[Solved] Best AA & AAA Battery Chargers: Comparing NC-3000, Varta LCD & Eneloop Pro for Cameras
grzegorz041 74496 31
Which charger should I choose for AA and AAA NiMH batteries for a camera, and is the Varta LCD charger safe to use?
Choose the everActive NC-3000 if you want the most capable option, or the NC-1000/NC-1000 Plus if you prefer a smaller and more convenient charger; the NC-3000 adds good internal resistance measurement and high measurement accuracy, while the NC-1000 is also reliable and has proper -dV charge termination [#16313266] Avoid the Varta LCD charger, because it charges cells in pairs, which can overcharge one battery and undercharge the other; that can make some cells boil while others remain undercharged and wear out the set early [#16313555] A warm battery at the end of charging is normal for Ni-MH cells, so heat alone does not mean the charger is bad [#16313555] For batteries, prefer known LSD NiMH cells such as Eneloop, Fujitsu, GP Recyko, Everactive, Ansmann, or Ikea Ladda, and avoid unknown high-capacity brands [#16313490]
  • #1 16311439
    grzegorz041
    Help: 7
    Rate: 142
    Hello all. I would like to know what charger you would choose to charge AAA and AA batteries. I have already looked at some posts (which were quite a long time ago) and articles regarding the ranking of chargers. However, I found out that the forum hints of the people who tested the pros and cons are the best. I read that the NC-3000 charger is at the forefront of chargers, but the price is PLN 130. it's a bit big- or maybe not? I had a charger in my possession https://imged.pl/ladowarka-varta-lcd-8x-akumulatorki-2600mah-r6-aa-792559.html My friend recommended that it was a nice charger for a nice price. I bought, also I think, nice eneloop pro rechargeable batteries for my camera. After the first charge, the rechargeable batteries were so hot that it was impossible to hold them in your hand !! I think - this is how they will end their lives quickly ... The charger went to the shelf and what next ..? Thanks in advance for the tips ...
  • #3 16311471
    kierbedz4
    Level 36  
    Help: 307
    Rate: 1008
    I propose the EMOS charger model KN-8501 It also has a switch that allows you to charge 2 or 4 batteries, I just have no problem with it. Moderate price around PLN 50
  • #4 16311509
    grzegorz041
    Help: 7
    Rate: 142
    I read about the BC-700 charger. They write that NC-3000 is like a more threshold. I have not heard about the EMOS KN-8501 model, but I have read the description - nice. It is probably important to discharge and support ..?
  • #6 16312407
    grzegorz041
    Help: 7
    Rate: 142
    This MH-C9000 is also interesting, but probably a bit too expensive for me. I will probably stay with the BC-700. Is the full name? Techno Line BC-700. ? I'm just wondering about the NC-3000 ...
    NC-1000 preferred for charging convenience and termination performance
    #7 16313266
    SPEAKERS_XP
    Help: 56
    Rate: 53
    The topic has already been rolled over several times.
    I recommend taking a look:
    https://www.elektroda.pl/rtvforum/topic3136687.html
    https://www.elektroda.pl/rtvforum/topic3055199.html
    https://www.elektroda.pl/rtvforum/topic3067587.html
    If I were to summarize (I have / have / tested all these chargers):
    BC-700 / BC-1000 - charges OK, but the design is quite old, with rather stupid limitations that can significantly limit the convenience of using the charger. Another disadvantage is the average measurement accuracy (mA / mAh) and the unfortunate 3V DC power supply.
    MH-C9000 - this charger actually charges worse than the BC-700 (in my opinion it has a worse charging algorithm), but has a very high measurement accuracy. For a typical user, this charger has no major advantages, and at the same time it is very expensive.
    NC-1000 - this is my favorite. Most often I refer to this structure. As a charger it works reliably and has a book-like, very good termination of the charging process - a real -dV mechanism. Minus is the average measurement accuracy (mA / mAh). The new NC-1000 Plus seems even slightly better ...
