Stuck Spring in Sewer Pipe: Removing WUKO Spiral from Basement Drain Grille (Detached House)
olek2601 22752 19
How can I remove a WUKO spiral that was left stuck in a basement drain pipe without breaking up the floor?
A stuck WUKO spiral can sometimes be removed without breaking the floor by grabbing the protruding end with the pusher and slowly feeding it out at minimum speed [#16996963] An inspection camera is useful to confirm exactly where the spiral is lodged and whether it is just stuck or actually broken inside the pipe [#16987640][#16991263] In this case, the problem turned out to be that the machine had been run at too high a speed on the pusher, so the spiral could not be pulled out that way; the second WUKO operator managed to release it correctly [#16996963] The floor did not need to be forged, because the removal was done without breaking it [#16996963] If the spiral had been broken or badly corroded, some replies warned that forging might still be necessary, but the first step should be to locate it precisely and try a controlled extraction [#16991263]
  • #1 16987150
    olek2601
    I have such a problem and I would ask someone wise to consult. A few days ago I had a small blockage in the sewer pipe in the basement of a detached house. WUKO arrived, they removed the blockage. Everything would seem OK. However, yesterday I discovered that they had left a spiral in the drain grille and pipe for unblocking. Does anyone know any way to remove such a spring? WUKO claims that the only way is forging in the basement floor, but somehow I don't trust them for obvious reasons. In addition, forging will be very troublesome and expensive because the floor is slabs and not screed.
    Thank you in advance for your answer.
  • #2 16987233
    Boryc2014
    Help: 21
    Rate: 90
    Hello. At the beginning I would do it or, as you've seen somewhere, bought some long pliers to catch and squeeze. I would even make a makeshift ribbed wire. Forging the floor does not make sense. Only what comes to my mind. Write the diameter of this pipe and how deeply this spring is stuck.
  • #3 16987268
    Radiokiller
    Level 30  
    Help: 156
    Rate: 237
    My idea is to remove the spring ........... with the second spring :D
    I imagine that you "crank" the recessed spring and it wraps around what's in it.
  • #4 16987335
    Loker
    Help: 575
    Rate: 722
    Wait - if they left the spring, let them pull it out. Forging? Let them forge, and then bring everything to their previous state.
  • #5 16987349
    Parowy
    Help: 55
    Rate: 227
    Welcome.
    olek2601 wrote:
    ... However, yesterday I discovered that they left a spiral in the sewage grille and pipe for unblocking ...
    If they've made it off, they should do it themselves.
    Why should you correct them?
    I understand that you may not trust them, but it's their concern to leave an efficient installation.
    Unless there's something else you haven't written about? :)
    edit:
    Loker colleague beat me :)
  • #6 16987408
    olek2601
    They want to forge, except that the basement is not used for screed, but for large panels, something like terrazzo, by the eye about 1.5x2m. If they start forging in such a record, in my opinion, it will crack and it will be glory. Probably later they would have to make the whole floor in the basement and it goes into thousands (basement + garage is about 40m2). In addition, I am not sure if the spring is exactly in the place that experts talk about. Apparently, some 6m of spring got stuck so a lot. It would be more convenient for me to get her out of it, but I don't know if it's possible. Maybe someone did such a miracle? I can tug on this today, maybe I can do it, damn it, it should come out.
  • #7 16987420
    Loker
    Help: 575
    Rate: 722
    As you wish. Two things:
    - somehow I can't imagine how this spring could get stuck - caught on something? About what?
    - hurry up with this pulling out, because if this spring starts to catch garbage then you will have such a blockage that without forging you will certainly not do without.
  • #8 16987432
    olek2601
    @Loker
    1. She had to catch something because they left her there and apparently it cost PLN 600, but nobody knows what. 3 pipes meet in the floor in one place, maybe there she stood on this tee.
    2. I just know, the morons have not said anything yet, and it has been lying there for a week. It is good that my wife did the laundry yesterday and checked the clothes, she saw a surprise.
  • #9 16987640
    RADU23
    Help: 2428
    Rate: 1732
    Let the inspection camera in and let everything be clear if it is exactly there.
    I had a similar case. The spring was folded from several pieces (it can be extended) and one of the attached segments detached and remained in the pipe.
    The guests let in an inspection camera and it was immediately obvious what and how.
    There is no unnecessary forging and undressing of side things.
  • #10 16987650
    olek2601
    And how did they get her out?
  • #11 16987651
  • #12 16987672
    RADU23
    Help: 2428
    Rate: 1732
    There was no problem because the installation goes under a suspended floor.
    So only one pipe element was dismantled and the spring was removed.
  • #13 16990079
    Tommy82
    Help: 455
    Rate: 1074
    But how is it you see it or do you know there is what you have access there don't you have any search along the way? maybe from the settler's side in the garden as you have. More details.
  • #14 16990367
    E8600
    Help: 530
    Rate: 2532
    Tommy82 wrote:
    More details.
    I support and some photo would be useful.
  • #15 16991263
  • #16 16991567
    Radiokiller
    Level 30  
    Help: 156
    Rate: 237
    I wrote that this is my idea and not a recommendation for a colleague of the author.
    However, I would try this way first with a feeling and a new spring.
  • #17 16991605
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6438
    If they could, they would pull it out, cut it off and leave it.
    Also it is very fast clogged with dirt and then it will be a lime.
  • #18 16991715
    KaW
    Help: 170
    Rate: 306
    Report the problem to WUKO. They work in it and have their own "patents" ...
  • #19 16993194
    jalop
    Help: 40
    Rate: 204
    Not only to report, but to write a complaint and support the one who left a viper.
