Best Color Laser Printer for Home Use: Affordable & Efficient – OKI C511dn, HP, Canon, Samsung
MrxPL 25608 12
What affordable color printer or multifunction device should I buy for sporadic home use, with low running costs and a possible scanner?
The thread leans toward a used Konica Minolta bizhub C35 if you want cheap operation, and some users also suggest Epson EcoTank instead of a cheap consumer laser. The bizhub C35 was described as the most sensible option on the market, with original toners around 90 PLN for 6 pages and the device itself starting at about 1500 PLN used [#16983289] [#16983447] One reply also noted the general rule that the cheaper the device, the more expensive it is to run [#16978128] As an alternative, Epson EcoTank was recommended because 70 ml of ink costs about 25 PLN, and one user reported two years of use with less than half the ink consumed [#16983645] However, others warned that modern inkjets can be disposable when they fail, so for sporadic printing they preferred a laser or business-class machine [#16983554] [#16983632]
  • #1 16978030
    MrxPL
    Rate: 17
    I am looking for a home printer (or possibly a multifunctional device), in the price of 1000-1200 PLN (but if it will be much cheaper then even better) which will be reasonably cheap in operation. It will be used sporadically (10 sheets per week, but maybe 100 on one day, but it's rather once a year)
    I keep an eye on OKI C511dn which costs PLN 650. However, I read that although the replacements are quite cheap (alllegro set of 150 PLN) then there may be some circuses with inks. At least that's how I read about its predecessor C301 / C311dn. Maybe I'm wrong.
    Maybe some HP? However, when I looked (superficially) on the prices of alternatives on the allegro to different models, they were not the lowest.
    Canon, Samsung?
    I completely do not know in printers (specific models) so I look at these replacement prices for now.
    As for the multifunctional device, the scanner would come in handy (sometimes there is a need to scan something), because now I have a separate Canon, but I know there is not enough space. So if there's something interesting about this price, I'm asking for some suggestions.
    Thanks for the answer.
  • #2 16978128
    DiZMar
    Help: 2891
    Rate: 6648
    The approximate rule works: The cheaper the device, the more expensive it is . And vice versa.
  • #3 16983289
    zen3x
    Help: 231
    Rate: 291
    purchase of bizhub c35 - toners of 90 PLN for 6 pages of course original. The device itself from PLN 1500 must be given, of course, used.
  • #4 16983447
    suri1986
    Help: 49
    Rate: 68
    I am also a C35 supporter - so far nothing is more sensible on the market.
  • #5 16983505
    płetwa
    Help: 165
    Rate: 551
    Why laser (if colored)? I faced the dilemma of buying a printer in December 2016.
    After a quick market analysis, the choice fell on a printer with a permanent ink supply system (CISS). I bought a Brother DCP-T 500 W because I wanted WIFI. For over a year, the printer printed 658 pages including 30-40 photos, including 8 A4 photos.
    All that went on all this ink: Best Color Laser Printer for Home Use: Affordable & Efficient – OKI C511dn, HP, Canon, Samsung
    Since the novelty has not been added, in the set were two black and one color.
    The price is new the original The set (you can buy one at a time) is not the entire 100 PLN.
    https://www.123drukuj.pl/Tusze-do-drukarek/Brother/Symbol-drukarki/DCP/DCP-T500W-p369776.html
  • #6 16983554
    suri1986
    Help: 49
    Rate: 68
    Only that inkjet devices, unfortunately, are for the first failure. Then they should be thrown away.
  • #7 16983571
    płetwa
    Help: 165
    Rate: 551
    I bought the HP 840 in 2001, and stopped working before buying the above-mentioned - 15 years, believe me I threw away without regret. UPsss, I did not throw away I dismantled the parts.
  • #8 16983632
    suri1986
    Help: 49
    Rate: 68
    We are talking about devices manufactured today. Yes, we're repairing the older inkjet, but the newer generation is an endless scrap! I change it every day.
  • #10 16983655
    płetwa
    Help: 165
    Rate: 551
    What can I expect? Please refer to my model, what should I be careful about.
  • #11 16983693
    suri1986
    Help: 49
    Rate: 68
    You know, it's hard to talk about someone who printed 658 pages. In addition, on one beautiful day the formater will just fall and repair will not be profitable - the new one will be cheaper. But in general we deviate from the subject.
  • #12 16983753
    płetwa
    Help: 165
    Rate: 551
    What does it have to do with it?
    I do not think so, on the contrary it can make the choice easier.
  • #13 16986581
    MrxPL
    Rate: 17
    Thanks for all the answers. I read a bit and took Brother DCP-9015CDW. Bizhub is a very good option from what I managed to orientate but it was supposed to be new necessarily (and not too big for that, and it is probably a bit bigger than Brother), although after two years Brother will do it, why not. And as for the inkjet I sometimes print occasionally so I have doubts if the spit would last me.