    NC-3000 - it was supposed to be a charger better than the NC-1000 ... and in fact it is ... but the NC-1000 is more pleasant and convenient for me to use - it is smaller and "faster" to use. The advantage of the NC-3000 is the quite well-functioning internal resistance measurement and, similarly to the MH-C9000, high measurement precision.
    I would choose between the NC-3000 and the NC-1000 (Plus) ... although it's best to have both ;)
  • #8 16313287
    grzegorz041
    Help: 7
    Rate: 142
    Oh and great. I already know what to look for. I also have a question. I wanted to buy rechargeable batteries. I need more for children's toys. They are for 5, 7, 10 or more zlotys on the allegrosz. But I also found those for PLN 2.5. I have better cameras for the camera, and are those for toys for 2.5 PLN enough?
  • Choose reputable LSD cells over inflated capacities
    #9 16313490
    SPEAKERS_XP
    Help: 56
    Rate: 53
    In the case of rechargeable batteries, first of all, I would advise you to avoid unknown brands with the highest capacity. In addition, it is worth looking for batteries with reduced self-discharge (LSD, Ready 2 Use) - this guarantees greater reliability of use.
    It should be remembered that the maximum capacity for R6 AA batteries is approx. 2600 mAh, while for R03 AAA it is approx. 1000 mAh - this is what the current technology allows ... but in questionable quality batteries these limits do not exist - as you know, paper / label will accept everything - unfortunately such "cheated" batteries are practically useless - the measured capacity is often even 10 times lower than the imprint on the label ... this can be easily assessed by performing molding / testing in any of the above-mentioned chargers.
    In terms of durability, my favorite for many years are Eneloop batteries, unfortunately they are not the cheapest.
    Others that also keep parameters are, for example: Fujitsu, GP - Recyko series, Everactive, Ansmann, Ikea Ladda.
  • #10 16313516
  • Pair charging risks uneven Ni-MH charging and premature wear
    #11 16313555
    SPEAKERS_XP
    Help: 56
    Rate: 53
    I would like to add that the temperature of Ni-MH batteries should clearly rise at the end of charging in each processor charger - it is really a guarantee that the batteries are properly charged.
    The Varta charger mentioned in the first post is unfortunately quite unfortunate, because it only charges the batteries in pairs - this is a significant disadvantage and limitation of many chargers.
    Such chargers treat each pair of cells as a package - for this to work well, the installed batteries must be identical, used and discharged in the same way when they are put into the charger ... in practice, it is impossible to ensure it - unfortunately, it usually ends so that some of the batteries are boiled and some of them are undercharged, as a consequence the whole set is worn out prematurely.
  • #12 16313562
    grzegorz041
    Help: 7
    Rate: 142
    Thanks a lot. I will definitely choose something now ...
  • #13 16580771
    mlero
    I have been BC700 for 10 years and I am annoyed by the muddy function buttons and sometimes charging AAA batteries indefinitely.
    For example, Eneloop Pro AAA 900mAh (new) with a current of 200mA can sometimes be charged to a capacity of 2200mAh on the display ...
    I bought the NC-1000 plus, which is admired here, and the buttons actually work properly and without any delays,
    aaaaale
    the default setting of the charging current at 500mA is stupid.
    In the BC700 charger, the default current for AA / AAA batteries is 200mA and it was good because even a person unfamiliar with things (wife) could safely charge the batteries. As AAA will be treated by default in the NC1000 with a current of 500mA, they will not work for a long time, and each time switching the current through 700/1000 / 200mA is a pain. An attempt to explain to a woman for whom the current is something incomprehensible such a procedure of charging may end up with a bump on the head of the size depending on the weight of the pan ;-) )
    In addition, I measured the voltage on the battery during charging and the BC700 is constant, slightly higher (about 0.2V) than on the display, while on the NC-1000plus the voltage jumps on the Voltmeter every 2 seconds, for example 1.39V - just 1.70V , and on the 4th 1.4v slot - and 2V - the charger display shows the constant lower voltage value.
    I also measured the voltage when discharging the AAA battery and ...
    the BC700 is the same as on the display, i.e. 1.28V,
    and on the NC1000plus, for example, a 1.18V display, and a voltmeter on the charger contacts 1.28V !!! What's going on here?