    The spiral probably got stuck somewhere and they left it there, "and maybe nobody will notice?"
    My daughter rinsed the kitchen towel two months ago, traveled halfway and finished. After many fights for a rod welded to the viper, he finally managed to pull it out.
    It will not be so easy with a spiral. I estimate the chances at zero.
  • #20 16996963
    olek2601
    The problem was solved, luckily it was done without forging, but another WUKO employee did. He clipped the protruding spring into the pusher and released it at minimum speed. As it turned out earlier, they set too high revolutions on the plunger and that's why they couldn't. They were scared because they saw that the floor was terrazzo and forging would cost them a lot of money. The best part is that in his opinion, they didn't need this spring unnecessarily earlier, it could have been pushed through differently.
A user reported a problem with a WUKO spiral left in a sewer pipe after a blockage was cleared in their basement. The user expressed concerns about the proposed solution of forging the basement floor to retrieve the spring, fearing it would damage the terrazzo flooring. Various suggestions were made, including using long pliers or a second spring to retrieve the stuck spiral. Some participants advised the user to let WUKO handle the extraction, while others recommended using an inspection camera to assess the situation. Ultimately, another WUKO technician successfully removed the spring without damaging the floor by adjusting the equipment settings, indicating that the initial high revolutions were unnecessary.
TL;DR: A stuck sewer snake can be 6 m deep and still be removed without breaking the floor; “some 6m of spring got stuck.” [Elektroda, olek2601, post #16987408] Why it matters: Knowing non-destructive removal methods helps homeowners avoid costly slab demolition.
How do I remove a stuck WUKO spiral without breaking my basement floor?
Clip the protruding spiral to the pusher and run the machine at minimum speed while pulling steadily. This method freed the snake without any forging when the initial crew had set the speed too high. “Minimum speed” was the difference between stuck and out. [Elektroda, olek2601, post #16996963]
What is WUKO (in this context)?
In Polish plumbing slang on the forum, “WUKO” refers to the drain-cleaning crew and their powered snake/jetting equipment that cleared the blockage and left the spiral in the pipe. The discussion revolves around their method and follow-up. [Elektroda, olek2601, post #16987150]
Should I try a second spring to hook the first one?
Some users propose feeding a second spiral to wrap and retrieve the stuck one. However, if two spirals break in the pipe, extraction becomes far harder. Consider inspection first to avoid compounding failures. “If two springs are broken in the pipe, nothing will help.” [Elektroda, Anonymous, post #16991263]
When is an inspection camera worth it?
Use a camera to confirm the location and cause before any demolition. One case showed the snake was a detached segment, instantly visible on camera, which prevented unnecessary forging and guided targeted access. Visual confirmation saves time and floor finishes. [Elektroda, RADU23, post #16987640]
Could the spiral be 6 meters in and still come out?
Yes. The OP reported about 6 m of snake lodged from the floor drain and still achieved non-destructive removal once speed was corrected. Depth alone did not require forging. Accurate technique mattered more than distance. [Elektroda, olek2601, post #16987408]
What immediate risk does a left-in snake pose?
A lodged spiral quickly accumulates debris and can create a hard blockage. Waiting increases the chance you’ll need invasive access later. Act promptly to avoid turning a retrievable snake into a full obstruction. [Elektroda, Strumien swiadomosci swia, post #16991605]
Can I hold the original crew accountable for removal?
Forum consensus: yes. If they left the spring, they should remove it and restore the system. Some users insisted any forging and making-good should be their responsibility if needed. Document everything when you call them back. [Elektroda, Loker, post #16987335]
Could the snake have snagged on a pipe tee or corrosion?
Yes. The OP’s layout had three pipes meeting at one point, and another user noted corrosion as a catch point. Junctions and rough internal surfaces often trap coils during high-speed runs. Reduce speed and inspect. [Elektroda, Anonymous, post #16987651]
What if my floor is terrazzo or large panels—should I allow forging?
Avoid forging slab or terrazzo without precise location proof. The OP feared slab cracking and high restoration costs. Camera verification and low-speed extraction resolved the issue without floor damage. Preserve finishes whenever possible. [Elektroda, olek2601, post #16987408]
Is there a quick 3-step method to try first?
  1. Secure the exposed spiral end into the pusher/driver.
  2. Set the machine to minimum speed to avoid further snagging.
  3. Apply steady pull while driving slowly until the coil frees. This sequence worked without demolition. [Elektroda, olek2601, post #16996963]
Could modular snake segments detach and stay in the pipe?
Yes. One case described a multi-piece snake where a linked segment came loose and remained inside. Camera confirmation identified the detached piece and prevented unnecessary tearing out of structures. [Elektroda, RADU23, post #16987640]
How fast should I act if the spiral has been there a week?
Act now. The OP discovered the snake after about a week, and others warned that debris catch-up accelerates. Early action improves the odds of simple extraction and avoids slab work. [Elektroda, Loker, post #16987420]
What if access from another clean-out is available?
If you have a secondary access or outside clean-out, consider approaching from that direction after camera localization. This can let you push or retrieve the segment with less risk to interior finishes. [Elektroda, Tommy82, post #16990079]
Is forging ever the only solution?
If the snake is fully hooked, double-broken, or trapped at a junction, localized access may be necessary. Create an inspection opening at a measured distance, not a trench from the drain, to minimize damage. [Elektroda, Anonymous, post #16991263]
What finally solved the OP’s case?
A different WUKO operator clipped the spiral, ran the pusher at minimum speed, and withdrew it cleanly. He noted the spring was unnecessary for the earlier blockage and high RPMs caused the problem. [Elektroda, olek2601, post #16996963]
