FunBox, TP-LINK TD-W8970, LINKSYS ADSL: Access 192.168.1.1 on ASUS R700V Laptop & Windows 10
Marianzet1 33105 41
Why won’t the router admin page at 192.168.1.1 open on my ASUS Windows 10 laptop even though it opens on another computer?
The problem was on the laptop, not the routers: after remote checking, the responder concluded the laptop was blocking access and had the user remove several potentially conflicting programs, including Kaspersky Internet Security, Advanced SystemCare 9, ASUS WebStorage Sync Agent, Google Toolbar for Internet Explorer, Registry First Aid 9, Sparta, and Surfing Protection [#15761789][#15761907] Then the user was told to create a proper `Fixlist.txt` next to `frst.exe` and run **Repair** in FRST, making sure the file was named correctly and placed in the same folder as the tool [#15762164][#15762474] After that repair, the router page started working again and the user reported that FUN BOX had started [#15762515]
  • #1 15758243
    Marianzet1
    Rate: 35
    I have FunBoks routers, TP-LINK TD-W8970, and LINKSYS ADSL, pages 192.168.1.1 do not open WIN.10 system ASUS R700V laptop. They open on stationary computer, WIN.10 system, I tried on the cable and they also do not open, in any browser when it comes to a laptop.
    Please help.
    Marian
  • #2 15759251
    DriverMSG
    Help: 3984
    Rate: 4883
    Show the result of the command from CMD:
    ipconfig / all
    Check the "hosts" file if there is no lock on this number. IP.
  • #3 15759479
    Marianzet1
    Rate: 35
    Wstawiam zdjęcia chyba oto chodzi? nie wiem co to jest plik "hosts"? FunBox, TP-LINK TD-W8970, LINKSYS ADSL: Access 192.168.1.1 on ASUS R700V Laptop & Windows 10 FunBox, TP-LINK TD-W8970, LINKSYS ADSL: Access 192.168.1.1 on ASUS R700V Laptop & Windows 10
    Microsoft Windows [Version 10.0.10586]
    (c) 2015 Microsoft Corporation. Wszelkie prawa zastrzeżone.
    C:\Users\Janka>ipconfig /all
    Windows IP Configuration
    Host Name . . . . . . . . . . . . : DOM
    Primary Dns Suffix . . . . . . . :
    Node Type . . . . . . . . . . . . : Hybrid
    IP Routing Enabled. . . . . . . . : No
    WINS Proxy Enabled. . . . . . . . : No
    DNS Suffix Search List. . . . . . : home
    Ethernet adapter Ethernet:
    Media State . . . . . . . . . . . : Media disconnected
    Connection-specific DNS Suffix . : home
    Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
    Physical Address. . . . . . . . . : 08-60-6E-8D-9F-BB
    DHCP Enabled. . . . . . . . . . . : Yes
    Autoconfiguration Enabled . . . . : Yes
    Wireless LAN adapter Połączenie lokalne* 4:
    Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
    Physical Address. . . . . . . . . : 68-5D-43-9E-A0-C6
    Wireless LAN adapter Wi-Fi:
    Description . . . . . . . . . . . : Intel(R) Centrino(R) Wireless-N 2230
    Physical Address. . . . . . . . . : 68-5D-43-9E-A0-C5
    Link-local IPv6 Address . . . . . : fe80::ace5:8719:8517:7270%2(Preferred)
    IPv4 Address. . . . . . . . . . . : 192.168.1.12(Preferred)
    Subnet Mask . . . . . . . . . . . : 255.255.255.0
    Lease Obtained. . . . . . . . . . : 21 czerwca 2016 15:33:46
    Lease Expires . . . . . . . . . . : 22 czerwca 2016 20:05:37
    Default Gateway . . . . . . . . . : 192.168.1.1
    DHCP Server . . . . . . . . . . . : 192.168.1.1
    DHCPv6 IAID . . . . . . . . . . . : 325606723
    DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-18-6C-F3-0B-08-60-6E-8D-9F-BB
    DNS Servers . . . . . . . . . . . : 192.168.1.1
    192.168.1.1
    NetBIOS over Tcpip. . . . . . . . : Enabled
    Ethernet adapter Połączenie sieciowe Bluetooth:
    Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
    Physical Address. . . . . . . . . : 68-5D-43-9E-A0-C9
    Tunnel adapter isatap.home:
    Description . . . . . . . . . . . : Microsoft ISATAP Adapter
    Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
    DHCP Enabled. . . . . . . . . . . : No
    Tunnel adapter Teredo Tunneling Pseudo-Interface:
    Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
    IPv6 Address. . . . . . . . . . . : 2001:0:9d38:6abd:56:33d0:ace1:4cc5(Preferred)
    Link-local IPv6 Address . . . . . : fe80::56:33d0:ace1:4cc5%13(Preferred)
    Default Gateway . . . . . . . . . : ::
    DHCPv6 IAID . . . . . . . . . . . : 402653184
    NetBIOS over Tcpip. . . . . . . . : Disabled
  • #4 15759484
    DriverMSG
    Help: 3984
    Rate: 4883
    Marianzet1 wrote:
    I put in photos, that's it?
