Peugeot 407 SW 2.0 HDI 2005 - Steering Wheel Lock, Red Indicator & Stop Light, Diagbox Test
siwak15 11145 7
  • #1 16412976
    siwak15
    Rate: 10
    Hello, I recently have a problem with my 407 at a standstill and when the steering wheel locks up, I will add that the oil level is above the max and there is no problem with foaming oil. While driving, when the steering wheel locks, the red steering wheel indicator and STOP lights up, after which the pump stops working and there is no power assistance completely after pressing the brake pedal and releasing everything goes out and the power steering comes back. When I do 30 seconds in diagbox, the blocking pump test is gone, but when I want to see the operating parameters of the pump on a lit engine only when it starts blocking, the connection is broken. What affects the operation of the pump where to look for a fault the pump or installation itself
    https://youtu.be/Z67FXrD16G4 " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > https://youtu.be/Z67FXrD16G4
  • #2 16413011
    sadek1979
    Cars specialist
    Help: 237
    Rate: 1423
    I recently had 307 and there was a problem with power after firing. I suggest checking the plug at the pump. Only good tug on the cables, because in my case the cover and the cable broken in the middle.
  • #3 16413014
    gizio2000
    What Year of this Peugeot?
  • #4 16413035
    siwak15
    Rate: 10
    2005
    Tomorrow I will check from plug to pit and let you know how and how
  • #5 16413046
    gizio2000
    in my opinion it is rather a steering gear regeneration or a new one
  • #6 16413070
    siwak15
    Rate: 10
    As this gear is what disconnects the pump
  • #7 16413077
    gizio2000
    disconnects the pump so that it does not get damaged and the computer catches an error and automatically disconnects
  • #8 16413090
    siwak15
    Rate: 10
    When I start the pump test in a diagbox with the engine off, the support runs and nothing happens and so I can start 2-3 times and nothing but start the engine and start turning the steering wheel and blocking begins and sometimes it happens like a 4-5 car will pass km and nothing happens and other times just after firing
    Added after 13 [hours] 36 [minutes]:
    Does anyone have the wiring diagram of the control etc. of the power steering pump? or will write what is involved in the control it seems to me that the combined switches under the steering wheel can they affect the operation of the pump ??
The discussion revolves around a 2005 Peugeot 407 SW 2.0 HDI experiencing issues with the steering wheel locking up while at a standstill. The user reports that the red steering wheel indicator and STOP light activate, leading to a loss of power assistance. They mention that the oil level is above maximum but not foamy. Suggestions include checking the pump's electrical connections, as a previous user experienced similar issues due to a broken cable. There are also considerations regarding the steering gear's functionality, which may disconnect the pump to prevent damage. The user is seeking a wiring diagram for the power steering pump control and inquires about the potential impact of combined switches under the steering wheel on pump operation.
