[Solved] radio 2 din 7163 gps - Chinese radio 2 din 7163 gps code for hidden menu
kuba56666 56880 17
What code opens the hidden menu on a Chinese 2-DIN 7163 GPS radio?
The hidden menu code on this radio is 000000, and multiple users confirmed that six zeros worked [#19333978] [#19223188]
  • #1 18640014
    kuba56666
    Rate: 15
    hello, I am looking for a code for the hidden menu on the 2 din 7163gps radio
  • #2 18640396
    gradek83
    Help: 930
    Rate: 2106
    kuba56666 wrote:
    7163gps
    Send a photo of this radio front and back and information sticker.
    Additionally, check:
    1111
    8888
    3368
    3618
    0000
    7890
    44320
    44328
    123456
    26959910
  • #3 18640399
    jurkuc
    Help: 146
    Rate: 315
    On some models of similar equipment, the access code is: 3368
    Please try and report.
  • #4 18640531
    kuba56666
    Rate: 15
    the code is 4 digits radio 2 din 7163 gps - Chinese radio 2 din 7163 gps code for hidden menu radio 2 din 7163 gps - Chinese radio 2 din 7163 gps code for hidden menu
    Added after 2 [hours] 41 [minutes]:
    none of the listed ones work
  • #5 18642520
    gradek83
    Help: 930
    Rate: 2106
    You wrote to the seller, maybe he knows this code.
    Are you sure it's a model 7163? Is there a sticker on the radio?
  • #6 18642733
    kuba56666
    Rate: 15
    just a description of the cube
  • #7 18642790
    gradek83
    Help: 930
    Rate: 2106
    Write to the seller or the Chinese, I don't know who you bought it from. Alternatively, look in the manual or on the CD, if there is one. Send a photo of where this pin calls out. Is it for advanced settings?
  • #9 18643081
    gradek83
    Help: 930
    Rate: 2106
    It is the EW6800 series or something like that and how many intermediate producers of the bush have it under their logo is difficult to determine. By default, the password should be 0000 or 000000
    But this type of information should be in the manual if the Chinese or the seller attached it.
    send a photo of the radio from the back and if there is a sticker on it with a call list, that's it too.
  • #10 18643367
    kuba56666
    Rate: 15
    This was the description from the seller
    CANVA 2 DIN MULTIMEDIA RADIO WITH POLISH MENU BASED ON MOSFET TECHNOLOGY WITH LARGE LCD DISPLAY, GPS NAVIGATION, REMOTE CONTROL, SD AND USB PORT, BLUETOOTH, RDS FUNCTION, REVERSING CAMERA OUTPUT AND EXTERNAL MONITORS radio 2 din 7163 gps - Chinese radio 2 din 7163 gps code for hidden menu radio 2 din 7163 gps - Chinese radio 2 din 7163 gps code for hidden menu
    the code is 0000 but it is for calls
  • #11 18643784
    gradek83
    Help: 930
    Rate: 2106
    What connections?
  • #12 18643892
    kuba56666
    Rate: 15
    bluetooth and the like
  • #13 18979742
    76slawek
    Rate: 77
    Hello everyone, does anyone know the code for this android 9.1 radio
  • #14 19219613
    stan000
    Help: 51
    Rate: 15
    Hello, I met the code 0126
  • #15 19223188
    76slawek
    Rate: 77
    Try 6 zeros for me it went.
  • #16 19333274
    Łysy321123
    Wipsz-8888
  • #17 19333660
    76slawek
    Rate: 77
    Hello, I consider the topic closed 6zero helped, thank you very much and greetings to all
  • #18 19333978
    damiancz
    Moderator of Car Radios
    Help: 475
    Rate: 1409
    Solved :arrow: closed, The code on this radio was: 000000
The discussion revolves around finding the access code for the hidden menu of a 2 DIN 7163 GPS radio. Various users suggest potential codes, including 1111, 8888, 3368, 3618, 0000, 7890, 44320, 44328, 123456, 26959910, 5802, and 000000. Some users report that none of the suggested codes worked, prompting recommendations to contact the seller or check the manual for the correct code. The radio is described as a CANVA 2 DIN multimedia device with features like GPS navigation, Bluetooth, and a large LCD display. Users also share images of the radio for identification purposes.
TL;DR: For these Chinese 2‑DIN/7163‑type radios, 1 confirmed working code is documented; "The code on this radio was: 000000". Try six zeros first, else 4‑digit options like 3368 or 8888. [Elektroda, damiancz, post #19333978]
Why it matters: This FAQ helps owners quickly unlock factory/hidden settings without guesswork or risky resets, especially on budget 2‑DIN/7163 units.