    Is this a defect of the charger or is it the same for you?
    I will just add that my NC1000plus ended the discharge of the AAA battery in the 4th slot with a voltage on the display of 1.17V, which is clearly a disadvantage because the remaining slots reach 0.9V.
  • #14 16607356
    grzegorz041
    Help: 7
    Rate: 142
    Welcome back. I purchased the NC-1000. Cool thing. Actually, it is such a small, very clever computer for charging batteries. Thanks a lot to everyone for your commitment and suggestions. Greetings
  • #15 16673438
    SPEAKERS_XP
    Help: 56
    Rate: 53
    I apologize in advance for a long absence, but for private reasons I could not look at the electrode forum earlier.
    1. The default current of 500 mA is, in my opinion, a big advantage of the NC-1000 Plus - for most AAA batteries it is fine, even less than 200 mA will cause problems with the proper completion of charging with larger AAA batteries (such as infinite charging noticed by mlero in the BC-700 charger), not to mention AA.
    2. Ni-MH batteries should, as a rule, be charged in pulses. The frequency, the filling of these pulses differs between different chargers, in some cases some meters have a problem with measuring such voltage at the output of the charger, the jumps will also be the greater, the higher the resistance of the inserted battery. What we can see on the chargers' display is the value measured between the pulses (the real value of the voltage on the battery). I would be far from faulting this place. I suggest using the discharge mode in NC-1000 Plus, wait until the process is finished and then compare the voltage value from the charger and the meter - without load, these values should be the same.
    The recalled voltage of 1.17V (measured without load) looks like the correct voltage of the discharged NiMH battery.
    3. ExtremeLine NC2000 looks like a Chinese noname, but if someone can borrow it, I will be happy to test it.
  • #16 16673488
    Freddy
    Help: 1394
    Rate: 2821
    I once bought liitokala 500 and I am very happy with it.
  • #17 16673957
    mlero
    I tested the chargers in turn:
    EverActive NC1000 plus,
    ExtremeLine NC2000
    EverActive NC3000 - the best and most accurate, and this one has stayed with me.
  • #18 16674062
    JaroPC
    Help: 18
    Rate: 38
    the first charger I bought is the NC-1000 +. I already have some time and I won't say a bad word about her. The author will surely be pleased. I recommend Fujitsu batteries, I use them in flashlights. They all have very similar capacities and I think they will work well when connected in series. I mention it because the repeatability of the capacity is not so obvious. I also have a set of Varta batteries. There are considerable discrepancies there. Fujitsu is said to produce its batteries in Japan.
  • #19 16676033
    grzegorz041
    Help: 7
    Rate: 142
    Hello again everyone. I can see that the topic is broadening with more statements. Cool. I haven't bought the rechargeable batteries yet. I picked up all the old ones and after turning on the refresh function I was able to regenerate them, to the point where they work very well. And I already used them to be lost. Certainly, if I need it, I will tempt you with these; Fujitsu. Greetings ....
  • #21 16802241
    mlero
    I have a question for owners of the EverActive NC3000 charger
    What voltage does the display show when the charger finishes charging and discharging?
    Mine ends charging when the display shows 1.56V, and the discharge shows 0.9V - regardless of the current, age and size of the battery.
    The presented battery capacities from charging and discharging performed immediately after charging differ significantly from each other:
    after charging the new VARTA AAA shows 1190mAh, and after discharging 1050mAh
    Eneloop AA shows 2190mAh when charged, and 1870mAh when discharged
    I know it takes a long time to spot the end of the process, but I've caught it a few times and it's always the same.
    I would like to add that the batteries at the end of charging are lukewarm or slightly warm even at a current of 0.5C.
  • #22 16802881
    mateusz2015_5102
    Pupil
    Rate: 81
    Panasonic eneloop, ever active and other chargers in electronics / household appliances stores are good.
    Or maybe it is best to use e.g. eneloop panadonic eneloop charger for varta batteries, varta chargers etc.
