[Solved] Seat Leon 1m 1.9i - Battery Charging Indicator Inconsistency During Start and Drive
Baca1988 16095 5
  • #1 16967058
    Baca1988
    Level 4  
    Rate: 134
    I have the following problem in my 1.9 1.9i Seat
    The battery charging indicator has been lit for some time
    The problem occurs as follows
    When starting the car (not every one) the battery indicator does not go out, it only turns off after driving a few kilometers
    It happens that I start the car, the disgust indicator will go off but will come on while driving and go off after driving a few kilometers
    I will check the charge tomorrow with the light on
    What else should you pay attention to?
  • #2 16967083
    rob4028
    Help: 66
    Rate: 472
    If there is no charging on the lit indicator, the second thing to check is the alternator, more precisely the brushes.
  • #3 16967407
    Baca1988
    Level 4  
    Rate: 134
    Hello, today I started the car and the light went out of disgust, tension on the load and without it
    is about 14.2 / 14.3 V
    I will go and see how it will last until the indicator lights up, then I will check on
    RADU23
    Help: 2428
    Rate: 1732
    I had exactly the same. Alternator regeneration solved the problem.
  • #5 16969652
    Baca1988
    Level 4  
    Rate: 134
    I bet on that too, but for now I have silence, let it not be before the storm ?
  • #6 17373957
    Baca1988
    Level 4  
    Rate: 134
    The reason is a broken alternator, regeneration solved the problem
