How to add a soundtrack to a movie without affecting the quality of the movie
poszukiwaczpracy1 8745 6
  • #1 16984059
    poszukiwaczpracy1
    Rate: 9
    I would like to add a sound file with a Polish teacher to the film "Your Vincent" or, if you prefer, "Your Vincent". Google is full of such instructions, but then the quality of the film deteriorates and from 3 GB to 9 GB, and what is worse is blurry image. How to do it without interfering with codecs and format.
    How to enlarge a little so that the left and right edges reach the end of the screen. There is a function in the player to bring it closer but I would like to save such changes in the movie so that it plays without a combination in full screen
    Which program to add the sound and set the picture anyway. No matter whether free or commercial
  • #2 16984118
    DTRQ
    Help: 13
    Rate: 18
    Try this . I used to edit the soundtrack with it and it was OK.
    Regards, DTRQ
  • #4 16985008
    poszukiwaczpracy1
    Rate: 9
    How do I add a sound file to the player if I want to play it with the movie at the same time?
  • #5 16985080
    jarrod
    Help: 59
    Rate: 131
    so I gave such a program.
  • Filmora lacks DivX export despite installed codec
    #6 16998822
    poszukiwaczpracy1
    Rate: 9
    Why in Wondershare Filmora 8.5.1.4 there is no option to save the movie to DivX
    There is only XviD and Mpeg and Mp4
    After all, I have DivX installed on the system from the site
    http://www.divx.com/
    The original DivX converter can also convert materials, but it lacks a lot of goodies, such as transitions or special effects
    Windows 7 Ultimate SP1 64 bit
  • #7 17725352
    Vendeur
    Rate: 23
    I don't know why you wonder about strange programs, since you have the best MKVToolNix given above. Before you add a movie track without changing its quality. Besides, what DivX again? It's an outdated codec. Mp4 will be better in every respect.
    If you want to "enlarge" the movie, or rather cut these black stripes on all sides, then the best will be Avidemux. Only here you can not do it without changing the quality, otherwise the filter option is inactive, and it is in them that you choose the active field that is to remain, and the remaining part is cut off.
The discussion revolves around adding a soundtrack to the film "Your Vincent" without compromising video quality or increasing file size significantly. Users suggest using MKVToolNix for adding audio tracks without altering the original video quality. A follow-up inquiry addresses the challenge of playing the added sound file simultaneously with the movie. Additionally, there is a mention of Wondershare Filmora's limitations regarding saving in DivX format, with suggestions to consider MP4 as a more modern alternative. For cropping the video to eliminate black borders, Avidemux is recommended, although it may require quality adjustments.
