Convert DivX WMA Audio V2 for Samsung TV & Atoma Laptop: Lightweight Software Options for Older PCs
nioop 6165 5
  • #1 16749930
    nioop
    Home appliances specialist
    Help: 503
    Rate: 3342
    Hello..
    I have the serial "X" on my disc. An older laptop working on an Atoma and a Samsung TV with USB that does not read while playing the sound of the above-mentioned movie from a USB flash drive.
    The audio format of the file is DivX WMA Audio V2.
    He plays other movies without a problem, only he has a problem with that. The picture is played correctly only without sound
    My question - Can anyone recommend me a program that would change the audio format itself while keeping the same compression and file size?
    I tried VirtualDub, but after converting from 200MB it becomes 13GB.
    Please also keep in mind the computer I work on, it is an older machine, so the program cannot be demanding.
    Kawa i Naprawa - Serwis AGD
    LA72
    Help: 648
    Rate: 1664
    You probably set an uncompressed image in VirtualDub instead of Direct Stream Copy.
    Convert WMA audio to MP3 in AVI with VirtualDub
    #3 16750983
    AxelNext
    Help: 265
    Rate: 454
    @U.P.
    Exactly :D
    Do it this way:
    File - Open video file (we indicate the movie file)
    Video - Direct stream copy
    Audio - Full processing mode
    Audio - Compression -> LAME mp3 -> we indicate e.g. 44100 Hz, 128 kbps CBR, Stereo -> OK
    Audio - Conversion -> 44100 Hz -> OK
    File - Save as AVI
    LAME mp3 or "LAME ACM MP3 Codec" is downloaded from
    http://www.free-codecs.com/download/LAME_ACM_Codec.htm
  • #4 16751905
    nioop
    Help: 503
    Rate: 3342
    Naturally, thank you very much for your help ..
    Another issue that I would like to mention - There is an option in the above-mentioned program to upload a few / a dozen video files to change the compression or do I need each file separately?
    Selecting an open video before it makes it impossible to select several files, dragging the selected items onto the program window is also not possible.
  • #5 16751914
    LA72
    Help: 648
    Rate: 1664
    As the so-called multi-file harvester I recommend the free MediaCoder.
  • Recommend MediaCoder for batch video conversion
    #6 16751918
    AxelNext
    Help: 265
    Rate: 454
    nioop wrote:
    There is an option in the above-mentioned program to add a few / a dozen video files to change the compression or do I need each file separately?
    Separately.
    You can combine multiple files into one movie, but you have to add each file individually.
    Added after 5 [minutes]:
    I am commercial Aiseesoft Video Converter and Pavtube Video Converter :D
