NVIDIA GeForce GT 430 Replacement: Best Graphics Card for 3 Monitors, Radeon HD 5830 Alternative
jerzy 10 8961 11
Which graphics card should I buy to replace a GT 430 so I can run three monitors independently at the same time?
A card that explicitly supports three active displays will solve this; for AMD, the forum says all Radeon HD5xxx cards support 3 monitors, and for NVIDIA the cheaper options mentioned were GTX 650, 660, 750 and the Ti variants, which should support at least 3 monitors [#16932698] [#16932693] A later confirmation says the Zotac GeForce GT 710 2GB DDR3 works 100% with three monitors simultaneously using DVI, HDMI and D-SUB, without adapters [#19171232] [#19513511] For AMD cards, the advice was to check for Eyefinity support, because multi-monitor support can depend on the exact model/version [#16932693]
  • Need a card with three independent displays
    #1 16932597
    jerzy 10
    Rate: 93
    I have a PC with an NVIDIA GeForce GT 430 graphics card, I need to replace it with a card that will support three monitors so that you can open pages independently on three screens. The current one, even though it has three outputs, but you can only independently display pages on two monitors.
    I was thinking about the Radeon HD 5830 card but you can't get it anywhere, I don't know if it will fit.
  • GTX 650/660/750 and Eyefinity support for 3 monitors
    #2 16932693
    sylweksylwina
    Help: 1882
    Rate: 2355
    As for nvidia, you can look at: https://www.geforce.com/hardware/desktop-gpus
    When you click on any graphics card and enter the specifications, you will have multi monitor written: X dispalys - where x is the maximum number of monitors. Unfortunately, the GPU 1000 series does not have such detailed information. From the cheaper cards you can choose GTX650, 660, 750 and Ti counterparts. All these models should support at least 3 monitors. Although it also probably depends on the specific version.
    AMD also has some cards with support for 3 and more monitors, but here it depends more on the specific card, somewhere I read that you need to look for cards with eyefinity support.
  • #3 16932698
    Kasek21
    Help: 4981
    Rate: 3547
    All Radeons from the HD5xxx series support 3 monitors.
    jerzy 10 wrote:
    I don't really know if it will fit.
    Fits what? It makes no sense to just display pages.
    What output do you need?
    What budget
  • #4 16932805
    jerzy 10
    Rate: 93
    Card price up to PLN 500, neutral outputs, I have new monitors
  • #5 16932817
    Kasek21
    Help: 4981
    Rate: 3547
    Like the rest of the computer configuration?
  • #6 16932903
    jerzy 10
    Rate: 93
    Please confirm or deny that the Radeon RX 560D Card will be the right card in terms of connector and support for these three monitors.
  • #7 19171232
    jamesdio
    Rate: 12
    I know that the thread is old, but I leave the info for posterity: Zotac GeForce GT 710 2GB DDR3 supports three monitors simultaneously (DVI, HDMI and D-SUB) connected with dedicated cables (without adapters). Works on Windows and Linux (tested on Mint 19 and 20). Apparently, most GeForce 710 GTs support 3 monitors simultaneously ...
  • Questioning GT 710 and HD 5450 triple-monitor support
    #8 19513440
    ygrecki
    Good morning
    jamesdio: Zotac GeForce GT 710 2GB DDR3 - have you tested it on three monitors? Quite a few graphics have three outputs, but only two of them can be active at any one time, and that's the catch with the cards. I am looking for something simple on a 3xLCD and this GT 710 would be perfect but does it work 100% with three monitors in parallel?
    I also wonder if ASUS ATI RADEON HD 5450 1GB EAH5450 SILENT can handle 3 monitors in parallel.
  • Three-monitor support confirmed on Linux
    #9 19513511
    jamesdio
    Rate: 12
    I confirm - every day I work on three monitors at the same time, this card works 100% with three monitors simultaneously. In fact, many cards have 3 outputs, and for example, only 2 work, but in this case, 3 work. I will say about it that the d..py graphics do not stop, but my job is mainly programming topics related to managing servers, websites etc so it's perfect. The only thing I noticed is that monitors with the same image settings display this image differently. For example, when I move the window to two monitors, the black color differs on these monitors, but it may have to do with cables, drivers (I'm using Linux at the moment). Still, it is not something that disturbs my work. These are subtle differences.
  • #10 19513527
    ygrecki
    And it needs 3xLCD for exactly the same. I have the same with colors. Currently, it works on two identical monitors, even the serial numbers have consecutive ones and on one it is white, on the other a bit bluish, and the settings are identical. OK then I'm buying a GeForce GT 710 2GB DDR3. I wonder if the 1GB versions also work in parallel on 3xLCD? Thanks for the info.
