cook claims that this way it ensures smooth operation of iPhones. The problem is that with very resource-consuming tasks, the processor's power consumption increases momentarily to high values. Older batteries are not able to cope with such rapid increases in energy demand, which may result in the iPhone turning off faster.
    Along with the iOS 11.2 system, this solution also went to the iPhone 7. In the future it also has to hit newer devices.
    Apple concealed the whole process. Now officially admitted to it.
    What are your home versions of the software?
  • #5 16915118
    Skazany1986
    Rate: 25
    I have iOS 11.2.1 only after updating it worked ok with two days battery kept. Only recently has something happened that keeps you less. I read a bit and somebody wrote that the A2 layout could be damaged.
    Added after 41 [minutes]:
    U2 error
  • #6 16915464
    matrix5
    Help: 8
    Rate: 37
    You talk about the charging system, I put more on this soft, but if you have a phone for warranty, you can always advertise it.
  • #7 16915543
    Skazany1986
    Rate: 25
    Well just 4 days ago he returned from the complaint and the problem is still the same nothing they did not do.
  • #8 16915680
    matrix5
    Help: 8
    Rate: 37
    If he returned from the complaint, he probably eliminated the power problem, upload a clean soft lower than iOS 11 and see if the problem will continue to occur. Kuzyn He had the same problem after uploading the iOS11 version and had to go down to the lower version, take a copy earlier. The problem has disappeared but as I wrote, you will not avoid it in the newest versions what Apple itself has confirmed and already in the US is preparing a lawsuit against Apple users because the company slowed down operation of older versions of the iPhone due to fast battery consumption.
    Read about it on the internet is loud about it.
    It is possible that you have also uploaded a program that pulls your batteries - let's hope it is in good condition - because there were also examples of users in the US that after replacing the new phone Iphone 7 significantly improved its functioning.
    What is your current soft download after the complaint - should unfortunately be the latest? And whether the complaint was with the manufacturer or advertised in some ordinary service?
  • #9 16915695
    sanfran
    Help: 963
    Rate: 3004
    A friend knows that he is calling somewhere, but he does not know where.
    This is about lowering the clock speed in the case of a battery that has already passed.
    The author still did not look into the "BATERIA" menu and did not write what gets him the most energy.
  • #10 17949786
    dziki-dzik
    I will refresh the topic.
    The author, regardless of the result, should write how the matter ended / solved .. People who can not finish the topic are terribly annoying.
    Currently, I have the same problem, the problem occurred on how the phone spent several hours in the cold, then the battery from 30% fell to 1% and so lasted the next few hours until I got home and connected. Since then (2 days), the battery is discharging very quickly, and it is charging very quickly, with 1% it jumps to 60% within 20 minutes.
    After the indications of the "battery" application, one installed app has high consumption, I will check what will happen and let me know.
  • #11 17949863
    gathor10
    Help: 100
    Rate: 137
    dziki-dzik wrote:
    like a few hours in the cold
    A colleague will praise in what "cold". Are we talking about negative temperatures? In your case, it looks like a battery damage and no problem is solved. If the battery charges 60% in 20 minutes it is definitely for exchange.
  • #12 17949895
    dziki-dzik
    You're right, I'm sorry for not full information.
    The temperature at the level of 3 degrees, the time lying in such a temperature about 4 hours.
    The following activities have been carried out;
    - turning off the time in front of the screen
    - switching off - switching on the device
    - uninstalling the application installed upon arrival, which in; settings -> battery, indicated the highest consumption
    Currently, after these treatments the power drop is a bit smaller, but I will know only in a few hours if the problem has decreased.
    In fact, I have a battery at 80% of consumption
    I will only ask if there is a sudden need to replace the battery? Earlier, the phone worked without any problems.
  • #13 17950320
    gathor10
    Help: 100
    Rate: 137
    After leaving the phone in such a low temperature for such a long period it is possible. First, however, I would dismantle it and check if it was not damp (condensation). It may be that the water just condenses and there is more than just a battery to replace. If there are no traces (which does not mean that you can exclude "flooding"), replace the battery.
