Seat Leon 1P 1.6 MPI - What is this device? Discharges the battery.
artur_r0 33606 9
Why does the secondary air pump in a Seat Leon 1P 1.6 MPI switch on by itself with the ignition off and drain the battery?
This is the secondary air pump, and the most likely cause is a faulty relay in the under-hood fuse/relay box. It should only run on a cold engine while the engine is operating, so if it starts with the ignition off the relay or its control circuit is malfunctioning [#16408827] One reply noted that if the relay is being triggered without ignition, the fault may also be in the relay box, the control wire from the engine controller touching ground, or possibly the engine control unit itself [#16411157] The original poster reported that disconnecting the battery overnight made the problem disappear temporarily, which is consistent with an intermittent relay fault [#16411142] In the end, the problem was confirmed to be a broken relay, and replacing it with a new one fixed the issue [#16424227]
  • #1 16408778
    artur_r0
    Rate: 38
    Today there was a problem with my Seat Leon 1P 1.6 BSE 2007 - a few hours after the last drive I found a car with a completely discharged battery - the central locking did not work, after turning the key in the ignition switch zero response.
    After charging the battery, I noticed that the engine (pictures below) is starting / trying to start every now and then. This happens when the engine and ignition are off. What device is this? Has anyone encountered such a problem?
    Thanks in advance for your help. Greetings. ;)
    ociz
    Help: 1379
    Rate: 3484
    Secondary air pump. It blows into the exhalation so that the catalyst heats up faster. It is to turn on only on a cold, running engine.
    Most likely, only the relay in the box under the hood will be damaged.
  • #3 16411142
    artur_r0
    Rate: 38
    Thank you very much. I disconnected the battery overnight so that it would not run out and after 12 hours when I connected it again, the problem disappeared. Is it possible for the relay to "hang" and return to normal operation after such a stop?
  • #4 16411156
    dabu
    Level 32  
    Help: 190
    Rate: 695
    Recently, I was firing a discharged leon with the same engine and also the same problem, the air pump turned on without the ignition switch, only after a few hours the pump did not start. Maybe some babol in the driver?
  • #5 16411157
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5050
    No, if it stuck it would stick all the time.
    If this pump tried to turn on without the ignition on, the problem is rather in the box where the fuse is or with the cable that controls this relay from the engine controller, it touches the ground somewhere. Unless something is wrong with the engine driver.
  • #6 16411367
    ociz
    Help: 1379
    Rate: 3484
    Rather, I would expect a broken anchor or spring itself.
    grala1 wrote:
    or with a wire that controls this relay from the engine controller, it touches the ground somewhere.
    At most, plus, because on the other hand you won't get it without turning on the ignition.
  • #7 16417143
    dabu
    Level 32  
    Help: 190
    Rate: 695
    In this case, after fastening the clamp clearly clicks the relay, but something causes its activation.
  • #8 16424227
    artur_r0
    Rate: 38
    Thanks for the help. In fact, the problem was a broken relay - after replacing it with a new one, it does not occur.
    Greetings.
  • #9 17097007
    kacprus
    Hi.
    Hey can you please take the picture of the relay? Where is it in Leon? In my seat, it is apparently built into a fan :(
    I had the same problem in November 2017. The mechanic replaced the coolant temperature sensor. The problem stopped. Today I got a check engine - I checked a simple program error P0491, after leaving the garage, - secondary air pump. After checking the fuses, the pillow lamp also lights up, it is not known why. I do not have a cable for the VAG interface so I will not delete the pillow error myself.
    My car is Seat Altea 1.6 petrol from 2008.
    I wonder where this driver is at your place.
    I will also replace the fuse from this pump and see what happens.
    A visit to the workshop is inevitable but maybe I will learn something from you.
  • #10 17097028
    artur_r0
    Rate: 38
    kacprus wrote:
    Hi.
    Now I can't take a picture of the box and the relay itself. I will try to send tomorrow. In Leon, the box with this relay is under the hood, and from what I managed to read in Altea is exactly the same. In the first photo I marked in green the place where the fuse box - relays is. In the second photo you have a diagram where the relay from the secondary air pump in Altea should be located.
✨ The discussion revolves around a battery discharge issue in a 2007 Seat Leon 1P 1.6 BSE. The user reported that the car's battery was completely drained after a few hours of inactivity, with no response from the ignition switch. After recharging the battery, the engine attempted to start intermittently even when the ignition was off. Responses identified the secondary air pump as the likely culprit, which is designed to operate only when the engine is cold. A faulty relay was suggested as a potential cause for the pump's unintended activation. After disconnecting the battery overnight, the problem temporarily resolved, but it was confirmed that a broken relay was the root cause. The user successfully replaced the relay, eliminating the issue.
