Compatibility of Intel Core i5 4460 (Socket 1150) with 1151 Motherboard
Stasiek102 10362 3
  • #1 16926910
    Stasiek102
    Hello, I have a question, I'm green when it comes to pc assembly and I currently have Intel Core i5 4460 @ 3.20GHz and NVIDIA GeForce GTX 750 Ti
    and I have a question because the i5 has a socket 1150 and the new board I intend to buy is 1151 and will it fit or not?
    Thank you
  • #2 16926919
    bolekis
    Help: 200
    Rate: 264
    It won't work, don't even try because you will damage something. You must buy a disc with the LGA1150 socket.
  • #3 16926938
    kokapetyl
    Help: 1787
    Rate: 2105
    Behind Wilkipedia
    LGA 1151? Intel processor socket for Skylake series processors and Kaby Lake from January 4, 2017. LGA 1151 is not backwards compatible with LGA 1150 despite the fact that the difference in pins between these two sockets is only one pin.
  • #4 16927806
    MiernikZKauflanda
    Help: 29
    Rate: 60
    I would get rid of this i5 and buy a + CPU board for 1151, it makes no sense to go to 1150 in my opinion.