  • #14 17950330
    sanfran
    Help: 963
    Rate: 3004
    This is not extreme temperature. The temperature is even lower in the pocket of the jacket, the backpack or the winter bag. And how many times has my phone stayed overnight in the car and somehow the battery survived.
    A wild-boar colleague did not give the model, but the 7th is waterproof.
  • #15 17950336
    gathor10
    Help: 100
    Rate: 137
    sanfran wrote:
    7th is waterproof.
    What is waterproof for condensation?
    You were just lucky. The issue is still that, as he wrote @ wild-boar
  • #16 17950353
    dziki-dzik
    Yes gentlemen, this is the iPhone 7
    Initially, I will replace the battery as soon as the adhesive strips reach my battery, I will have an original 90% from a survivor from a friend (until the power dropped to 80% the equipment worked perfectly) and somehow I have more confidence in replacements. After the exchange I will check further.
    Immediately I ask for info on checking the moisture he mentioned @ gathor10 , after a damp paper, I can check it out somehow?
    And so I will ask, how to remove the "service" from the batteries after the exchange? A friend once mentioned in and; settings-> battery-> battery condition, appeared to him with information (despite the 95% status) "service"
  • #17 17950359
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    Apple exchanges batteries with a one-year warranty. I exchanged in my i7 and i +. ? 25 per item in the Apple salon. Time of waiting.
    Water tightness for condensation has a lot. If something is watertight, there is nothing to condense inside.
  • #18 17950390
    gathor10
    Help: 100
    Rate: 137
    It would go on to argue, but it would be necessary to write a very extensive report on this subject.
    dziki-dzik wrote:
    after the damp paper, I can check it out somehow?
    If you have a microscope, it's the easiest way to check if there's patches on components, etc. If it's not just "papers"
  • #19 17950482
    dziki-dzik
    ok, if it really will be a battery is not a big problem and in the end I will go to the website, in PL something like PLN 150 costs exchange,
    I do not have a microscope, and the paper under the tray shows white color
    edit.
    battery mentioned in 96% and so far the indication is correct, but the best thing is that despite the decrease to the theoretical 1% it actually had more and the power drop was normal. After charging, I used the phone until I jumped again 1% and after that I left the phone unused, I looked at him for a long time and so he watched two days and after putting the battery to another device it turned out that it was still 21% before the phone would turn off.
The discussion revolves around an iPhone 7 experiencing rapid battery drain, lasting only 8-9 hours on a full charge, compared to the previous two-day performance. Users suggest checking battery usage in settings, performing a factory reset, and avoiding restoring from iCloud to prevent reintroducing issues. The introduction of iOS 11 is noted as a potential cause for increased battery consumption, with users reporting similar problems post-update. Some users recommend downgrading the iOS version or replacing the battery, especially after exposure to cold temperatures, which may damage the battery. The conversation also touches on warranty options for battery replacement and the importance of checking for moisture damage.
TL;DR: Affected users report battery life dropping to 8–9 hours; one noted it "only 8–9 hours doing nothing." Start with Battery settings, clean reinstall (no iCloud restore), and consider battery replacement if health is low. [Elektroda, Skazany1986, post #16913741]
Why it matters: This FAQ helps iPhone 7 owners diagnose fast battery drain and decide when software resets or hardware service make sense.
How do I quickly see what’s draining my iPhone 7 battery?
Open Settings > Battery and check the per‑app usage list. Remove or restrict apps with high background activity. Then test for a day. If the issue vanishes, reinstall apps one by one. Avoid restoring a full iCloud backup during testing, as it can reintroduce the problem. “Go into the settings, battery tab and there shows you what consumes the most.” [Elektroda, arekb81, post #16913850]
Should I restore from iCloud when troubleshooting battery drain?
No. Perform a clean restore and set up as new. Then manually reinstall apps. This prevents bringing back a corrupted profile, buggy settings, or a misbehaving app that drains power. Users caution that restoring an iCloud archive can restore the very error causing drain. Test battery life for 24–48 hours before adding back heavy apps. [Elektroda, arekb81, post #16913850]
Did iOS 11 cause my iPhone 7 to feel slower or drain faster?
