[Solved] Windows 10 after updating to 1803 blocked the ability to print error 0x00000bbb
k45i89o98j66 13305 1
  • #1 17273457
    k45i89o98j66
    Help: 538
    Rate: 990
    Dell laptop. After upgrading to Windows 1803, it is not possible to print to any local or network printer. When trying to print a test page, the message: operation could not be completed (error 0x00000bbb). Unable to create a print job - the operation could not be completed (error 0x00000bbb). Unable to create print job.
    Restarting the print spooler, deleting jobs and printers, uninstalling all printers, changing registry entries does not help.
    The methods from the hp forum and from these links also don't work.
    https://www.youtube.com/watch?v=I0br3hUqfYw
    https://www.youtube.com/watch?v=l0ZopPl9mW0
    Only remains likely:
    Restore the system from before the 1803 update
    Clean windows installation
    Maybe someone was working on this topic relatively fresh?
    Added after 49 [minutes]:
    it didn't work either:
    After trying EVERYTHING and spending a full day with MS Support - here is the resolution if your issue was preceeded by a Windows 10 update
    WINDOWS start
    cmd.exe
    enter
    right click to execute as Administrator
    type
    cd \ Windows \ System32 \ spool
    enter
    type
    cacls.exe PRINTERS / E / G administrator: C
    enter
    Reboot
    Should work. If issues persist, you may want to also execute the above, substitute your user name for "administrator" in this line:
    cacls.exe ....
    WE CAN PRINT AGAIN !!!!!
  • #2 17274257
    k45i89o98j66
    Help: 538
    Rate: 990
    WINDOWS start
    cmd.exe
    enter
    type
    enter
    type
    enter
    Reboot
    cacls.exe ....
    Added after 7 [hours] 8 [minutes]:
    Delete all printers from the system.
    Remove all printer drivers from the system, including additional programs for printer drivers (especially from the HP family).
    Delete all entries for manually installed and old and new printers from the registry.
    Scan the CCleaner registry.
    Reboot the system.
    Add printers or a printer again.
    And you can print it all again.
