Hi, The VSC, ESP, Brake (orange) and alternating Check parking brake and Check VSC system lights are on (as in the attached photos). After a reset (removing the minus clamp from the battery) the problem disappears and everything is OK for a while. The problem occurs intermittently. The car was connected to the computer at the service centre (just then the lights were not on) and no errors were found. Has anyone had a similar problem and how to diagnose it further?
krtadeusz1
krtadeusz1
Rate: 11