Users reported that iOS 11 introduced power management that reduces performance when batteries age, which can feel like worse battery life. One expert noted it’s about lowering the clock speed with a worn battery to prevent shutdowns. Update iOS, then check Battery Health and app usage. Replace the battery if health is low. [Elektroda, sanfran, post #16915695]
What does “U2/Tristar issue” mean on iPhone 7?
In this thread, “U2 error” was mentioned in the context of the charging system. It refers to hardware on the power/charging path. If charging is erratic after clean software steps and a known‑good battery, consult a repair shop for board‑level diagnostics. Prioritize software isolation first, then hardware checks. [Elektroda, matrix5, post #16915464]
My iPhone 7 suddenly drains fast after being left in the cold—what now?
Cold exposure can stress an aging cell. A telltale sign is unnatural charging like 1% to 60% in ~20 minutes. That points to capacity loss or damage. Warm the phone to room temperature, retest after a clean restore, then plan a battery replacement if behavior persists. “If the battery charges 60% in 20 minutes it is definitely for exchange.” [Elektroda, gathor10, post #17949863]
Is iPhone 7 waterproof enough to prevent condensation problems?
Water resistance does not guarantee immunity to internal condensation. Temperature swings can create moisture inside even sealed devices. If you suspect condensation, power down, let it dry at room temperature, and avoid heat sources. If symptoms continue, have a technician inspect for corrosion. [Elektroda, gathor10, post #17950336]
How can I check for moisture or corrosion without special tools?
Technicians look for corrosion “patches” on components under magnification. If you can’t inspect with a microscope, watch for recurring charging issues, random shutdowns, or rapid drain after temperature changes. These signs suggest professional evaluation. A shop can assess and quote for cleaning or board work. [Elektroda, gathor10, post #17950390]
When should I replace the iPhone 7 battery?
Replace it when Battery Health shows around 80% and you see fast discharge or erratic charging. One user reported 1% to 60% in ~20 minutes, which is abnormal and indicates a failing cell. Expect improved stability after replacement if software causes were ruled out. [Elektroda, gathor10, post #17949863]
What might service do if my phone returns unchanged?
If service returns the device with the issue intact, perform a clean install without iCloud restore and check Battery settings for top consumers. Document results and re‑submit with specifics. Ensure the repair ticket lists the battery test and any findings. [Elektroda, sanfran, post #16915695]
Will Apple replace my whole iPhone 7 model for battery drain?
Expect repair actions first, not a full model replacement. Community advice is to pursue warranty service for verified defects, starting with software diagnostics and battery testing. If hardware faults appear, they’ll address those under policy. [Elektroda, matrix5, post #16915464]
Why do I see “Service” in Battery Health after a swap?
Users observed a “Service” message even with high reported capacity after non‑stock battery changes. This warning can appear after certain replacements. If performance is fine, monitor it; otherwise, use an authorized part or seek service to clear hardware flags. [Elektroda, dziki-dzik, post #17950353]
How do I perform a clean reinstall to rule out software causes?
  1. Back up photos/files manually; sign out of iCloud.
  2. Erase all content and settings, then install iOS fresh via Settings or a computer.
  3. Set up as new; install apps one by one and avoid restoring an iCloud backup during testing. [Elektroda, arekb81, post #16913850]
Can downgrading iOS help with battery drain?
A user reported relief by rolling back below iOS 11 at the time. Today, focus on the latest supported iOS for security, then validate with a clean setup. If drain persists, check hardware. Policies may block downgrades now. [Elektroda, matrix5, post #16915680]
What if my phone still lasts only 8–9 hours after all steps?
Collect a one‑day Battery usage screenshot, note Battery Health, and list any abnormal charging stats. Submit these with your service request. Replacements resolved issues for several users once a faulty battery was confirmed. “You can always advertise it.” [Elektroda, matrix5, post #16915464]
