Interpreting Volvo FH 12 440 2006 Dashboard Light: Circle with Dashed Stripes
H.A.R.B 18897 8
  • #1 16366936
    H.A.R.B
    Hello, today a message will light up on me which is the above mentioned circle and I do not know if it is about brake linings or maybe the ending clutch. Thank you in advance for your help. best regards
  • #2 16367218
    diablo23248
    Help: 102
    Rate: 614
    How such things are blocks or sensors to check.
  • #3 16367528
    H.A.R.B
    Do you mean pad wear sensors?
  • #4 16367650
  • #5 16367735
    Mar-Aur
    Rate: 29
    You can check the on-board computer, there is such an option.
  • #6 16368571
  • #7 16368669
    Mar-Aur
    Rate: 29
    There are protruding sticks on the brake calipers that show pad wear. As they stick out, the pads are OK, if they are flush with the clamp, they need to be replaced. After each replacement, you need to calibrate the pads, and for this you need efficient sensors. If the sensor were damaged, it would show a sensor error. FH has a self-diagnosis on the computer.
  • #8 16369467
  • #9 16369496
    Mar-Aur
    Rate: 29
    It's true how to exchange it only for the original. usually his fault is either a break or getting water.
The discussion revolves around the interpretation of a dashboard light in a 2006 Volvo FH 12 440, specifically a circle with dashed stripes, which is believed to indicate issues related to brake pad wear sensors. Participants suggest that the light is likely triggered by the pad wear sensor, and emphasize the importance of visually inspecting the brake pads to confirm their condition. They note that if the sensor is malfunctioning, it may not provide accurate information. The on-board computer can also be checked for diagnostics. Recommendations include using original sensors for replacements to avoid false signals and ensuring proper calibration after pad changes.
