[Solved] Best Pneumatic Wrench for PLN 300-350: Home Garage Use, Car Wheels and Suspension, 150L Compressor
marek49ae 4752 5
  • #1 16976967
    marek49ae
    Help: 57
    Rate: 254
    Hello, there are a lot of topics about keys, most of them old, and the technique is moving forward. I need a pneumatic wrench, for occasional use in a home garage, for unscrewing and tightening the wheels in a passenger car, and maybe sometimes some suspension. Certainly, the key will not be used often, the budget is PLN 300-350. I have a compressor with a 150 liter cylinder, the actual capacity is 450 liters per minute, at a pressure of 8 atmospheres. I am asking for advice.
    Agnieszka_Plesiewicz
    Rate: 8
    I am the owner of the SATRA 1500NM pneumatic impact wrench, the cost is about PLN 350. I have it for two years, it works well, I have no problem. I use it sporadically, chewing 3 sets of tires for winter, summer, sometimes some suspensions or unscrew the screws.
  • #3 16977378
    marek49ae
    Help: 57
    Rate: 254
    Thanks, mate. Does anyone use a BJC key?
  • #4 16979622
    marek49ae
    Help: 57
    Rate: 254
    Satra-Bjc key was purchased.
  • #5 16986609
    marek49ae
    Help: 57
    Rate: 254
    So . The wrench tried, the wheel studs were unscrewed without a hitch, the old rusty M12 bolts were unscrewed, the M14 cut off the bolt's head. A toy worth its price.
  • #6 16999813
    marek49ae
    Help: 57
    Rate: 254
    A BJC key was purchased, it works without problems, it has the power to unscrew and tighten. Adequate price for the product.
