[Solved] Windows 10 Update Error 0x8024a11a: Solutions for 64-bit Home vers. 1709 (KB4056892) Issue
przemek345rukat 10062 4
  • #1 16945729
    przemek345rukat
    Rate: 23
    Hi, I have a problem with the update for windows 10 64 bit home vers. 1709 (kb4056892). In the update window, I choose restart now to apply the update, but after a long time I get the message: There was a problem restarting to complete the installation. Please try again in a moment. If this problem persists, search the Internet or contact us
    technical support for assistance. The error code may be useful: (0x8024a11a). I do as instructed, but nothing helps or I found no clue. Can enter the local services, system event broker and windows update - properties, stop and on drive C in the windows folder referred to as the Boot folder referred to as the Softwaredistribution folder change the name to Softwaredistribution.Old and restart the event broker?
  • #2 16945784
    nuszek
    Level 30  
    Help: 123
    Rate: 389
    Taken out of the Dell box, during update 1709, five / 5 / times, he told me that the update error had already installed update 1709 without a problem the fifth time.
    Colleagues told me to act until successful, so probably this update 1709 has it.
  • #4 17101001
    przemek345rukat
    Rate: 23
    Thanks for the help of nuszek and joy, several attempts to settle the topic.
  • #5 17101006
    przemek345rukat
    Rate: 23
    Thanks to nuszek and radwoc, several reboots will do the trick.