  • NC-1000+ thermistors and deep-discharge workaround
    #23 16805167
    Pemek
    Rate: 19
    Out of curiosity, I opened my NC-1000 + and my thermistors were properly installed. They fell into small pockets filled with conductive paste. The implementation of the tile is very solid and elegant.
    The disadvantages include a small display, you need to have good eyesight (or glasses) to see what is written there. Also the fact that it does not start working with fully discharged batteries. But this is not a big disadvantage, it is enough to have an old, ordinary charger and charge it for a few minutes, put it into the NC-1000 + and it's OK.
    I recommend checking the websites:
    http://ladowarki.com/porownanie-ladowarek-pro...ni-mh-nc-1000-bc-1000-bc-700-mh-c9000-nc-3000
    http://everactive.pl/Ladowarka-NC-1000-polecana-przez-serwis-PCWORLD.PL!
  • #24 16854790
    buhehe12
    Hello!
    I am trying to buy a charger and a battery.
    I think I will take the everActive NC-1000 PLUS charger, but I have no idea what batteries to take.
    I need the LR03 which I use for the headlamps, so it fits reasonably well.
    For this also lr6 for pilots, etc.
    Does anyone have any specific and proven battery models?
  • #25 16854825
    Freddy
    Help: 1394
    Rate: 2821
    Maybe make yourself a charger for AA and AAA, it's not that difficult, for example on the MAX712 or the old TC675.
  • #26 16854951
    rafbid
    Help: 153
    Rate: 418
    buhehe12 wrote:
    to the pilots
    Rechargeable batteries are uneconomical for pilots. You probably replace the batteries every few years?
  • #27 16858112
    buhehe12
    rafbid wrote:
    buhehe12 wrote:
    to the pilots
    All in all, I will give these LR06 lamps to such battery lamps, they fall off quite quickly.
    As I wrote, I need LR03 for two headlamps, 3 batteries for one, because the usual ones are dead.
    As for the charger, I have an old Panasonic BQ-2FE.
    230V 50 HZ 5W
    2.8V-220mAx2 (R6)
    2.8V-65mAx2 (R03)
    It is not good for anything, is it?
  • #28 17101601
    buhehe12
    Can I ask for help?
  • #29 17101719
    grzegorz041
    Help: 7
    Rate: 142
    Hello. Hi. I bought the everActive NC-1000 charger and Eneloop PRO rechargeable batteries. In the camera, for me, great thing. For the flash, I think they work extra. They can withstand a lot.
    As far as I know and read a bit, the eneloop R6 (the white ones) also works well.
    But a good charger is essential - it's worth the investment.
  • #30 17112209
    SPEAKERS_XP
    Help: 56
    Rate: 53
    230V 50 HZ 5W
    2.8V-220mAx2 (R6)
    2.8V-65mAx2 (R03)
    The charger is very simple - it is time-based - there is no meaningful automation in it, it also only charges in pairs. With frequent recharging of the batteries, it is better to look for something automatic with the possibility of charging odd amounts.
The discussion centers around the selection of AA and AAA battery chargers, specifically comparing the NC-3000, Varta LCD, and Eneloop Pro. Users share their experiences and recommendations, highlighting the NC-3000 as a top choice despite its higher price (PLN 130). The Varta LCD charger is criticized for its limitation of charging batteries in pairs, which can lead to uneven charging and premature battery wear. The BC-700 and MH-C9000 chargers are also mentioned, with the BC-700 noted for its reliability but outdated design. Users emphasize the importance of using high-quality rechargeable batteries, such as Eneloop and Fujitsu, and advise against cheaper, unknown brands. The discussion also touches on the charging characteristics of Ni-MH batteries, including the acceptable temperature rise during charging and the need for proper charging algorithms to avoid overcharging.
TL;DR: Eneloop Pro AA retain 85 % capacity after 1 year (Panasonic); meanwhile, “NC-1000 is my favorite” [Elektroda, SPEAKERS_XP, post #16313266] Pick single-slot smart chargers (NC-1000/3000) to avoid hot, under-charged pairs and extend battery life [Elektroda, grzegorz041, post #16311439]
Why it matters: The right charger adds years to cells, saves money, and prevents dangerous overheating.