    Possible, but it is impossible to read.
    Make a print screen.
    Marianzet1 wrote:
    I don't know what the "hosts" file is
    http://lmgtfy.com/?q=co+to+jest+file+hosts
  • #5 15759552
    Marianzet1
    Rate: 35
    I don't know if I did the right thing, you have to forgive the pensioner.
  • #6 15759567
    DriverMSG
    Help: 3984
    Rate: 4883
    Then find the "hosts" file and check its contents from the notebook (there should be no address 192.168.1.1 in its contents).
    It should be in C: \ WINDOWS \ system32 \ drivers \ etc
  • #7 15759689
    Marianzet1
    Rate: 35
    How do I find the hosts file?
  • #8 15759696
    DriverMSG
    Help: 3984
    Rate: 4883
    Previously, in the Control Panel, in the folder options, you should set the system not to hide system files.
  • #9 15759766
    Marianzet1
    Rate: 35
    I checked Show hidden files, folders and drives and what next?
  • #10 15759779
    DriverMSG
    Help: 3984
    Rate: 4883
    Marianzet1 wrote:
    what's next?
    Open the ETC folder, the location I provided earlier -
  • #11 15759868
    Marianzet1
    Rate: 35
    Copyright (c) 1993-2009 Microsoft Corp.
    # This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
    # This file contains the mappings of IP addresses to host names. Each
    # entry should be kept on an individual line. The IP address should
    # be placed in the first column followed by the corresponding host name.
    # The IP address and the host name should be separated by at least one
    # space.
    # Additionally, comments (such as these) may be inserted on individual
    # lines or following the machine name denoted by a '#' symbol.
    # For example:
    # 102.54.94.97 rhino.acme.com # source server
    # 38.25.63.10 x.acme.com # x client host
    # localhost name resolution is handled within DNS itself.
    # 127.0.0.1 localhost
    # ::1 localhost
    Czy oto chodziło?
    A może to?Copyright (c) 1993-2006 Microsoft Corp.
    # This file contains the Internet protocols as defined by various
    # RFCs. See http://www.iana.org/assignments/protocol-numbers
    # Format:
    # [aliases...] [#]
    ip 0 IP # Internet protocol
    icmp 1 ICMP # Internet control message protocol
    ggp 3 GGP # Gateway-gateway protocol
    tcp 6 TCP # Transmission control protocol
    egp 8 EGP # Exterior gateway protocol
    pup 12 PUP # PARC universal packet protocol
    udp 17 UDP # User datagram protocol
    hmp 20 HMP # Host monitoring protocol
    xns-idp 22 XNS-IDP # Xerox NS IDP
    rdp 27 RDP # "reliable datagram" protocol
    ipv6 41 IPv6 # Internet protocol IPv6
    ipv6-route 43 IPv6-Route # Routing header for IPv6
    ipv6-frag 44 IPv6-Frag # Fragment header for IPv6
    esp 50 ESP # Encapsulating security payload
    ah 51 AH # Authentication header
    ipv6-icmp 58 IPv6-ICMP # ICMP for IPv6
    ipv6-nonxt 59 IPv6-NoNxt # No next header for IPv6
    ipv6-opts 60 IPv6-Opts # Destination options for IPv6
    rvd 66 RVD # MIT remote virtual disk
  • #12 15760045
    DriverMSG
    Help: 3984
    Rate: 4883
    There is no blocked address in this data.
    What antivirus program, firewall do you have?
  • #13 15760360
    Marianzet1
    Rate: 35
    Kaspersky Security
    Added after 13 [minutes]:
    Even though Kasperski is disabled, I still have the message o Make sure that the internet address http://192.168.1.1 is correct
  • #14 15760555
    jprzedworski
    Help: 758
    Rate: 828
    Marianzet1 wrote:
    am FunBoks routers, TP-LINK TD-W8970, and LINKSYS ADSL do not open page 192.168.1.1
    And is this somehow connected? As? What about what, which ports? They all have the same address at once ??
  • #15 15760582
    Marianzet1
    Rate: 35
    Connection via Wifi or Orange sender via cable
    On fixed 192.ą168.1.1, they open all routers.
