Connecting Xenic Smart Media Box DVB-T2 DVB-2241 to Panasonic TH-37PA30 TV via HDMI-VGA
Crenen 8853 9
How can I connect an HDMI-only media box to a Panasonic TV that only has VGA and also get sound?
You need an active HDMI-to-VGA converter/adapter; a passive HDMI-to-VGA cable will not work, and there is no other option mentioned in the thread [#16300099][#16300181] VGA carries only the picture, so for sound you need a converter with a 3.5 mm audio output or another separate audio output [#16299898][#16300168] If the TV has no PC audio IN, you can feed the sound into another input such as AV3, because the TV already works that way with the laptop setup described in the thread [#16300059] The replies do not offer a cheaper way to connect this HDMI-only box to VGA with sound [#16300099]
  • Seeking HDMI-to-VGA audio solution under PLN 200
    #1 16299863
    Crenen
    Hello, I am the owner of this Panasonic TH-37PA30 TV. I would like to buy a 2in1 device (Smart TV + DVB-T) called Xenic Smart Media Box DVB-T2 DVB-2241. The problem is that this device can be connected to the TV only via HDMI, which my older TV does not have, but it has, among others, D-Sub (VGA). Unfortunately, from what I orientate, the cable from HDMI to VGA actually exists, but it will not work because it is supposedly a sell. It is only when this cable has a converter that converts digital signal to analog signal that the image will appear. Unfortunately, just the picture, and I care about the picture + sound which is probably not strange :P The price is also not small, and if it is possible due to the fact that I have recently moved, I need a cheap way. Namely, my questions are:
    1. Does the device pay off in general and does it work as it should, i.e. Smart TV (I only want IPLE, that I have a computer in the gaming pages, so its parameters are enough for that?) And of course terrestrial television? And its price is 169 PLN, as in the jbc promotion. :P
    2. If this device, how do you recommend it to me, which cables should I use?
    3. If this purchase does not pay, is there any alternative in similar money. I remind you recently moved in and I do not want to spend a lot of money today, moreover, it probably would not pay off because you could buy a TV with these functions about PLN 800 a consumption.
    4. The price at which I would like to close with all this is PLN 200 if it is possible.
    Unfortunately, it turned out that I cannot insert links because I am new; / So I will give where to find the devices. By entering Xenic Smart Media Box DVB-T2 DVB-2241 in a home electronics store Euro DVB-2241 pops up jbc. the one for 169 PLN.
    Unfortunately, the TV set in Panasonic TH-37PA30 google has the specification on telekom.com.pl
    And now something else I'm watching movies from the net through a connected laptop. It is connected via a D-Sub cable taken from an old monitor, and the sound through a double cinche, and to the bench jack plug 3.5 - 2 x cinch socket. Can anything be used for this?
    Many thanks in advance :)
  • #2 16299898
    sosarek
    Help: 9320
    Rate: 15542
    Crenen wrote:
    the converter converting the digital signal to analog is the image will appear. Unfortunately, just the picture, and I care about the picture + sound
    There are such, provided that the TV has a PC audio IN input.
    Z
    Pka, Poznań, 60-850
  • #3 16300045
    Crenen
    From what I see, I do not have, but I took pictures of what I have. And I do not know why, but the TV does not play sound only the image as it is connected to the front via D-Sub (signed PC) and a double jack on the front panel of the TV with a laptop.
    Connecting Xenic Smart Media Box DVB-T2 DVB-2241 to Panasonic TH-37PA30 TV via HDMI-VGA Connecting Xenic Smart Media Box DVB-T2 DVB-2241 to Panasonic TH-37PA30 TV via HDMI-VGA
  • #4 16300059
    sosarek
    Help: 9320
    Rate: 15542
    If this is how it works with the converter, it will work, too, do you have sound from your laptop connected to AV3?
    Z
    Pka, Poznań, 60-850
  • #5 16300084
    Crenen
    Yes, exactly AV3. Only what cable to use for this because this decoder (Smart TV) has only from what I see the HDMI output, and this converter costs 60 PLN; / Is there any other option to connect this device?
  • #6 16300099
    sosarek
    Help: 9320
    Rate: 15542
    Crenen wrote:
    a converter from PLN 60 costs; /
    Unfortunately, but it works.
    No.
    What resolution are you able to get on the TV screen when connecting a laptop?
    Z
    Pka, Poznań, 60-850
  • Questioning HDMI-to-VGA converters with audio output
    #7 16300151
    Crenen
    And what about the sound because, for example, on apricots I found such a converter Cable Elmak DisplayPort - D-Sub 0.15m Black (SAVIO CL-90) for PLN 30 but I do not see any connection to the sound. Is there a converter from HDMI to D-Sub + Jack or cinch? Because I understand that we are talking about such a converter :P ?
    I can't tell you exactly now because I just disconnected the laptop from the TV and I'm writing with it now, but more than Full HD 1920x1080 which is surprising because it's an old TV :P the first unit was certainly over 2000.
    sosarek
    Help: 9320
    Rate: 15542
    At Alle ... you have a lot of these converters, they have, apart from the VGA output, an audio output Jack.
    Z
    Pka, Poznań, 60-850
  • #9 16300175
    Crenen
    Sorry, the error crept, I meant Gembird HDMI Cable - D-Sub 0.15m Black (A-HDMI-VGA-04) for PLN 33.
    sosarek
    Help: 9320
    Rate: 15542
    Write on Alle ... HDMI - VGA adapter and that's it.
    Z
    Pka, Poznań, 60-850
The discussion revolves around connecting a Xenic Smart Media Box DVB-T2 DVB-2241 to a Panasonic TH-37PA30 TV, which lacks an HDMI port but has a VGA (D-Sub) input. The user seeks a cost-effective solution to achieve both video and audio output. It is noted that while HDMI to VGA cables exist, they typically do not carry audio unless paired with a specific converter. Suggestions include using an HDMI to VGA adapter with an audio output, and various models of such converters are mentioned. The user expresses concerns about the cost and functionality of the Smart TV device, particularly regarding its performance and compatibility with existing equipment.