• NC-1000 adjustable charge current: 200–1000 mA in 100 mA steps [NC-1000 Manual]. • NC-3000 adds internal-resistance test (20–200 mΩ range) [Elektroda, SPEAKERS_XP, post #16313266] • BC-700 default current 200 mA; street price ≈ PLN 80 [Elektroda, mlero, post #16580771] • Some no-name AA claim 3000 mAh yet measure <300 mAh—10× lower [Elektroda, SPEAKERS_XP, post #16313490] • Eneloop Pro AA 4-pack costs approx. PLN 60, rated 2500 mAh LSD [Panasonic Datasheet].
1. Why use a processor (smart) charger instead of a simple timer model?
Smart chargers monitor voltage, temperature and −ΔV, stopping at full charge, so cells last hundreds more cycles. Timer units ignore battery state, often boil one cell while undercharging another, shortening life [Elektroda, SPEAKERS_XP, post #16313555]
3. Is the MH-C9000 worth paying extra?
For most users, no. Its algorithm ends charge earlier than BC-700, despite higher ±1 % meter precision; price is 2-3× BC-700 [Elektroda, SPEAKERS_XP, post #16313266]
4. What current should I select for AA and AAA cells?
Use 0.3–0.5 C. On NC-1000 the default 500 mA suits most AAA and AA; currents below 200 mA can cause never-ending charge on high-capacity AAA [Elektroda, SPEAKERS_XP, post #16673438]
5. Can pair-only chargers really damage batteries?
Yes. They treat two cells as one pack. If capacities differ, one cell overheats >20 °C while its twin stays under-charged, accelerating sulphation and loss of capacity [Elektroda, SPEAKERS_XP, post #16313555]
6. How do I revive old Ni-MH with the Refresh cycle?
  1. Insert cells and choose “Refresh” (or “Break-In”).
  2. Charger performs slow charge, full discharge, then gentle recharge.
  3. Repeat 2–3 times; capacity often recovers 5–15 % [Elektroda, grzegorz041, post #16676033]
8. Why does my NC-3000 show higher charge than discharge capacity?
Display shows input to cell during pulses; discharge shows usable output. Heat and internal resistance waste 8-15 % energy, so readings differ [Elektroda, mlero, post #16802241] "Losses are normal," notes HKJ’s test lygte-info. Values within 15 % are acceptable.
9. What temperature rise is normal while charging?
A clear temperature lift at the end—cells feel warm (≈45 °C) but not hot—indicates full charge. No rise suggests termination too early; scorching hot (>60 °C) implies overcharge risk [Elektroda, SPEAKERS_XP, post #16313555]
10. Are 3000 mAh AA cells advertised online real?
No. Laboratory tests find many deliver only 200–300 mAh—10 × less than the label [Elektroda, SPEAKERS_XP, post #16313490] Stick to brands quoting ≤2600 mAh for AA.
11. My NC-1000 won’t start on fully-dead cells—what now?
Slots need about 0.5 V to detect a battery. Pre-charge two minutes in any dumb charger or in a flashlight, then retry; detection succeeds [Elektroda, Pemek, post #16805167]
12. Should I fully discharge Ni-MH before storage?
Store at 40-60 % charge in a cool place. Fully flat cells may reverse during self-discharge; full cells lose capacity faster [IEC 61951-2]. Recharge every 6 months.
13. Can I build my own AA/AAA charger instead?
Possible using ICs like MAX712 or TC675, but you need thermal sensing, −ΔV logic and independent channels. Buying an NC-1000 costs less than sourcing parts today [Elektroda, Freddy, post #16854825]
14. What’s an edge case where NC-1000 fails?
Early NC-1000 Plus units ended discharge in slot 4 at 1.17 V instead of 0.9 V, giving 20 % low capacity readings; warranty replacement fixed it [Elektroda, mlero, post #16580771]