Which code solved the hidden/factory menu in this thread?
Six zeros. The moderator closed the case with: “The code on this radio was: 000000.” Start with 000000 on similar Android 9.1 units. If that fails, proceed to common 4‑digit options. “Try six zeros first” is the practical takeaway. [Elektroda, damiancz, post #19333978]
What 4‑digit code has worked on similar equipment?
Try 3368. A contributor noted, “On some models of similar equipment, the access code is: 3368.” Enter it in the Factory/Advanced settings prompt if your unit requests four digits. If it doesn’t accept 3368, continue with other defaults like 8888 or 1111. “Start simple, then expand the list.” [Elektroda, jurkuc, post #18640399]
What are the most common default codes to try on 2‑DIN/7163‑type radios?
Users commonly test these in order: 1111, 8888, 3368, 3618, 0000, 7890, 44320, 44328, 123456, 26959910. Enter only what the prompt length allows. If the unit expects four digits, stick to the four‑digit options first. Record what you tried and the response. This reduces repeat attempts later. [Elektroda, gradek83, post #18640396]
Is there a GA7163-specific access code mentioned?
Yes. A user researching the GA7163 manual suggested, “Please also try the code: 5802.” They noted the GA7163 by GEONON appears related. If your label references GA7163, try 5802 after common defaults, and consult the manual linked in that post. [Elektroda, jurkuc, post #18643014]
Is 0000 the hidden menu code or only for Bluetooth pairing?
On these units, 0000 is often just the Bluetooth pairing/calls PIN. It typically doesn’t unlock the factory menu. If you see the prompt while pairing a phone, that is the pairing code field. For factory settings, try 000000 or 3368 instead. [Elektroda, kuba56666, post #18643367]
My unit only accepts four digits—what should I do?
Stay within four‑digit options. Start with 3368, 8888, 1111, 3618, and 0000. Some variants reject longer codes entirely. One owner confirmed the prompt was four digits and none of the early lists worked. If 4‑digit options fail, verify the exact model and firmware. [Elektroda, kuba56666, post #18640531]
Where else can I find the correct code if none of these work?
Contact the seller or manufacturer support and check the included manual or CD. Provide photos of the radio’s front, rear, and any stickers to confirm the exact variant. Sellers often know their batch defaults. “Write to the seller… look in the manual or on the CD.” [Elektroda, gradek83, post #18642790]
How do I try codes safely without messing up settings?
How‑To:
  1. Open the Factory/Advanced settings prompt on the unit.
  2. Try defaults in this order: 000000, 3368, 8888, 1111, 3618, then longer ones if allowed.
  3. If rejected, exit without saving changes, note results, and verify your model. This systematic approach mirrors community testing advice. [Elektroda, gradek83, post #18640396]
What family might the 7163 resemble, and do defaults overlap?
One reply linked these to an EW6800‑type series used by multiple brands. In those, defaults often include 0000 or 000000. That overlap explains why six zeros or simple four‑digit pins frequently unlock factory menus across re‑branded units. [Elektroda, gradek83, post #18643081]
Did six zeros work for others here besides the moderator’s note?
Yes. Another participant confirmed, “6 zero helped,” and considered their issue closed. If your radio is Android‑based or similar to that example, prioritize 000000. If you still get a denial, proceed with 4‑digit fallbacks. [Elektroda, 76slawek, post #19333660]
Someone wrote “Wipsz-8888.” What does that mean in practice?
It means “type 8888.” Some firmware accepts 8888 for the factory menu. If your prompt allows four digits, enter 8888 and confirm. If that fails, continue with the rest of the common default list before contacting the seller. [Elektroda, Łysy321123, post #19333274]
How many candidate codes were proposed in one key reply?
Ten candidate codes appeared in a single list. That breadth reflects how many firmware branches exist across 2‑DIN Chinese radios. Start with the simplest values and match the field length. Document attempts so you don’t repeat codes. [Elektroda, gradek83, post #18640396]
Is my “hidden menu” prompt actually the Bluetooth PIN screen?
If the prompt appears during phone pairing, it’s the Bluetooth PIN. One owner clarified their “0000” was for calls/Bluetooth, not factory settings. Enter 0000 only in pairing contexts. For factory settings, use 000000 or other admin codes. [Elektroda, kuba56666, post #18643892]
What details should I share to get faster help identifying the right code?
Post clear photos of the front, back, and any information sticker. Helpers asked for these to confirm the exact variant and suggest correct codes. Also include your current prompt length and any manual model references. [Elektroda, gradek83, post #18640396]
