[Solved] Blocking Facebook on Asus DSL-N12E-C1 Router: HTTPS Pages, IP Blocking & Open DNS Setup
johnny5001 11799 15
How can I block Facebook on an Asus DSL-N12E-C1 router for two devices when URL filtering does not work on HTTPS pages?
You cannot reliably block Facebook on this Asus DSL-N12E-C1 by URL or by a couple of IP addresses, because HTTPS hides the URL and Facebook uses many different IPs; to do it properly you would need to block the whole Facebook address range or use a router with SSL packet inspection/DD-WRT [#16944005][#16946558][#16946874] For a Windows PC, one workaround is to add Facebook domains to the hosts file [#16939189] OpenDNS can help as a DNS-based block, and it will see the router’s public IP on the Wi‑Fi network, not separate device IPs, but it only applies while the device uses that network [#16939189][#16946558]
  • #1 16937470
    johnny5001
    Rate: 22
    Welcome . Please advise how to block Facebook on Asus DSL N12E-C1 router.
    I read and read, and it is probably not so simple. I need to block access on two devices. I have ADSL from Netia on the Internet. For convenience, I am providing a demo page where you can enter the router settings. Blocking after URL doesn't work because fb is after https. Apparently you can somehow block the IP but I'm not very smart at it. The router demo page is: ] Link
    PS Of course, I'm also interested in blocking using Open DNS
  • #3 16941826
    KOCUREK1970
    Help: 3862
    Rate: 5490
    johnny5001 wrote:
    Apparently you can somehow block after IP
    Facebook.pl
    185.60.216.15
    Facebook.com
    185.60.216.35
  • #4 16944005
    WMichał
    Level 32  
    Help: 172
    Rate: 136
    Blocking these two addresses will not help.
    The author may also be at a different ip address than the above.
    Facebook corresponds to me at other addresses.
    To successfully block, you must block the entire facebook address classes: https://bgp.he.net/AS32934
    Unfortunately, nothing can be done on this router
    Already on ddwrt you can 100% block facebook messneger script that will throw all these addresses to iptables
  • #5 16944731
    johnny5001
    Rate: 22
    Thanks for the help!.
    The lock on the computer using the host file is known to me, but the other device is an iPhone smartphone and is closely guarded ;) .
    Right now at work I tried the Open DNS method and so far it doesn't open fb, messenger and snapchat. When I get home I will try again. Explain one more thing to me. How the Open DNS server will see the IP of the computer and iPhone. They will be different if the server can see only one IP of my router ?.
  • #6 16945347
    KOCUREK1970
    Help: 3862
    Rate: 5490
    Your router's IP, but until you turn on your own internet on your smartphone - then you no longer block it on your phone, because it no longer refers to the wifi network only to the GSM network.
  • #7 16945532
    johnny5001
    Rate: 22
    I understand, but it does not bother me because Play is poor at home with my range.
    In the evening I get to work. I will let you know what and how. Thanks.
  • #8 16945536
    czuker
    Help: 80
    Rate: 68
    I don't think that the fact that Facebook works after https affected the possibility of blocking traffic by URL filters. Have you tried doing that?
  • #9 16945586
    johnny5001
    Rate: 22
    No way. Even in a firewall router it clearly says that it does not block https pages. It was the first thing I did.
  • #10 16945602
    czuker
    Help: 80
    Rate: 68
    Is blocking in the URL filter not working in the keyword filter?
    because while content filtering doesn't seem obvious, I don't see why URL filtering doesn't work.
    Az I will probably check on my old router.
    And I won't look in the manual :)
  • #11 16945624
    johnny5001
    Rate: 22
    See point 2 in my router's configuration. I checked it doesn't work :) Blocking Facebook on Asus DSL-N12E-C1 Router: HTTPS Pages, IP Blocking & Open DNS Setup
  • #12 16945632
    czuker
    Help: 80
    Rate: 68
    Look at the bookmark name :)
  • #13 16945638
    johnny5001
    Rate: 22
    I know, but url will not go either. Try at home. I finish my work, I go home and I will fight there with a living organism.
  • #14 16946558
    czuker
    Help: 80
    Rate: 68
    I am sorry to say that the manufacturer is right and blocking the URL in the case of pages after https does not work :(
    I see no reason why it couldn't be done, but it doesn't work
    As for OpenDNS - in the IP packet headers the server will see the public address, so in the common configuration it will be the router's address.
  • #15 16946874
    jprzedworski
    Help: 758
    Rate: 828
    This is a common problem on many devices. Trend Micro gives this way. Maybe it will work:
    https://en.community.trendmicro.com/tm_en/top...s-trend-micron-not-block-sites-with-https-www
    Check Point also has this problem:
    https://forums.checkpoint.com/forums/thread.jspa?threadID=20155
    There is no problem when the device has SSL packet inspection, but it's not in Asus - another class.
  • #16 17348435
    johnny5001
    Rate: 22
    I'm closing the old topic. Everything worked for 2 minutes. I quickly worked it out by changing the DNS of the browser. Thank you for your interest.
The discussion revolves around the challenges of blocking Facebook on the Asus DSL-N12E-C1 router. Users express difficulties with URL filtering due to Facebook's use of HTTPS, which complicates blocking attempts. Suggestions include modifying the hosts file on Windows devices and utilizing OpenDNS for network-wide blocking. However, users note that blocking specific IP addresses may not be effective as Facebook frequently changes its IPs. The limitations of the router's firmware are highlighted, with recommendations for alternative firmware like DD-WRT for more robust blocking capabilities. The conversation concludes with the realization that changing DNS settings can bypass restrictions, rendering initial efforts ineffective.