    A thread unless you close it, unless it can be useful to someone who faces a similar dilemma
The discussion revolves around selecting an affordable and efficient color laser printer for home use, with a budget of 1000-1200 PLN. The OKI C511dn is highlighted as a potential choice due to its low replacement costs, although concerns about operational issues with its predecessors are noted. Other brands considered include HP, Canon, and Samsung, with some users advocating for the Brother DCP-T 500 W and Brother DCP-9015CDW for their cost-effective ink solutions and multifunction capabilities. The conversation also touches on the reliability of inkjet versus laser printers, with some users expressing skepticism about the longevity of newer inkjet models. Ultimately, the Brother DCP-9015CDW was chosen by the original poster for its balance of features and price.
TL;DR: Home users printing ~10 pages/week saw "For over a year, the printer printed 658 pages" on a CISS inkjet; lasers avoid clogs but watch running costs. [Elektroda, płetwa, post #16983505]
Why it matters: This FAQ helps budget‑minded buyers choose a reliable home color printer or MFP without surprise costs.
What’s the best color laser printer for home under 1200 PLN?
Prioritize low running costs and reliability. The thread starter ended up choosing a new Brother DCP‑9015CDW for a compact, home‑friendly color MFP. Consider models with duplex and network/Wi‑Fi if space and convenience matter. “The cheaper the device, the more expensive it is” remains a solid filter when comparing toner yields and unit prices. [Elektroda, MrxPL, post #16986581]
Is OKI C511dn a good budget pick and what about toner replacements?
It was seen around 650 PLN, making it attractive. The OP noted cheap third‑party sets on marketplaces but had read about "circuses" with consumables on related predecessors (C301/C311dn). If you choose it, verify chip compatibility and firmware before buying bulk toners. [Elektroda, MrxPL, post #16978030]
Should I consider a used Konica Minolta Bizhub C35 instead?
Some members endorsed the Bizhub C35 for sensible color printing, but typical listings started near 1500 PLN used, plus original toner costs. It’s larger than most home MFPs, so measure your space and factor service history. [Elektroda, zen3x, post #16983289]
Are inkjets viable for low‑volume home use?
Yes, if you pick tank/CISS models and print periodically. One user’s Brother DCP‑T500W printed 658 pages in just over a year on bundled inks. That supports very low cost per page and fewer cartridge swaps. [Elektroda, płetwa, post #16983505]
Are modern inkjets really unreliable compared with lasers?
A service‑oriented member reported that newer inkjets often aren’t worth repairing, calling many units “endless scrap.” For risk‑averse buyers, a color laser or a tank‑based inkjet reduces clog‑related headaches. [Elektroda, suri1986, post #16983632]
What is CISS and why does it matter?
CISS means Continuous Ink Supply System. Instead of small cartridges, you refill external tanks with bottled ink. Benefits include much lower cost per page and fewer replacements. Real‑world report: a Brother tank model handled everyday documents and photos inexpensively. [Elektroda, płetwa, post #16983505]
How cheap are EcoTank‑style inks in practice?
A user with two years of EcoTank experience cited 70 ml bottles at about 25 PLN and noted minimal ink use despite photo printing. That translates to very low ongoing costs for light‑to‑moderate home workloads. [Elektroda, roman106, post #16983645]
Laser vs inkjet for occasional bursts (like 100 pages in a day)?
A laser handles sporadic duty cycles well and avoids nozzle clogs during quiet weeks. If your baseline is ~10 pages weekly with rare 100‑page spikes, a compact color laser or robust tank inkjet both fit. Check space and consumable pricing. [Elektroda, MrxPL, post #16978030]
What did the original poster ultimately buy and why?
They chose a new Brother DCP‑9015CDW over a used Bizhub, citing the need for a new, not‑too‑large device. That aligns with home environments where footprint and warranty matter more than enterprise features. [Elektroda, MrxPL, post #16986581]
Quick 3‑step method to choose a home color printer?
  1. Set a hard budget and estimate monthly pages, including rare bursts.
  2. Compare cost per page and duty cycle; remember: “The cheaper the device, the more expensive it is.”
  3. Decide MFP vs single‑function based on scanning needs and space. [Elektroda, DiZMar, post #16978128]
Any failure risks I should know before buying?
One warning: a formatter (main board) can fail suddenly, making repairs uneconomical versus replacement. Keep receipts, consider extended warranties, and back up drivers/firmware to reduce downtime if that edge case hits. [Elektroda, suri1986, post #16983693]
Do I need a scanner or a full MFP at home?
If you occasionally scan forms, an MFP saves space versus a separate flatbed. The OP sought a scanner and resolved it with a compact color laser MFP, balancing footprint and features. [Elektroda, MrxPL, post #16978030]
Are marketplace toners safe to buy for older OKI models?
The OP flagged low‑cost sets but also reports of issues with predecessor series. If you buy third‑party consumables, test a single set first and avoid bulk until quality proves consistent. [Elektroda, MrxPL, post #16978030]
Is there a simple rule to balance device price and running cost?
Yes. “The cheaper the device, the more expensive it is.” Use that to weigh starter price against toner yields, drum costs, and expected lifespan. [Elektroda, DiZMar, post #16978128]
