Reviving Opel Omega 2000's Auxiliary Heater: Eberspacher D3WZ Controller Diagnostics & Repair
GrzegorzWo 13410 3
  • #1 16994758
    GrzegorzWo
    Rate: 9
    Recently, I decided to bring an auxiliary heater back to life in my car (Opel Omega, 2.0 DTI, 2000, Hydronic D3WZ No. 25 2008). The booster heater has never worked before. After unscrewing the driver, it turned out that the candle needs to be replaced. All other components were operational - the fan was spinning, the pump was feeding fuel, the sensors (at 0 degrees Celsius) had parameters corresponding to the tabular values.
    After putting everything together, the additional heater was still silent (I connected it with power, ground, alternator excitation signal, air conditioning signal and a pump). I read that the controller locks up after 10 unsuccessful attempts - that is, it probably blocked many years ago when the candle burned. Unfortunately, disconnecting the power supply around the clock did not unlock the controller.
    I drove to the service in Krakow, which deals with Webasto / Eberami - unfortunately, after connecting, there was no communication between the stove and the modular clock (-: - all the time on the display). The man from the website suggested damage to the driver. Later, on the electrode I found the document "hydronic BD345WSC SS.pdf", in which I read how the procedure for unlocking and diagnosing this controller should look like.
    What you did from the website looked "a little different", including the fact that the watch was different than those mentioned in this document (a modular clock or a clock tester). As far as I could see, after connecting to the diag line, he pressed the "D" button but it was the middle button, not the first button on the left as in the test clock.
    In general, I have doubts if the man from the site tried to connect well (and if he had the right equipment for it), especially since I suspect blocking the driver. In connection with the above, I have a few questions.
    I think it's good to have a structured set of information about the Eberspacher D3WZ driver itself:
    1. One of the documents that describe Eber's diagnostics says that errors 015 and 050 - and therefore blockage - do not apply to the D3WZ additional heater.
    (I found a total of three similar instructions - Polish, English and German, this is the English document "Eberspacher_D3WZ_Hydronic_heater_workshop_manual.pdf", in the other two error numbers 015 and 050 are also marked with an asterisk, but there is no explanation of what this asterisk means). Is it true? Is D3WZ really not "blocking"? This would explain why in many cars it is enough to disconnect the power to the stove for a while - just to give it a chance to reset. Without it, he has the power connected all the time and remembers the faulty condition.
    2. However, if the physical controller lock occurs in D3WZ - how does it manifest? My Eber is silent, nothing clicks, does not whistle, etc. After connecting the power supply, it takes about 50 mA. The controller, after unplugging the internal plug and connecting the power supply, outputs +12 V on the fan pins of the internal plug (13 and 14) and consumes 0.5 mA. Connecting the fan and connecting the power supply means that +12 V on the fan pins does not appear anymore - to my taste it looks like a typical self test. Hence I suppose my driver is not dead.
    One more observation: when I connect the + 12V power line to the controller, + 12V also appears on the diag line, but if I connect the power supply and ground - the Diag line is pulled to ground. This would indicate that some basic control of this line takes place on the controller side. What does communication look like at all? Should the controller transmit something with the power connected,or maybe the waveform will be visible only after connecting the modular clock (which will probably be the master in this communication)?
    3. What can you do with the driver when it is locked? Is it possible to read errors on it (eg with the "D" button as you tried on the website)? Or maybe you need to perform the unlocking procedure first and then you will be able to read the errors? In fact, no instructions describe how the blockage of the controller manifests itself, except that the stove does not work.
    4. How can you 100% confirm that the driver is damaged (not blocked)? I read in a thread that someone was successful after a few attempts to unlock the unlocking procedure ... Are there any steps - further actions, current measurements, pin states, e.g. measured with an oscilloscope, etc., that allow you to confirm 100% that the controller is damaged? It would be worth confirming this in some way, before we start the time-consuming digging out the driver from the housing and from this jelly ...
    5. Can the controller without accessories (sensors, candle, fan, pump - i.e. with the internal plug disconnected) be diagnosed / unlocked? Or maybe you need a complete stove? Of course, the diagnostics will show errors related to the lack of individual components, but unlocking could be done ..
    6. Is it enough to connect only three lines for diagnostics / unlocking (power, ground and diag [blue and white])? Or maybe you also need an additional excitation signal and / or climatronics? (When I suggested on the website that maybe you need to unplug the stove from the car, because maybe something else is blocking the diag line, you said that it did not make sense, because all the other lines will also have to be dragged (pump, excitation, climatronics signal) ..
    7. Is there anything more than cold February happening in the damaged driver? Are there any standard controller failures caused by many years of stagnation? In the lower part, some pins of the internal plug are a bit tarnished (those from temperature sensors - I treated them with "S-Contact"), but nothing else. The wires are intact and healthy, the jelly is not burned out. As far as I read the forums, the most common damage (apart from cold solders) is the detachment of an element while cleaning the driver from jelly ... In one thread someone had a burned path from the candle - but this is probably not my case.