TL;DR: On an Asus DSL‑N12E‑C1 you can’t reliably block Facebook at the router; “This Asus will not allow it.” Two options exist: hosts-file edits or OpenDNS. [Elektroda, Anonymous, post #16939189]
Why it matters: If you’re asking how to block Facebook/Messenger/Snapchat on this Asus, the built‑in URL filter won’t stop HTTPS traffic and quick workarounds exist.
Can I block facebook.com on an Asus DSL‑N12E‑C1 using the built‑in URL filter?
No. Owners confirmed the router’s URL/keyword filters don’t block HTTPS pages, so facebook.com still loads. The firewall UI even notes HTTPS isn’t filtered. Use network‑level DNS filtering or device‑level controls instead. [Elektroda, johnny5001, post #16945586]
Will blocking a few Facebook IPs like 185.60.216.15 and 185.60.216.35 work?
No. Facebook serves content from many IP ranges aggregated under AS32934, so blocking two addresses misses the rest. Effective IP blocking would require covering all Facebook prefixes, which this Asus cannot manage. [Elektroda, WMichał, post #16944005]
Is OpenDNS a viable way to block Facebook on this router?
Yes, OpenDNS can block domains at DNS lookup time. However, a user reported it was bypassed within 2 minutes by changing the browser’s DNS. Use router‑enforced or locked DNS and device restrictions to reduce bypasses. [Elektroda, johnny5001, post #17348435]
How does OpenDNS see my devices—individually or as one IP?
OpenDNS sees the public IP of your router, not individual LAN device IPs. That’s normal for home NAT setups. If a phone switches to mobile data, the router’s controls no longer apply. [Elektroda, KOCUREK1970, post #16945347]
Why doesn’t HTTPS blocking work here without extra features?
HTTPS encrypts the URL path, so simple URL filters can’t read it. “There is no problem when the device has SSL packet inspection, but it’s not in Asus—another class.” Enterprise gear with SSL inspection can filter it. [Elektroda, jprzedworski, post #16946874]
What’s the quickest way to block Facebook on a single Windows PC?
Edit the Windows hosts file to resolve Facebook domains to 0.0.0.0. This is device‑specific and easy to undo, but it works per‑PC without router changes. [Elektroda, Anonymous, post #16939189]
What is OpenDNS?
OpenDNS is a DNS resolver that offers category and domain blocking before connections are made. Point your router or device DNS to OpenDNS and enable its filtering policy for social networking. [Elektroda, Anonymous, post #16939189]
What is DD‑WRT, and could it help?
DD‑WRT is third‑party router firmware that adds advanced features, including iptables scripting. A contributor noted DD‑WRT can push a full Facebook/Messenger block list into iptables, unlike the stock Asus firmware. [Elektroda, WMichał, post #16944005]
What is an Autonomous System (AS32934)?
An Autonomous System is a collection of IP prefixes under one network operator. Facebook/Meta uses AS32934 to announce many IP ranges, which is why single‑IP blocks fail. [Elektroda, WMichał, post #16944005]
Can I rely on keyword filters to stop Facebook Messenger?
No. Keyword/URL filters on this model don’t see HTTPS content, and Messenger also uses varied endpoints. Use DNS filtering plus device policies, or firmware with SSL inspection/IP blocking at scale. [Elektroda, czuker, post #16946558]
How can users bypass router‑level DNS blocks?
They can set custom DNS in the browser or OS, use a VPN/proxy, or switch to mobile data. In this thread, changing the browser DNS bypassed OpenDNS in 2 minutes. [Elektroda, johnny5001, post #17348435]
What’s a realistic plan to block two specific home devices?
Combine OpenDNS on the router with per‑device restrictions. Lock DNS settings on each device and remove admin rights. This layered approach resists casual bypasses for two devices, as requested by the original poster. [Elektroda, johnny5001, post #16937470]
3‑step How‑To: Try OpenDNS on the DSL‑N12E‑C1
  1. In the router WAN/DNS settings, set both DNS servers to OpenDNS addresses.
  2. In your OpenDNS dashboard, enable the Social Networking block category and add facebook.com to block list.
  3. Reboot router and clear device DNS cache; test on target devices. “Or as you write OpenDNS.” [Elektroda, Anonymous, post #16939189]
Edge case: Why does Facebook still open at work but not at home (or vice‑versa)?
Policies apply to the network enforcing them. At work, OpenDNS blocked sites; at home, changing DNS defeated it. Location, DNS settings, and whether the device uses Wi‑Fi or cellular determine results. [Elektroda, johnny5001, post #17348435]
Does the Asus demo UI help configure blocking?
The demo shows QoS and filtering menus, but the key limitation remains: HTTPS URL blocking isn’t supported. Don’t expect the demo’s URL filter to stop Facebook. [Elektroda, johnny5001, post #16945586]
If I must block by IP only, what’s the limitation?
You’d need to maintain an extensive, changing list of Facebook/AS32934 prefixes. The DSL‑N12E‑C1 lacks tools to import and update that list, making IP‑only blocking impractical here. [Elektroda, WMichał, post #16944005]
