adata su800 - After cloning the system to ssd, Windows does not start
micziliczi 4977 5
  • #1 16954161
    micziliczi
    I decided to change the drive to ssd. The choice fell on the ADATA SU800 256gb. I did recovery on the existing hdd disk so that the system was not cluttered and cloned the partition to the ssd via usb -> sata. Then I removed the old hdd and installed a new ssd. Unfortunately, after booting, the system does not want to start. Message appears:
    PXE - E61 TEST FAILURE CHECK CABLE
    PXE -M07 EXITING ROARDCOM PXE ROM
    I will just add that in Bios the disk is visible and is set as first.
    Thanks in advance for your help!
  • #2 16954206
    Matuzalem
    Help: 1653
    Rate: 1101
    The disk may be set first, but the messages you cite refer to network boot attempts with no trace of another source in them.
    PS
    Perhaps it would be easier to "guess" if at least the motherboard and source disk models were known (because the system is definitely redundant).
    Doradztwo podatkowe
    Wilczyńskiego 25/13, Olsztyn, 10-686
  • #3 16954210
    sylweksylwina
    Help: 1882
    Rate: 2355
    And whether the system was installed in EFI or CSM.
  • #4 16954328
    micziliczi
    As for the motherboard, I put a screen.
    I installed the system from the hidden hdd partition and then cloned to ssd.
  • #5 16954364
    Matuzalem
    Help: 1653
    Rate: 1101
    This is not a response to what Mr. sylweksylvania wrote - it's once. Two - and exactly what you have cloned - number and names, or size of partitions. Lest it turn out that the operation only affected C: \.
    PS
    The system remains redundant as it was. Eh!
    Doradztwo podatkowe
  • #6 16966128
    micziliczi
    Problem solved - everything works.
    It turned out that I cloned the disk incorrectly. I only moved the system partition and I should have cloned the entire disk.
    Subject to be closed.