  • #12 19513547
    ygrecki
    I look at it too, it's a pity there is no 2xDVI. But for the price it's ok. Thanks again,
The discussion revolves around replacing an NVIDIA GeForce GT 430 graphics card with a model that supports three independent monitors. Users suggest various alternatives, including NVIDIA GTX 650, 660, 750, and AMD Radeon HD 5xxx series, all of which are capable of supporting multiple displays. The Radeon RX 560D is also mentioned as a potential option. The Zotac GeForce GT 710 2GB DDR3 is highlighted for its ability to run three monitors simultaneously without issues, with users confirming its performance in multi-monitor setups. Concerns about color discrepancies across monitors are noted, but they do not significantly impact usability. The discussion emphasizes the importance of checking specific card capabilities and outputs for multi-monitor support.
TL;DR: Need a simple 3‑monitor GPU? A user-confirmed Zotac GeForce GT 710 runs 3 displays; “I confirm—every day I work on three monitors.” [Elektroda, jamesdio, post #19513511] Why it matters: This FAQ helps you replace a GeForce GT 430 and reliably drive three independent screens for work or browsing.
What’s the simplest proven replacement for a GeForce GT 430 to drive three monitors?
Zotac GeForce GT 710 2GB DDR3. A forum user confirmed daily use with three simultaneous monitors. It works on Windows and Linux. Use the DVI, HDMI, and D‑Sub ports with direct cables. No adapters are required for this setup. [Elektroda, jamesdio, post #19171232]
Do all GPUs with three video ports run three independent displays?
No. Several cards expose three outputs but only allow two active displays at once. Verify “3 displays” or “Eyefinity” (AMD) in specs before buying. This limitation was highlighted by users troubleshooting triple‑monitor setups in the thread. [Elektroda, ygrecki, post #19513440]
Will a Radeon RX 560D support three monitors?
Check the exact vendor model. Confirm in the official specs that “multi‑monitor: 3 displays” (or AMD Eyefinity) is listed. Users note Nvidia and AMD vary by board version, so confirm before purchase. [Elektroda, sylweksylwina, post #16932693]
Do the Nvidia GTX 650/660/750 families support three monitors?
Yes, user guidance points to these as budget options that support at least three monitors. Capability can depend on the specific board variant. Check the model’s specification page for maximum displays. [Elektroda, sylweksylwina, post #16932693]
Can the Zotac GT 710 really run 3 monitors at the same time?
Yes. One user reports working daily with three monitors simultaneously on the GT 710. Quote: “I confirm—every day I work on three monitors.” This covers typical office and programming tasks. [Elektroda, jamesdio, post #19513511]
Which ports worked for triple‑monitor on the GT 710?
DVI, HDMI, and D‑Sub worked together using dedicated cables, without adapters. The same user confirmed success under Windows and Linux (Mint 19/20). [Elektroda, jamesdio, post #19171232]
Does a GT 710 with 1GB VRAM also support 3 monitors?
Unconfirmed in the thread. A user suggests functionality depends more on the specific card model than memory size. Verify the vendor’s spec sheet for “3 displays” support. [Elektroda, jamesdio, post #19513535]
What is AMD Eyefinity?
Eyefinity is AMD’s multi‑monitor technology label. Cards marked with Eyefinity are the ones to target for 3‑plus display support. Users recommend hunting for Eyefinity when choosing AMD GPUs. [Elektroda, sylweksylwina, post #16932693]
How do I verify a GPU will drive three independent screens?
  1. Open the card’s spec page and find “Multi‑monitor” or “Maximum displays.”
  2. Confirm it lists 3 displays (or AMD Eyefinity support).
  3. After install, enable all three screens in your OS display settings. [Elektroda, sylweksylwina, post #16932693]
Is the Radeon HD 5830 a good pick today for triple‑monitor?
It supports three monitors as part of the HD 5xxx family. The thread notes it’s hard to source now. If you can’t find it, consider other HD 5xxx cards or the GT 710 option. [Elektroda, Kasek21, post #16932698]
Will a Radeon HD 5450 1GB run 3 monitors in parallel?
A user asked this, and guidance indicates HD 5xxx cards support 3 monitors. Check for Eyefinity on the exact 5450 model you buy. Port mix may affect which trio works. [Elektroda, Kasek21, post #16932698]
What budget did the original poster set for a 3‑monitor card?
Up to PLN 500 for the graphics card. Use this as a reference point when comparing used or entry‑level new options. [Elektroda, jerzy 10, post #16932805]
Any pitfalls when mixing three monitors?
Yes. One user saw subtle color differences between displays with identical settings. Expect slight variations in black level or white point across screens. Calibrate if precise color matters. [Elektroda, jamesdio, post #19513511]
Does Linux work well with a triple‑monitor GT 710?
Yes. The GT 710 setup was confirmed on Linux Mint 19 and 20, as well as Windows. Use native drivers where possible. [Elektroda, jamesdio, post #19171232]
I only browse and code—do I need a powerful GPU for 3 monitors?
No. Users report the GT 710 handles everyday programming and web tasks fine across three screens. This keeps costs low while meeting workflow needs. [Elektroda, jamesdio, post #19513511]
Why did my GT 430 fail to run 3 independent displays?
A user found it only managed two independent screens despite three physical outputs. This is a known limitation for some older cards. [Elektroda, jerzy 10, post #16932597]
