Seeking Protocol Pattern for Induction Hob Connection: Authorized DIY Queries
dark_star_mario 43989 8
  • #1 16989291
    dark_star_mario
    Rate: 10
    Hello everyone in this forum. I have the authorization and I would like to connect the induction hob but I do not have the appropriate protocol pattern. Someone will help me because maybe he has one or will suggest how to write it or where to find it. Thanks in advance.
  • #2 16989302
    czareqpl
    Help: 196
    Rate: 580
    Such a protocol is usually supplied with the induction hob.
  • #3 16989303
    anet870
    Help: 67
    Rate: 248
    Make an entry and raise in warranty. If it is not present and the disc is used, you can write the protocol yourself. It must contain information such as the time and place of connection, device model, type of installation and who was connecting to whom.
  • #4 16989351
    dark_star_mario
    Rate: 10
    That is, it is not so complicated. Is there any protocol template?
  • Warranty-style installation record details needed
    #5 16989364
    retrofood
    Help: 1140
    Rate: 4798
    anet870 wrote:
    type of installation and who connected to whom.
    As in any such type of document, there should be data about who, what and how, i.e. date, place (address), equipment identification data, statement about the correctness of the connection and the possibility of power supply and first name with the name of the installer, PESEL, and the number of the qualification certificate .
    Anyway, just read the warranty provisions somewhere in the kitchen store and take them as a model.
  • #6 16990239
    dark_star_mario
    Rate: 10
    It even makes things a little easier. Is the stamp required for this or is it enough to enter the qualification number and surname?
  • #7 16990340
    kozi966
    Help: 599
    Rate: 1288
    dark_star_mario wrote:
    And a stamp is required for this
    The stamp is just a convenience.
    Your document is the paper with the number. The stamp is not a document. You can even enter your number with a finger smeared in paint and this is your certification.
  • #8 16990815
    kkas12
    Help: 1076
    Rate: 4313
    I filled today.
    required:
    - factory number of the device,
    - mounting address,
    - fitter's details (date, surname and first name, qualification certificate number) or company stamp.
  • #9 16991000
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1504
    Subject exhausted, I close.
The discussion revolves around the need for a protocol pattern for connecting an induction hob. Users suggest that such a protocol is typically provided with the device. If absent, it can be created by including essential details such as the connection date, location, device model, installation type, and installer information (name, qualification certificate number). A follow-up inquiry addresses whether a stamp is necessary, with responses indicating that while a stamp is convenient, it is not mandatory as long as the qualification number is included. Key required information for the protocol includes the factory number of the device, installation address, and fitter's details.
