Peugeot 407 SW 2007 2.0 HDI: Rear Left Turn Signal Not Working, BSI Error B4BD & Pin Info
Aleksander_01 23157 18
Which BSI wire or pin feeds the rear left turn signal on a 2007 Peugeot 407 SW, and what should I check for a B4BD short-to-left-rear-indicator fault?
The rear left indicator signal is on the A17 287C wire at the black 3-pin plug, so you should trace that line at the rear lamp rather than only looking for a BSI pinout [#16936339][#16936886] A good first test is to swap the left and right indicator circuits at the lamp to see whether the fault follows the lamp or stays with the car wiring [#16934242] The thread also points to a possible lamp-board/driver or socket-ground problem, since the signal was intermittent after battery disconnect and the lamp-side fault was eventually found there [#16936886][#16934396]
  • #1 16934200
    Aleksander_01
    Help: 1155
    Rate: 3372
    Peugeot 407 SW, 2.0 HDI, 2007.
    Problem - no left rear indicator.
    After unplugging the battery there are moments that the direction is, but rarely and quite briefly.
    BSI error B4BD (short to rear left turn signal) appears.
    Does anyone have knowledge of which BSI pin signal goes to the left back.
  • #2 16934242
  • #3 16934276
    Aleksander_01
    Help: 1155
    Rate: 3372
    The lamp was burnt out, but it's done (with warranty until the end of this car). If I continue to blow it in ... I will solder the light bulb directly to the cables.
  • #4 16934296
  • #5 16934332
    Aleksander_01
    Help: 1155
    Rate: 3372
    But I take, I take the clamp for about a minute and sometimes everything is OK, the longest it walked over half an hour. After all, in BSI there may also be a short circuit or a damaged driver from this bulb. Is there any connection block between BSI and rear lamp (something similar as in reno).
  • #6 16934347
  • #7 16934384
    Aleksander_01
    Help: 1155
    Rate: 3372
    I also replaced Narva bulb, the lamp was in perfect condition (the fire was a bit lit, but it was already repaired).
    At BSI you still have outputs that are blocked by ground condensers, can stick such a cusik.
  • #8 16934389
    andrzej20001
    Help: 1574
    Rate: 6639
    Did you give weight from the wire to the lamp board by soldering directly?
  • #9 16934396
    Aleksander_01
    Help: 1155
    Rate: 3372
    Exactly, I always do that when the burnt mass in the socket.
    Gentlemen, I have something lucky these peugots lately, but so far it has always helped download the clamp, even a few days ago one customer over the phone suggested what to do, in a moment he called and thanked.
  • #10 16934628
    andrzej20001
    Help: 1574
    Rate: 6639
    Hook is Maybe a module?
  • #11 16934734
  • #12 16934764
    Aleksander_01
    Help: 1155
    Rate: 3372
    The hook is gone. Gentlemen, I asked for which BSI pin is responsible for this bulb. It is known that I will find this cable, it is a waste of time and here you have to look for the number on the cable (and the eyes are no longer those). Once I find this cable at BSI, it is known to cut and solder the bulb to it and ground, and then observe. Well, the tenth is coming time to go to work.
    Daro122
    Help: 165
    Rate: 747
    The rear left direction is on the A17 287C cable.
  • #14 16936886
    Aleksander_01
    Help: 1155
    Rate: 3372
    I located on the black 3-pin plug. Unfortunately, but as I thought, the driver (half) is released from this bulb. I will buy and substitute tomorrow.
    Thanks Daro122 - next time I am asking for a faster response :D :D :D
  • #15 17214321
    krych14
    Rate: 16
    Maybe you could tell exactly which plug which cable and which draywerek and whether it worked, I have the same problem only that the Peugeot 308
  • #16 19303480
    Nas19
    Hello, what is this driver?
    I have a problem with the direction in 407, the mass is done and the direction is still missing
  • #17 19303495
    andrzej20001
    Help: 1574
    Rate: 6639
    Disconnect the battery for a while.
