Seeking Nitecore UM10 Reviews: 18650, AA, AAA Battery Charging Capabilities
lexom 3942 5
  • #1 16940867
    lexom
    Rate: 9
    I am looking for a charger for 18650 cells with the option of charging AA / AAA batteries.
    Preferably something small and mobile - preferably for one link.
    While browsing the internet, I found a Nitecore UM10 - it says that it loads 18650 / AA / AAA.
    Maybe someone used and will speak, or maybe someone will give you some other proposal.
  • #2 16940934
    goldi74
    Help: 1367
    Rate: 1539
    UM10 charges only Li-Ion cells, AA / AAA 1.2V are not supported by it: http://charger.nitecore.com/CHARGER/UM/UM10/
    If there can be 2 cells, then you should be interested in Nitecore i2 or D2, both of which support both Li-Ion and Ni-MH / Ni-Cd 1.2V cells.
  • #3 16940951
    MLODY73
    Help: 15
    Rate: 26
    I use Nitecore D2 to charge 18650 and AAA (bicycle lights).
    It can be said that it does the job as it does not depend on time (charging current a bit - only 0.5A).
    Currently, if I was buying, I would look for something stronger (at least 1A).
  • #4 16940962
    lexom
    Rate: 9
    And there will be something for one link?
  • #5 16941123
    goldi74
    Help: 1367
    Rate: 1539
    Soshine SC-S7
    LittoKala Lii-100
    Opus BT-C100
    Overall, there are much fewer single universal chargers than 2 or 4 channel.
  • #6 16941274
    lexom
    Rate: 9
    Thanks. I'll choose something of it.
