[Solved] Mercedes A Class A170: SRS Error, Code 028 Driver's Airbag & 007 Driver Cushion Igniter Issue
bioly1 17253 2
  • #1 16994238
    bioly1
    Rate: 12
    I have a problem with this car. After firing up, the SRS indicator lights up after a few seconds. After connecting the tester displays error 028 - driver's airbag. So I took off the steering wheel cushion, tape and a new error appeared "driver cushion igniter" number 007. After plugging in the resistor error 007 disappeared and only 028 remains. And now the question what can it mean? Does my tester (Chinese VCI delphi) translate it properly? I was looking for codes on the internet but hard to find. When I enter the parameters, the condition of all pillows and other parameters is OK. What's the deal with this error because it comes out that it is not an error from the steering wheel cushion.
  • #2 16994386
    panscan
    Rate: 13
    check the plug under the armchair from the pyrotechnic pretensioner or armchair cushion or backing mat
    best regards
  • #3 17257824
    bioly1
    Rate: 12
    Replacing the tape helped so I close the topic.
