Hello. I have a problem with the ZTE MF910 router. Namely, the Router works, it grabs the range, it connects to the network. But you can't connect to it via wi-fi, the phone, console, or the computer doesn't catch the router, only via a USB cable, you can connect to the Internet. I tried to remove the sim card, it did not help, I pressed the Reset button, it did not help, the factory reset did nothing. Anything else you can do? Is Router Down?
Reaktor6
Reaktor6
Rate: 15
