Afriso Four-Way Valve Actuator & Defro K1Pv4 Controller: Cable Connection Guidance
Tomasz Puc 10398 4
  • #1 16940199
    Tomasz Puc
    I need professional advice that may seem ridiculous to some. I wanted to connect the Afriso four-way valve actuator with the Defro K1Pv4 controller. The actuator has 3 cables: black, brown and blue, and the controller has two options for connecting it. Looking from the back of the controller, all these inputs are marked on the left with the valve and three inputs marked OZN, and on the right where all sensors are connected, there is only two cables and the description of the valve. I am a layman in these matters, so can anyone write to me if they know which cable in which hole?
  • #2 17065449
    adiva22
    Rate: 21
    Has a colleague managed with this connection? because I also have a problem.
  • #3 17418619
    janusz0064
    Rate: 37
  • #4 20212121
    konrad_51
    Rate: 20
    Connecting the afrisko actuator
    blue - n
    black - with
    brown - o
  • #5 21794593
    zaradny2
    Rate: 34
    I'm surprised that still 2025r can't find instructions on how to plug it in. There are not even detailed instructions for the k1pv4 controller outputs (not k1p2...) .
