Bosch SP150E35EU - error E15 after pouring ordinary washing-up liquid
majuDJ 17415 5
  • #1 16983640
    majuDJ
    Rate: 35
    I have a problem, someone poured ordinary dishwashing liquid and the dishwasher poured water with foam. There is error E15 and a blinking tap. The dishwasher is full of foam. I read in the forum that you should tilt it for a while at an angle of 45 degrees on the back, somewhere it was still written aside. Can it wait until morning and the dishwasher will run empty when the foam has settled? In another topic I found not to tilt https://www.elektroda.pl/rtvforum/topic2993811.html
  • #2 16983685
    zibi1971
    Home appliances specialist
    Help: 262
    Rate: 1120
    Apparently, adding ordinary soap causes it to stop foaming. Tilt the dishwasher on your back, wait a few seconds for the water to drain, turn on the rinse program itself to get rid of foam.
  • #3 16983722
    majuDJ
    Rate: 35
    After all, when I lean on my back, water can flow to some contacts and flood, for example, the engine or some mechanisms ????
    I will wait until the morning the foam drops and try to turn on and see if there will still be error E15.
  • #4 16983760
    GrzesiekF1
    Rate: 36
    The error will be as long as the water in the tray on the bottom of the dishwasher ;) If you are afraid to prime the pump or anything else, unscrew the plate on the right side of the dishwasher and select water. I use a sponge to wash dishes
  • #5 16983847
    majuDJ
    Rate: 35
    Well, I think I have to do it during the day, because I have a dishwasher built in so I need to know how it is screwed.
