VORDON 7 HD Navigation: Updating Maps on Memory Card & Selecting SD Card Path Option
RobRa 6660 11
How can I update the maps on a Vordon 7 HD navigation device so it uses the maps on the SD card instead of Flash, and why doesn’t the SD card path option appear?
Update the maps through the Windows installer with the USB-connected device, where you should be able to choose the program location and the maps [#16411734] If you only want to move the maps, copy them into the correct folder used by the navigation program; for the navigation program itself, Vordon options point to the .exe file, not to the maps [#16411360] It is also acceptable to install Navigator on the SD card and then upload the new maps there [#16411817] If the card still does not show up as a path option, check that it is formatted as FAT or FAT32 and that it is visible when the device is connected by USB with the card inserted [#16411411]
  • #1 16410923
    RobRa
    Rate: 11
    Good morning
    I have a new Vordon 7 HD navigation and wanted to update the maps. I uploaded them to a memory card, but I don't know how to indicate that the navigation should use those on the card and not on Flash.
    The option of indicating the path does not show me the option SD card, only Flash.
    Do you have any suggestions?
    Regards,
    robert
  • #2 16411360
    jajacekpl
    Help: 65
    Rate: 268
    Updating maps or navigation program? Because it is something completely different (and a lot of people confuse these terms, so I prefer to make sure)
    You copy the maps to the correct folder in the navigation program.
    Navigation program - you specify the * .exe file in the Vordon options.
  • #3 16411411
    koala106
    Help: 471
    Rate: 1240
    And if you can't choose a card in the path settings, check it in what format the card is - FAT or FAT32. Connect the device under USB with the card inserted and check whether it is visible.
  • #4 16411637
    RobRa
    Rate: 11
    I want to update the maps themselves, not the program. The USB card is visible.
    I wanted to upload the maps to the same place as they are at the moment, but it turned out that there was not enough space.
  • #5 16411657
    koala106
    Help: 471
    Rate: 1240
    What navigation program?
  • #6 16411715
    RobRa
    Rate: 11
    Free navigator
  • #7 16411734
    koala106
    Help: 471
    Rate: 1240
    Update from Windows installer with a USB device. You should have a choice of program locations and maps.
  • #8 16411798
    RobRa
    Rate: 11
    I downloaded the installer on a desktop computer and through it uploaded maps to the SD card, but I do not know how to indicate navigation so that it uses maps on sd, not those in Flash. I think, don't install Navigator on SD and then upload new maps?
    koala106
    Help: 471
    Rate: 1240
    You can do it and it will be ok.
  • #10 16419702
    RobRa
    Rate: 11
    I installed Navigator on SD but I have a problem with ports. I didn't find it automatically, I switched it to manual, but I didn't find COM0. Any idea what to do about it?
    koala106
    Help: 471
    Rate: 1240
    Install the automap demo and let it scan. Set port and speed, set it.
  • #12 16434155
    RobRa
    Rate: 11
    OK, thanks for your help.
The discussion revolves around updating maps on the VORDON 7 HD navigation device using a memory card. The user, Robert, seeks guidance on how to configure the navigation system to utilize maps stored on the SD card instead of the internal Flash memory. Responses highlight the importance of ensuring the maps are placed in the correct folder and suggest checking the SD card's format (FAT or FAT32). It is noted that the navigation program must be specified correctly, and users can install the navigation software on the SD card to facilitate map updates. Additionally, issues with port detection when using the installed navigator are addressed, with suggestions to use the automap demo for scanning and setting the correct port and speed.
