Seeking Affordable, Compact Laser Printer for Daily Use: HP Atarmentówka Alternatives Under 200 PLN
5922 20
What compact black-and-white laser printer should I buy for daily occasional use on a budget of 200 PLN or less?
Buy a used monochrome laser printer rather than a cheap new one; forum users recommend older HP LaserJet models because they are durable, parts are cheap, and toner refills are widely available [#17551618] A particularly good find is a post-leasing HP 2015dn for about 100 PLN, with duplex and network, and the older HP LJ 1200/1300 family is also praised for lasting 80–100k pages and accepting 4–5 toner refills of about 10–12 PLN each [#17551618][#17536887] Another solid option is the Brother HL-2030 / DCP-7010 family, where toner for about 3000 pages costs around 30 PLN and the drum about 40 PLN, making running costs low [#17537561] If you prefer buying new, one reply suggests the cheapest new Samsung monochrome laser models, but notes starter toners have reduced yield, so the economics are worse than used gear [#16786613]
  • #1 16786305
  • #2 16786366
    sanfran
    Help: 963
    Rate: 3004
    A cheap printer is expensive consumables.
    Look for used equipment.
    I once bought a penny (equivalent of PLN 15) at the flea market at the epson epl6100 printer. I wanted to get it started and see what's inside. But when connected to a computer, it turned out that it prints. Admittedly pale and vertical stripes but I didn't give up I bought a toner powder (150g powder) at a similar price, cleaned the laser components, rotating mirrors, prisms and the printer started printing correctly. I already print 12 years. And at home, kids print things for school, work, etc. The counter when buying indicated 55,000 pages, now it has 10,000 more.
    Recently a colorful laser (Samsung CLP 365) appeared on the shelf for color prints, but Epson is not inferior in quality.
  • #3 16786512
  • #4 16786613
    sanfran
    Help: 963
    Rate: 3004
    If several pages per month, I suggest you buy something the cheapest, but new. Remember that new devices have so-called boot toners for a limited number of prints. For example, Samsung, whose normal toner lasts for about 1,500 pages in the boot version, allows you to print only about 500 pages. With 40 pages per month, it's enough for a year. Samsung MA is also quite cheap substitutes (I use substitutes myself)
    On the Media Markt website there are three monochrome laser printers for up to PLN 300. Compare other stores and choose something for yourself.
  • #5 16786680
  • #6 16824699
  • #7 17535592
  • #8 17535602
    kierbedz4
    Level 36  
    Help: 307
    Rate: 1008
    Search Konica Minolta 1600F printer portals. The new toner capacity is 4,000 prints. Cheap toner
  • #10 17535687
    kierbedz4
    Level 36  
    Help: 307
    Rate: 1008
    I buy new toners for the recommended printer for PLN 70 each.
  • #11 17535700
  • #12 17535932
    kierbedz4
    Level 36  
    Help: 307
    Rate: 1008
    At Allegro, regenerated toner for PLN 87.
  • #13 17536170
  • #14 17536192
    enhanced
    Help: 963
    Rate: 883
    I buy a cow oki b4350 for 11 zlotys + shipment or bigger about 30 zlotys.
    But it's a big old laser printer.
  • #15 17536862
  • #16 17536887
    enhanced
    Help: 963
    Rate: 883
    I have never done anything like that.
    I bought the printer in September 2011, a year ago I replaced the drum because it was dirty, so some PLN 150 went roughly + the smallest toner for PLN 10 + shipping (plus the second bigger one bought yesterday founded on 7k pages).
    So that he rests a lot though yesterday I wanted to print 127 pages (two pages per page) and there was no problem.
    So now of course you can easily buy it for PLN 200 with duplex (mine does not have it so if you want to play double-sided printing, you need to turn the pages).
    I am very pleased and most importantly there are no problems with the driver under 7 and probably and under newer systems will go. What used to be with disposable inkjet cartridges where you had to use the laser regularly is heaven and earth.
    From what I looked, she printed over 6,000 pages.
    USB has and LAN options could be purchased to connect directly to the rj45 router with a cable. Although I already had a USB cable to the router and the router supported it.
  • #17 17536972
  • #18 17537561
    Eidems
    Help: 83
    Rate: 253
    Multifunctional without duplex and network: I use DCP 7010 and it is armored equipment, cheap is used. As for the printer, I recommend the cousin HL 2030 and derivatives. Toner for 3 thousand pages PLN 30, beats the worn out HPki on the head (and has a drawer for cards not like HP from the 10XX series). The drum costs around PLN 40 and I only replaced it once. greetings
  • #19 17551471
  • #20 17551618
    Homo_toxicus
    Help: 76
    Rate: 375
    A year ago a colleague "hit" the post-leasing HP2015dn (duplex and network card) - PLN 100. Mileage, attention ... 58 pages. Factory cleanliness inside. Older HP models were durable and idiotic and by the way they perfectly tolerated replacements. The company still has several HP printers in use - LJ 1200/1300 models, 2001/2002 - they have not yet seen a screwdriver at mileages of 80-100 thousand. printed pages. Toner (replacement), with a skillful adding of powder, it withstands 4-5 "top-ups" (one "top-up" costs about 10-12 zlotys) which gives about 8-10 thousand pages, then you need to replace the slats and the drum or buy another replacement - 40 zł. Personally, I would not be afraid of used equipment, especially HP. I use two HP laser at home - LJ 1000 and LJ1150 recovered from the printer palette I bought a few years ago for all .... ro. For these printers, the cost of even new parts is low and availability is widespread. It is clear that what colleagues recommend is not inferior brands.
