Passat b5 1.8 ADR 1996 Water Pump Replacement: Tips on AUX Wheel & Timing Gears
Exiss94 8622 3
  • #1 16922732
    Exiss94
    I started to replace the water pump in the Passat b5 1.8 ADR 1996. everything went my way until I noticed that the pump screws fall under the AUX wheel on the timing gear. As I have never taken my camshaft apart, I have a question:
    what is this wheel for and can I unscrew it safely after locking CA and CS?
    maybe there is a "trick" not to move the timing?
  • #2 16922774
    daro31ie
    Automation specialist
    Help: 366
    Rate: 650
    Unfortunately, there is no such trick.
    You must download.
  • #3 16922864
    Exiss94
    Okay, I understand that I only set the characters for CA and CS? AUX doesn't matter? Passat b5 1.8 ADR 1996 Water Pump Replacement: Tips on AUX Wheel & Timing Gears
    moto-kord
    Help: 137
    Rate: 505
    Exiss94 wrote:
    AUX doesn't matter?
    You don't have to set up exactly.
