Kubota D1402 Engine: Valve Clearance Size & Bolt Tightening Torques - Assistance Needed
DominikSliwinski 20100 2
  • #1 16936216
    DominikSliwinski
    Rate: 8
    I just picked up the Kubota d1402 engine from the cylinder cut. I would need the valve clearance size and bolt tightening torques.
    Would someone with a problem help?
    elektryk112
    Help: 176
    Rate: 239
    Inlet and exhaust valve clearances 0.145 to 0.185 mm, and the moments and sequence in the pdf supplement:
    • 2 Series Torque Specs.pdf (337.28 KB) You must be logged in to download this attachment.
  • #3 16937199
    DominikSliwinski
    Rate: 8
    Thank you very much for your help.
    best regards