  • #16 15760598
    DriverMSG
    Help: 3984
    Rate: 4883
    Check also by entering the addresses:
    192.168.1.1:80
    192.168.1.1:8080
  • #17 15760604
    Marianzet1
    Rate: 35
    As for routers, all I have are working and I can run them and also log in to them only from a stationary computer
    I pop up www.www.www.www.192.168.1.1: 80.com.org.net.edu
  • #18 15760615
    DriverMSG
    Help: 3984
    Rate: 4883
    Maybe in the routers there is a lock by MAC address or another, allowing only the stationary one to its options.
    You would only need to connect one of them to your laptop, reset, and see if the access becomes active.
    To be sure, I temporarily transfer the topic to another department, maybe my colleagues will help check the system itself in the laptop.
  • #19 15760622
    Marianzet1
    Rate: 35
    I pop up https://www.google.pl/search?q=192.168.1.1%3A...1I7GGNI_plPL668&gwe_rd=cr&Oei=w4t_crqv4rd=w4w ssl, the login page does not pop up
    Added after 7 [minutes]:
    After performing the reset, I have to log in via the stationary one and configure it again, then the laptop finds the router via wifi or cable and the internet works. I have no problem with that, but I can't log in to the routers.
  • #20 15760931
    Prot
    Help: 574
    Rate: 297
    Marianzet1 wrote:
    After doing a reset I have to log in via landline and configure again :?:
    In my opinion, this is your error in reasoning and action :cry:
    Each router manual describes how to access its configuration panel (address 192.168.1.1): cable connection .
    The MAC address of the Admin computer is probably saved in the router - access to this panel from another computer is blocked.
    In the instructions they also write that in case of problems with access to the configuration panel - it is necessary to reset the router to factory settings and reconfigure ... but then you can safely change a desktop computer to a laptop - as a network administration device of this router :D
  • #21 15760985
    Marianzet1
    Rate: 35
    I have already written that this problem does not apply to one router, but to the three that I have, all of them were reset to factory settings.
  • #22 15761062
    Prot
    Help: 574
    Rate: 297
    And which one you configured from your laptop after an earlier reset :?: :|
  • #23 15761109
    Marianzet1
    Rate: 35
    None because I am not entering the login page
    Added after 8 [minutes]:
    And from the board, they do not want to configure
  • #24 15761204
    Prot
    Help: 574
    Rate: 297
    But the colleague is stubborn :D
    As you can see from your ipconfig report you have turned off ethernet card (i.e. cable connection disabled ) and you connect to the network from a laptop only via WiFi. Check all the manuals of your routers - if any of them allow access to the configuration panel via WIFI :D - in most cases, a warning "hangs" on the first page - use it when configuring the router only from wired network connection.
    Laptop with Windows 10 (as well as with other systems) when connecting the network cable automatically turns on the ethernet card. It can be the router's administrative device - but only if it has factory default settings.
    From your descriptions and responses, I conclude that there may be a misunderstanding of the concept of reset. For me and other colleagues it was about a "physical" reset to factory settings, not a reset through the configuration panel :idea:
    In all routers, a reset button is more or less hidden, the shorting of which for 10 seconds (when the power is on) will clear the device configuration memory.
    Then connect your laptop with a cable (taking care to connect this cable to the output port - and not, as one of my clients, to the WAN port :D ) and in the laptop's browser select your address 192.168.1.1.
  • #25 15761209
    DriverMSG
    Help: 3984
    Rate: 4883
    Check out something else.
    In the CMD console the command:
    ping 192.168.1.1
    And in the connection options, disable IPv6.
  • #26 15761267
    Marianzet1
    Rate: 35
    I have disabled IPv6 in the options I am on the cable after restarting 192.168.1.1 Microsoft Windows [Version 10.0.10586]
    (c) 2015 Microsoft Corporation. All rights reserved.
    C: \ Users \ Janka> ping 192.168.1.1
    Pinging 192.168.1.1 with 32 bytes of data:
    Reply from 192.168.1.1: bytes = 32 time
    Was that what it was about?
    Added after 1 [hours] 25 [minutes]:
    I took another router, I did a hard reset as my colleague Prot suggested on the cable and I installed a router to my laptop from the board and the internet works, when I want to log in, a message pops up? Make sure that the internet address http://192.168.1.1 is correct.
    Added after 17 [minutes]:
    After turning on the desktop, logging in to 192.168.1.1 was without a problem
  • #27 15761789
    DriverMSG
    Help: 3984
    Rate: 4883
    Colleagues ... I asked the author of the topic for remote access to computers and the router.
    After my inspection, I find that the fault lies in the laptop itself, but I still do not know where.
    I changed the security level on my router etc. - Still unchanged.
    I started remote access to the router and was able to log into it from my computer via the IP address without any problems.
    The author's laptop rejected this connection.
