Vordon 4.5 "- There is no access to GPS, autosart Automaps
Ibiszek 3570 5
  • #1 16560226
    Ibiszek
    Hello. A friend brought me the VORDON 4.5 "navigation to update her automapa. I downloaded her automapa as I had done a dozen times before on other devices. I try to turn on the device and it turns on. However, the automap does not start automatically (I set the path to it and it does not work). the problem is that after turning on the automapa, a message pops up: unable to access gps (com2)
    I am asking for advice on what to do to make the GPS catch and everything works as it should.
    Thank you in advance and best regards
  • #2 16560616
    jajacekpl
    Help: 65
    Rate: 268
    Most likely the factory menu / navigation program process is blocking the port.
    1. Write how you installed AM (on SD, in the device, what add-ons)
    2. How do you run Automapa?
    3. The port in Am is set to COM2 or AUTO?
  • #3 16560726
    koala106
    Help: 471
    Rate: 1240
    When choosing a path you have a tick - run automatically on startup - select it.
  • #4 16560894
    Ibiszek
    I marked this bird.
    After switching on the device shows the desktop and from there I start the automape (from the shortcut). And I installed it on the SD card and then installed the card in the device. The port in Automapa is set to COM2.
  • #5 16566730
    Ibiszek
    Automapa is already running :) I changed the COM port. Now I am just asking for help so that the automap is turned on automatically when the device is started. Because now the device turns on so that I can see the desktop and from it I have to start Automapa.
  • #6 16568173
    _Olivka
    Help: 81
    Rate: 158
    But I don't recommend doing this, you can blow the device.
