Drone Camera Connection Issue: No Smartphone Connection, Wrong WiFi AP Message - Seeking Help
Xserodarek 40410 10
How do I connect my smartphone to a toy drone camera when the app keeps showing “connect to wrong wifi ap”?
You should not connect the app to your home Wi‑Fi; first connect the phone directly to the drone’s own Wi‑Fi network, then open the app and search for the drone camera there [#16920943][#16921083] The phone can see and connect to the drone’s Wi‑Fi, but if the app still reports “connect to wrong wifi ap” or keeps trying forever, the app/phone is not completing the camera connection [#16921131][#16921142] Try another phone to check whether the problem is with your device [#16921339] If it still fails on a different phone, the drone camera may be damaged [#16921339][#16923165]
  • #1 16920889
    Xserodarek
    Rate: 27
    Hello!!!
    I bought a drone with a camera for my child, unfortunately I can not configure it. Invariably in the application, the network is being connected or a message appears (connect to wrong wifi ap) Please help because nothing could be found on the net or it was written in this way that I did not understand anything. Mark, I wanted to be a total layman when it comes to this kind of thing.
  • #2 16920907
    leonov
    Help: 1039
    Rate: 2246
    And what is this drone? model? no instructions to him?
  • #3 16920928
    Xserodarek
    Rate: 27
    http://allegro.pl/wielki-dron-z-kamera-na-sma...mViMDdjZDc2OTE4ZjdlMjcxZDlkZWQ4ZTc2NDU3YzI%3D
    It is a toy which does not change the fact that we can not make full use of it.
    In the instructions it was only about the first launch of the drone, and only to download the app to connect to the wifi and already. Unfortunately, it does not work as they wrote.
  • #4 16920943
    leonov
    Help: 1039
    Rate: 2246
    The application does not connect to the wifi network, only through the application you search the camera of the drone and connect to it.
  • #5 16920962
    Xserodarek
    Rate: 27
    Could you write to me what it should look like I used a few apps, among others gx-ufo
    Added after 4 [minutes]:
    Where in this app is searching for a webcam, excuse me but I do not see it. (I mark again I am a total layman)
    I turned on the home drone in my wifi I saw it connected me but at the same time I logged out the phone from the wifi and there was still a mistake of crossing
  • #6 16921083
    leonov
    Help: 1039
    Rate: 2246
    Xserodarek wrote:
    but at the same time I logged out the phone from the wifi and there was still a connection error
    It's normal that if the tel has not connected to the wifi, the connection with the drone will not be, because from what you write it is supposed to work ... how strange to me it turns out that you can only use it within the range of wifi. ?
    And in the wifi networks on the phone you can see dorna? can you connect with him?
    In my opinion it should look like this ...
  • #7 16921131
    Xserodarek
    Rate: 27
    You can connect with the drone, but when you try to start the app, the message connect to wrong wifi ap pops up
  • #8 16921135
    leonov
    Help: 1039
    Rate: 2246
    Is such a message on all applications?
  • #9 16921142
    Xserodarek
    Rate: 27
    On others, there is the attempt to connect all the time without a message but also without a result
  • #10 16921339
    leonov
    Help: 1039
    Rate: 2246
    Check again on another phone, if it does not help, maybe something is damaged?
  • #11 16923165
    Xserodarek
    Rate: 27
    Under another phone I can not connect the drone camera to my smartphone
✨ A user is experiencing difficulties connecting a drone camera to a smartphone, receiving a "connect to wrong wifi ap" message. The drone is described as a toy, with minimal instructions provided, primarily focusing on initial setup and app download. Users suggest that the connection should be established through the app by searching for the drone's camera. Despite attempts to connect via different applications, the user reports persistent issues, including disconnection from WiFi and inability to connect on another phone. Suggestions include checking the connection process and considering potential hardware issues.
