Router with Word-Based Parental Control: Block Explicit Content in Institutions (TP-Link)
jakisgosc 7122 10
Can I use a router to block porn pages by keywords rather than by website address, ideally on TP-Link equipment?
No ordinary router will reliably block porn by keyword, especially on HTTPS pages, so DNS filtering or a proxy is the practical approach instead [#16337083] [#16339327] Use a filtering DNS service such as 208.67.222.123 and 208.67.220.123, and block users from changing their DNS settings on the client devices [#16339327] If you want to do this on a cheap TP-Link, you likely need OpenWRT so you can redirect DNS traffic from port 53 and force all clients through the filtered DNS [#16351883] For an institution, a MikroTik or a UTM-class solution is a better fit than basic TP-Link hardware, especially if you also want control over torrents and 10–20 devices [#16377293]
  • Seeking routers with keyword-based content filtering
    #1 16337034
    jakisgosc
    I mean a router that has a kind of parental control
    but I mean blocking after specific words, not website addresses, because it has every router.
    I have to block the possibility of displaying porn pages in one institution and the easiest way to do it on the router (blocking by the words: porn, porn, etc.), I do not want to mess with applications on a dozen or so computers.
    I remember that a long time ago such a possibility was on old Linksys with Tomato installed but now it is inefficient equipment.
    Maybe someone knows if today any routers have it - preferably some Tp-link.
  • #2 16337083
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    Welcome.
    In my opinion, this mechanism will be rather inefficient. Rather, it should not disturb on SSL secured pages (and there are more and more of them).
    In my opinion, setting up a proxy server and forcing connected computers to use it would be more effective: https://www.howtoforge.com/filtering-https-traffic-with-squid
  • #3 16338984
    zwi
    MikroTik RB962UiGS 5HacT2HnT hAP ac
    You do what you want on Layer7, it requires some configuration knowledge.
    I do not know if such sites fly over http or https but you have to check it yourself. Maybe there will be a problem with https, Snort?
  • #4 16339327
  • #5 16346601
    bryko
    Help: 49
    Rate: 103
    any Mikrotik. Using Layer7 filters, I cut out YouTube access for some computers in my network (https).
  • #7 16351883
  • #8 16375623
    jakisgosc
    Thanks for all the answers. I didn't think about https. But the DNS lock seems enough.
    MikroTik is a little afraid because I have never had contact, and I heard that the configuration is not easy, the equipment is also not cheap.
    I didn't have any contact with Asus either, so I am the closest to Tplink and OpenWRT - although for the last time I did something 2 years ago - Gargoyle on a regular MR3420.
    Jurek.adam you know if I can set it on any Tplink for any computers or do I need it for the whole network? Could you recommend a specific Tplink, which will calmly handle 10-20 devices on the network?
    I also need to block torrents there, because I connect very slow in the woods and if 2 people launch torrents, the rest of the pages cannot be opened.
  • #9 16376056
  • #10 16376148
    bryko
    Help: 49
    Rate: 103
    The cheapest Mikrotik is less than PLN 90, so the high cost is not.
  • #11 16377293
    czuker
    Help: 80
    Rate: 68
    If it's an institution and has money, I recommend UTM class solutions
The discussion revolves around finding a router with word-based parental controls to block explicit content in an institutional setting. The user seeks a solution that does not require individual application installations on multiple computers. Responses suggest that traditional word-based filtering may be ineffective, especially with the prevalence of HTTPS. Alternatives include using a proxy server for better control, implementing MikroTik routers with Layer7 filtering capabilities, or utilizing DNS services like Yandex.DNS for content filtering. Some participants recommend MikroTik for its effectiveness, while others mention the potential of TP-Link routers with OpenWRT firmware for DNS-based blocking. The user expresses a preference for TP-Link but is open to other options, particularly for managing bandwidth and blocking torrents.