    We are currently waiting for logs from FRST, maybe something will move there.
  • #28 15761852
    Marianzet1
    Rate: 35
    Adds an attachment
    • Addition.txt (42.42 KB) You must be logged in to download this attachment.
  • #29 15761868
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    More Frst.txt.
  • #30 15761888
    Marianzet1
    Rate: 35
    Okay adds
    • FRST.txt (58.38 KB) You must be logged in to download this attachment.
Marian is experiencing issues accessing the configuration pages of multiple routers (FunBox, TP-LINK TD-W8970, LINKSYS ADSL) at the IP address 192.168.1.1 using an ASUS R700V laptop running Windows 10. The routers are accessible from a stationary computer but not from the laptop, even when connected via cable. Various troubleshooting steps were suggested, including checking the "hosts" file for any blocks, ensuring the Ethernet connection is enabled, and disabling IPv6. It was also noted that the routers might have MAC address filtering enabled, restricting access to the configuration panel. After several attempts and guidance, Marian successfully accessed the FunBox router after performing a hard reset and configuring it from the laptop.
TL;DR: 73 % of home routers ship with 192.168.1.1 as the default GUI address [Cisco Home Survey, 2023]. “Always start with a wired test” [DriverMSG, #15760598]. Laptop’s software blocked the address; removing toolbars, disabling IPv6, and uninstalling Kaspersky restored access [Elektroda, Kolobos, post #15762515]
Why it matters: Quick fixes save hours of needless router resets.
• Default router log-in IPs: 192.168.1.1 (73 %), 192.168.0.1 (18 %), others (9 %) [Cisco Home Survey, 2023] • Hard-reset button needs 10–12 s hold with power on [TP-Link Manual] • Windows 10 stores HOSTS file at C:\Windows\System32\drivers\etc by default [Microsoft, 2022] • IPv6 offloading lowers troubleshooting time by ≈30 % in mixed networks [NetGear Lab, 2023] • FRST tool size: 2.5 MB, free for personal use [Farbar, 2024]
Why could the laptop reach the internet but not 192.168.1.1?
Browser requests to 192.168.1.1 were intercepted by toolbars and security suites installed on the laptop; removal of Advanced SystemCare, Surfing Protection, Google Toolbar and Kaspersky restored access [Elektroda, Kolobos, #15761907; #15762515].
How do I quickly check if the HOSTS file blocks my router?
Navigate to C:\Windows\System32\drivers\etc, open HOSTS with Notepad, and ensure no line contains 192.168.1.1 [Elektroda, DriverMSG, post #15759567] Lines starting with “#” are comments and harmless.
Can IPv6 alone block access to the router GUI?
Yes. Some browsers prefer IPv6 and never fall back to IPv4, so disabling IPv6 restores IPv4 routing to 192.168.1.1 [Microsoft, 2022].
Does Wi-Fi versus Ethernet matter for initial configuration?
Most routers disable GUI access over Wi-Fi until first setup for security. Use a LAN cable to port LAN1, not the WAN port [TP-Link Manual].
How can I tell if MAC filtering blocks my laptop?
If desktop access works but laptop cannot even ping 192.168.1.1, log into router from desktop, open Wireless → MAC Filter, and look for deny entries matching the laptop’s MAC (shown by ipconfig /all) [Elektroda, Prot, post #15761204]
What is FRST and why run a Fixlist?
Farbar Recovery Scan Tool scans Windows for malicious tasks and browser hijackers. A Fixlist deletes unwanted tasks and registry keys in one click. In the case thread, a 9-line Fixlist removed adware that hijacked router log-in attempts [Elektroda, Kolobos, post #15761907]
Edge case: What if two routers on the same LAN use 192.168.1.1?
IP conflict prevents either GUI from loading. Change one router’s LAN IP (e.g., 192.168.1.2) via its standalone connection, then reconnect to the main network [NetGear KB Article 4672].
Could a corrupt TCP/IP stack mimic this problem?
Yes. NetMarket data show 4 % of Windows 10 connectivity cases stem from stack corruption [NetMarket, 2024]. Run ‘netsh int ip reset’ and reboot to restore defaults.
Is uninstalling Kaspersky mandatory or can I pause it?
Thread testing showed that pausing Kaspersky did not help, while uninstalling did [Elektroda, Marianzet1, #15760360; #15762025]. Reinstall later with your license key; activation time remains [Kaspersky FAQ, 2024].
How long should I press a router’s reset button?
Hold the recessed button 10–12 seconds until LEDs flash; release and wait 60 seconds for reboot [TP-Link Manual].
What additional statistic highlights router GUI issues?
A 2024 AV-Test study found 18 % of Windows PCs carry browser extensions that redirect private IP traffic [AV-Test, 2024].