  • #18 19306528
    Nas19
    I was the first to do it, even at 4 hours it was unfastened and it did not help
    What is this driver?
    Only in this lamp I have no direction
  • #19 19317075
    Nas19
    The computer has a B4BD error
✨ The discussion revolves around a malfunctioning left rear turn signal on a 2007 Peugeot 407 SW 2.0 HDI, accompanied by a BSI error code B4BD indicating a short circuit. Users suggest various troubleshooting steps, including checking the bulb, swapping connections between the left and right indicators, and examining the BSI module for potential faults. The importance of grounding and the possibility of a damaged driver are highlighted. A specific cable, A17 287C, is identified as responsible for the left rear direction signal. The author plans to replace the driver after locating the appropriate connection.
TL;DR: Peugeot 407 SW rear-left indicator faults often trace to 1 failed BSI output; “I located on the black 3-pin plug.” [Elektroda, Aleksander_01, post #16936886]
Why it matters: This FAQ helps 2004–2010 Peugeot owners quickly diagnose BSI B4BD turn-signal errors without chasing the entire loom.
Quick-Facts
What does BSI error B4BD mean on a Peugeot 407?
B4BD indicates a detected short circuit on the rear-left turn-signal circuit. The symptom is a dead left indicator and stored BSI fault. [Elektroda, Aleksander_01, post #16934200]
Which BSI wire feeds the rear-left turn signal?
Users identified the rear-left indicator feed as wire A17 287C that runs from the BSI to the left rear lamp cluster. [Elektroda, Daro122, post #16936339]
Where is the connector for this circuit on the BSI?
One repair located the relevant lead on a black 3‑pin plug at the BSI. The output “driver” for that bulb had failed. [Elektroda, Aleksander_01, post #16936886]
Will disconnecting the battery reset the indicator fault?
A battery disconnect can temporarily restore the indicator. "Disconnect the battery for a while." Then retest the circuit. [Elektroda, andrzej20001, post #19303495]
How long should I leave the battery disconnected?
One member tried up to 4 hours with no lasting fix. If the fault returns, the issue isn’t reset-related. [Elektroda, Nas19, post #19306528]
Can swapping left and right indicator feeds help diagnose?
Yes. Swap mux/feeds to compare left vs right. If the fault follows the lamp, suspect the lamp/ground; if not, suspect wiring/BSI. [Elektroda, Anonymous, post #16934242]
What if the lamp ground (“mass”) pad is burnt?
Add a dedicated ground wire soldered from harness ground to the lamp board. This restored function in similar cases. [Elektroda, Aleksander_01, post #16934396]
What is the “driver” people mention in this thread?
It’s the BSI’s output stage for the bulb. One case found that driver "released" (failed) for the left rear circuit. [Elektroda, Aleksander_01, post #16936886]
Could a short inside the BSI be the cause?
One responder noted if the BSI itself shorted, the bulb behavior and ground fault message wouldn’t match that scenario. [Elektroda, Anonymous, post #16934347]
Why does a battery reset help only briefly?
Reset clears a latched fault, but hazards work without ignition. Intermittent wiring or lamp issues can quickly retrigger the code. [Elektroda, Anonymous, post #16934734]
How do I perform a quick 3‑step BSI reset for the indicators?
  1. Switch everything off and open the hood.
  2. Disconnect the battery negative clamp and wait a short while.
  3. Reconnect, then test indicators and hazards.
    "Disconnect the battery for a while." [Elektroda, andrzej20001, post #19303495]
Is there an inline module between BSI and the rear lamp?
The thread’s working fix targeted the BSI output and the A17 287C run, not a separate inline module. [Elektroda, Daro122, post #16936339]
What’s an edge case that can confuse diagnostics?
A lamp can still shine yet log a ground short. Check for partially burned ground paths on the lamp board. [Elektroda, Anonymous, post #16934347]