    PS Despite the age, most printers can run under Win7,8,10 systems. UPD drivers from HP give quite a lot of freedom with older equipment models.
  • Recommended page count and toner availability for HP2015dn
    #21 19578142
The discussion revolves around finding an affordable and compact laser printer under 200 PLN for daily black and white printing tasks. Users share experiences with various models, emphasizing the importance of low maintenance costs and reliability. Suggestions include looking for used printers, such as the Epson EPL6100 and older HP models like the LJ 1000 and LJ 1150, which are noted for their durability and low-cost toner options. Other recommended models include the Samsung ML-2165W, Samsung Xpress M2026W, Ricoh SP150W, and Konica Minolta 1600F. Users highlight the significance of toner availability and the potential for using refurbished or regenerated toners to reduce costs.
TL;DR: For light B&W duty, plan around starter toner yield: ~500 pages vs 1,500 on standard, and remember, “Remember that new devices have so-called boot toners for a limited number of prints.” [Elektroda, sanfran, post #16786613]
Why it matters: This FAQ helps home users pick a compact, low‑cost laser under 200 PLN and avoid consumable traps.
What’s the best compact laser under 200 PLN for occasional home printing?
Look for a clean, used mono laser with duplex if possible. HP LaserJet 2015dn often appears cheap and handles home needs well. Older HP units tolerate refills and parts are widely available. Inspect page count and test a demo page before buying. [Elektroda, Homo_toxicus, post #17551618]
Are cheap printers expensive to run?
Yes—consumables drive total cost. As one expert put it, “A cheap printer is expensive consumables.” Prioritize models with affordable toner and drums, or proven refill options. Used business lasers typically beat entry inkjets on cost and reliability for low monthly volumes. [Elektroda, sanfran, post #16786366]
How many pages will a starter (boot) toner really print?
Expect about 500 pages from a starter cartridge, while the standard cartridge for the same model may be rated near 1,500 pages. Plan purchases accordingly if you print 40 pages per month; a starter can last roughly a year. “Boot toners” are limited by design. [Elektroda, sanfran, post #16786613]
Is buying a used mono laser safe for light, infrequent printing?
Yes. Older HP business lasers are robust and tolerate refills. Example: a 2015dn found at 100 PLN, and LJ 1200/1300 units running 80–100k pages without major service. Verify condition and page count; very low mileage units exist. [Elektroda, Homo_toxicus, post #17551618]
Which Wi‑Fi models did users shortlist for small homes or dorms?
Community picks include Samsung Xpress M2026W, Ricoh SP 150w (USB + Wi‑Fi), and HP LaserJet Pro M12w. These are compact, B&W, and suitable for occasional use. Compare starter vs standard toner yields before purchase. [Elektroda, Anonymous, post #17535592]
Will older lasers work on Windows 7/8/10 64‑bit?
Often yes. Users report success using HP’s Universal Print Driver with many legacy LaserJets on Windows 7, 8, and 10. Always check the specific model and driver package before buying a used printer. [Elektroda, Homo_toxicus, post #17551618]
How do I revive a used laser that prints pale or with stripes?
Try this quick refurb:
  1. Clean laser path: mirrors, prisms, and lenses carefully.
  2. Refill with compatible toner powder; reseal properly.
  3. Test, then repeat cleaning if banding persists. Users restored full quality this way on flea‑market finds. [Elektroda, sanfran, post #16786366]
Is Konica Minolta 1600F a good budget pick?
One user recommends it for high‑capacity toner rated around 4,000 pages and low consumable costs. Check availability, size, and whether you need multifunction features. Confirm driver support before purchase. [Elektroda, kierbedz4, post #17535602]
Any driver gotchas I should know before buying used?
Yes. Edge case: a user flagged Konica Minolta 1600F as not compatible with Windows 7 64‑bit. Always verify 64‑bit drivers for your OS before paying, especially on older MFPs. [Elektroda, Anonymous, post #17536862]
Do lasers need periodic "exercise" if I print rarely?
Not necessarily. A user ran an OKI laser mostly idle, replaced a dirty drum after years, and continued printing thousands of pages without routine "keep‑alive" prints. Lasers store better than inkjets. [Elektroda, enhanced, post #17536887]
What monthly volume defines this use case?
The thread frames it as occasional use: about 50–100 pages per month, with a bigger annual batch. Size the printer and consumables to that range, not office workloads. [Elektroda, Anonymous, post #17536972]
What’s a simple cost plan for 40 pages per month?
A new printer’s starter toner can cover roughly a year at that volume. Budget next for a standard 1,500‑page cartridge, or select a model with low‑cost refills to minimize ongoing spend. [Elektroda, sanfran, post #16786613]
Where can I find low‑cost toner for budget setups?
Marketplace listings offer regenerated toner options. Example: an Allegro listing had regenerated toner for about 87 PLN. Validate seller ratings and return policy before buying. [Elektroda, kierbedz4, post #17535932]
Is Brother HL‑2030 a better bet than aging HP 10xx models?
One user prefers Brother HL‑2030, citing a real paper drawer and very low consumable costs: ~3,000‑page toner for ~30 PLN and a drum near 40 PLN. Reliability reported as strong. [Elektroda, Eidems, post #17537561]
What page count is acceptable when hunting an HP 2015dn today?
Lower is better. A standout find showed only 58 pages printed. These models are durable, and older HP lasers often run tens of thousands of pages reliably when maintained. Prioritize clean internals and low counters. [Elektroda, Homo_toxicus, post #17551618]
