VW Passat B5 2000 1.8 Gas ADR Engine: Coolant Leak & Fluid Exchange Connector Replacement
ondrei 16401 10
How do I replace the leaking coolant stub pipe at the rear of a 2000 VW Passat B5 1.8 ADR engine, and what needs to be removed for access?
Remove the parts blocking access, mainly the air filter duct, then place a container under the car because coolant will spill out [#16915440] Move the metal clip from the lower hose, unplug the sensor connector, and detach the cable from the sensor [#16915440] Unscrew the mounting screws and pull the connector out [#16915440] Before fitting the new part, clean the mounting surfaces, for example with acetone, and replace the seals/O-rings if they are not included in the kit [#16915440]
  • #1 16914172
    ondrei
    Rate: 43
    Hello, I have vw passat 1.8 gasoline, gas from 2000r engine code ADR. I have been running out of coolant for some time. These are not significant losses. I saw that there was a leak at the rear of the engine, dripped on the gearbox. I guess it's a stub pipe. I have already purchased https://e-katalog.intercars.com.pl/#/produkty...P108_196-O5725-krociec-ukladu-chlarzenia.html such an item. And here the stairs begin. How to name it .... there is no film (or I can't find it). I think the exchange is not too complicated but I will not do it without an instructor. I do not know if I want to buy any other sensor-style part etc. I would need some block diagram showing the order of works (what to dismantle to have a better approach etc.) Please help
  • #2 16914656
    Pedros050
    Help: 2471
    Rate: 3926
    Hello. I suggest putting the car back to the mechanic in a few hours. If you have no knowledge in this topic, I advise you not to do the work. And he'll find out exactly where the leak is from.
  • #3 16914670
    ondrei
    Rate: 43
    Unfortunately, for some time now I doubt "barn" mechanics and I can't afford asao. I am still waiting for help ...
  • #4 16914680
    Pedros050
    Help: 2471
    Rate: 3926
    There is no trusted mechanic a colleague does everything himself with this Passat?
  • #5 16914705
    ondrei
    Rate: 43
    no tire replace in vulcanization ... inspections at the station and the agent's ... Will anyone help?
    I have just applied for this forum for knowledge ;)
  • #6 16914723
    Pedros050
    Help: 2471
    Rate: 3926
    And how did you check that it is definitely a stub pipe and not something else?
  • #7 16914733
    ondrei
    Rate: 43
    as I wrote, fluid leakage and this connection is wet
  • #8 16915241
    Alfred_92
    Help: 148
    Rate: 706
    Here almost all "barn specialists"
    But we know that you need a 10mm wrench
  • #9 16915377
    ondrei
    Rate: 43
    keep going
  • #10 16915396
    Alfred_92
    Help: 148
    Rate: 706
    I will give myself, and finding instructions on the internet replacing the metal piece takes less than 10 seconds.
    The internet doesn't stop at youtube.
    tomekmazepa
    Help: 16
    Rate: 117
    I apologize in advance for lack of Polish letters but I do not have English windows.
    In fact, there is nothing difficult about it:
    You unscrew the elements that will hinder access to the connector, i.e. the air filter duct, I write it from my head recently I replaced such a connector in 2.0, then you put something underneath the car to catch coolant as it will leak.
    You move the metal clip from the bottom hose, the plastic clip from the sensor, detach the cable from the sensor, unscrew the mounting screws and pull out the connector.
    Before mounting, you wash the mounting places (I use acetone), you get new ones for the rings, unless they are included in the set I mean a ring for the head and the sensor and you fold.
    Greetings Tomek
    Mobilny Serwis Samochodowy Tom-Car
    Brzostkow 22, Jarosław, 37-500
The discussion revolves around a coolant leak issue in a 2000 VW Passat 1.8 with an ADR engine code. The user suspects the leak originates from a stub pipe located at the rear of the engine, which drips onto the gearbox. They have purchased a replacement connector but seek guidance on the replacement process, including necessary tools and a block diagram for disassembly. Responses suggest consulting a mechanic for diagnosis, while others provide DIY instructions for replacing the connector, emphasizing the need to remove obstructive components like the air filter duct and to handle coolant leakage carefully. The process involves detaching clips, unscrewing mounting screws, and ensuring proper sealing with new rings.
