Bosch SMV50D10EU / 09 Dishwasher - Water Not Heating, Drying, or Program Changing Issues
barbara1991 9252 5
  • #1 16915992
    barbara1991
    Hello. I have a problem with the Bosch SMV50D10EU / 09 dishwasher. It does not heat water, does not dry, and it cannot be changed to another program. The husband undressed her, checked the heater, unfortunately there is no transition on the perimeter, but he did not observe any "scorched" paths or contacts. Is it really a heater to replace? The cost of a new pump with a heater is PLN 600, in addition it is very difficult to access. Another question is whether it is impossible to remove this heater from the pump? It is set on some glue and the husband has not touched it yet. If it were possible, the husband could solder something, because he knows quite a lot about these things. Please help.
  • #2 16933621
    machnicki.krzysztof
    Help: 12
    Rate: 78
    If the husband knows about such things, he should not have a problem checking if the heater is working. You have to start from this. If it is functional and the dishwasher does not heat, it is worth looking into the control module within the relays from the heater. And if it turns out that the heater is damaged, it is easily available at a price of about PLN 350.
  • Used pump-heater from Allegro as cheap replacement
    #3 16933786
    zbych15
    Rate: 14
    I had a similar problem with Bosch dishwasher, the cost of repair was also finishing off. I bought a pump with a heater used on an allegro and instead of shipping 560 PLN it cost me about 50 PLN. There are a lot of service technicians on the Allegro selling parts from disassembly. Just ask a question at several auctions with pumps with a heater and specify the type of dishwasher. Certainly someone will speak. Especially that you can already disassemble and fold the dishwasher.
  • #4 16933826
    machnicki.krzysztof
    Help: 12
    Rate: 78
    My friend new and original pump on the allegro just costs about PLN 350 so it's worth considering whether to push the drug ...
  • #5 16949337
    psiocha
    Rate: 27
    I also had a problem with a heater in a Bosch dishwasher. After careful examination, I found that there was a scorched path next to the connector. I soldered and the dishwasher works like new. I attach photos from the heater.
    Bosch SMV50D10EU / 09 Dishwasher - Water Not Heating, Drying, or Program Changing IssuesIMG_201801...073205.jpg (3.38 MB)You must be logged in to download this attachment. Bosch SMV50D10EU / 09 Dishwasher - Water Not Heating, Drying, or Program Changing IssuesIMG_201801...083040.jpg (3.12 MB)You must be logged in to download this attachment.
  • #6 18080840
    qwazarpl
    Help: 37
    Rate: 270
    How did you manage to solder? He tries and tin doesn't want to stick to the path. I used soldering acid and lime.
