Wi-Fi Drone Connection Issue: DRON WIFI CAMERA 3D VR LED W6 Z186 GLASSES - Android Troubleshooting
Skandor 16041 9
How can I connect my Android phone to a drone’s Wi‑Fi when the network appears without internet access and the drone app won’t work?
When Android shows that the drone Wi‑Fi has no internet, that is normal; dismiss the warning and open the drone app, because you do not need internet from the drone’s network [#18959819][#18998766] Make sure Wi‑Fi is enabled on the phone and there are no Wi‑Fi locks or restrictions blocking the connection [#16900373] If the drone still does not show up in the app on Android 8–9, turn off data transmission/mobile data, and note that some drones may have 5G-related compatibility issues [#19111538]
  • #1 16898930
    Skandor
    Rate: 12
    Hello, I bought a drone son some time ago. Normal cheap Chinese for 230 PLN (DRON WIFI CAMERA 3D VR LED W6 Z186 GLASSES). I have a problem connecting the drone to the Wi-Fi network on my phone. I am looking for a network, but there is no connection so I can't use the application on Android, so we can't take pictures. I am happy to read your advice on what I can do next. Regards
  • #2 16900373
    Madrik
    Help: 627
    Rate: 1189
    The first thing to check is whether there are any locks on your phone on the WiFi network and whether it is turned on.
  • #3 17194767
    Skandor
    Rate: 12
    I would like to come back to the subject after a long time. I have Wi-Fi turned on and it is possible to connect, but it still says in brackets "no internet connection" I tried to connect from another phone but the same problem occurs. Maybe you need to configure this network somehow?
    • Wi-Fi Drone Connection Issue: DRON WIFI CAMERA 3D VR LED W6 Z186 GLASSES - Android Troubleshooting 31571018_1700755219992626_1705875121_o.png (133.65 KB) You must be logged in to download this attachment.
  • #4 18959819
    pimat13
    Hello. But you probably don't want to use the internet only from a drone. Confirm 'no' and go to the drone application. It should be OK.
  • #5 18998766
    pimat13
    Of course, in choosing YES and the drone will remain in the network without internet.
  • #6 19047770
    Dydygryf
    Hi. I just bought a CSJ s 166 drone and the same problem. I have the view from the webcam on my phone, the drone synchro is successful, but the drone cannot be started and the same problem with WiFi. Do you already know something about the topic?
  • #7 19067468
    Tomi51
    Help: 6
    Rate: 11
    Na kontrolerze lewym drazkiem do gory i do dolu i powinien sie polaczyc kontroler z dronem.
  • #8 19111538
    stadeks
    In the 4DRC 4D-F3 drone, in the absence of visibility in the application, turn off data transmission in Android 8-9. This is covered in the help file
    installed program. Some drones support 5G and this may also be the reason.
  • No internet access prevents map and satellite features
    #9 19761431
    Goryl m 109
    Rate: 14
    Hello. In my 4DRC pro Mark 300 the situation is as follows. There is a connection between the phone and the drone, the view from the camera in the application, the ability to control the camera up and down. After unlocking, the drone starts the motors. The problem is the lack of WiFi access to the Internet, i.e. no possibility of connecting to satellites, Google Maps in the drone application do not work. I am asking for help and info if anyone has encountered such a problem.
  • #10 20260321
    krystianstasiak061
    Hello, have you solved the problem? Because it's the same for me and I don't know what to do
    Hello, have you solved the problem? I have the same problem and I don't know what to do.
✨ The discussion revolves around connectivity issues with the DRON WIFI CAMERA 3D VR LED W6 Z186 GLASSES drone, specifically regarding its Wi-Fi connection to Android devices. The user initially struggles to connect the drone to their phone's Wi-Fi network, which prevents the use of the associated application for taking pictures. Subsequent responses suggest checking Wi-Fi settings, confirming that the drone does not require internet access for its app, and ensuring proper configuration. Other users report similar issues with different drone models, indicating a common problem with Wi-Fi connectivity and app functionality. Solutions include disabling mobile data on the phone and ensuring the drone is properly synchronized with the controller.