    8. Referring to my case, with a little theorizing:
    The candle was burnt, so once the stove worked (probably from 8 years ago or earlier). After burning the candle, the driver blocked after 10 unsuccessful attempts. Later, for 8 consecutive years, the power supply was still on, but it was blocked all the time due to a candle burning. Could the driver be damaged in this situation? In my opinion, not really ... At most those cold February, tarnished connections (because the inside of the furnace is not hermetic).
    Well, unless my driver was damaged in such a way that it did not cut off the power supply to the candle, causing it to burn ... That would be an option ..
    Or maybe there is some common cause of driver damage? If so - where to look for it (a transistor? A diode?)?
    9. I saw many threads about D3WZ - many photos of disassembled stoves and their drivers. I noticed that they often differ in their internal plugs - in some they are 10-pin rectangular in shape, in others 14-pin oval shaped (like in mine). Interestingly, the outputs of these oval plugs correspondthe conclusions described in the drivers from D5WS - are these drivers replaceable? Is there a list of D3WZ versions somewhere with the differences between their versions? Maybe, since the outputs are the same as in D5WS, then like D5WS - the driver may lock up?
    10. I saw on OLX that you can buy a modular clock for less than PLN 100.
    10.a) Is there a list of clock numbers with their parameters somewhere? I saw that they definitely differ in: supply voltage (12V / 24V), use in wet and dry heaters (which is equivalent to the presence or absence of a potentiometer) and the language version. So far I found such a list:
    22 1000 30 38 00 - Air Heater, EN, with potentiometer, 12 or 24V
    22 1000 30 40 00 - Air Heater, DE, with potentiometer, 12 or 24V
    22 1000 30 34 00 - Water Heater, EN, without potentiometer, 12 or 24V
    22 1000 30 36 00 - Water Heater, DE, without potentiometer, 12 or 24V
    I also saw (I will try to complete if I get more data):
    22 1000 30 44 00 -? ? without potentiometer, 12V
    22 1000 30 35 00 -? ? without a potentiometer,? V (it could have been an error in the number because I have not found such a marking anywhere)
    25 1483 73 00 00 -? ? without potentiometer, looks like some older type
    I am enclosing two documents that I have not seen before on our forum, regarding the operation and connection of modular clocks.
    10.b) Can any clock be used to diagnose and unlock the controller? Or maybe it has to be dedicated to wet heating if we want to operate the D3WZ?
    10.c) Will only the clock with the Eberspacher logo work? Can the Webasto clock also diagnose / unlock the driver? They look the same, they even have the same connection on the back and differ only in the logo on the front panel ...
    I hope that my topic will start a series of tips and tricks on how to diagnose and repair additional heaters drivers.
    Greetings!
    • manual_module_timer_en.pdf (614.86 KB) You must be logged in to download this attachment.
    • 7daytime.pdf (163.31 KB) You must be logged in to download this attachment.
  • #2 17581336
    GrzegorzWo
    Rate: 9
    As winter is back, I decided to update the thread with my summer stove experience.
    In short - we managed to fire it. Unfortunately, I was not able to connect to it and diagnose Techem 2 (- finally I did not go to Techa because the stove worked). Anyway, most likely everything worked fine for me immediately after replacing the candle ... Although I dismantled the entire driver, gouged it out, corrected all February etc. according to the instructions, but I think that it did not help in my case.
    The most important tip for me was not to connect the signals from the alternator and the air conditioning at the same time during the tests. In general, these signals were shorted during all tests - and then the stove did not start. This made me think that it was blocked / malfunctioning / broken, etc. I did not find any information about it anywhere in any guide - perhaps in the older model versions such a short circuit was acceptable, while in my version (serial number 25 2008) the stove was He just didn't take off.
    As it turned out - when first (except of course the power supply) I gave the signal from the alternator to the stove, waited a few seconds and only then gave the signal from the air conditioning - the stove started correctly and everything worked as it should. This was the key to my problem. Unfortunately, I had to do it myself, completely by accident.
    Probably it has always been like this, only I always did my tests when both signals were shorted - if I gave + 12V to the signal from the alternator, the signal from the air conditioning was also sent automatically. In the case of my car - Opel Omega B, year 2000, these signals had to be separated and the signal from the air-conditioning should be given only after some time.
    I also came to the conclusion that my D3WZ is not blocking, and even if it blocked, it was actually enough to disconnect the stove (or battery) completely, wait an hour and try again. no clock, no interface, no program etc.
    I do not know if I helped someone - but I admit - in my case it was a trifle that nobody wrote anywhere (or I did not find it :P ).
    So during the tests - first the signal from the alternator, and only after a while (a few - several seconds) the signal from the air conditioning.
    Greetings!
    PS: As I wrote, I did not diagnose the furnace, but I was able to connect to it using the usual K interface and the AB-Com or Tech program. The programs connect to the furnace, but when I try to read errors, they either hang (AB-Com), or they return the string "NO WAY" (Tech).
    Anyway, answering my question number 6: In order to connect to the stove with the K line, it is necessary to start it, i.e. to provide the alternator signal, apart from the power supply, and after a while the signal from the air conditioning - then the stove starts and you can connect to it.
  • #3 17632813
    Didi1102
    Rate: 18
    Could you draw a cube and show what and where and how much to give it to start it, I am collecting information temporarily and waiting for a pump. From what I read, it is only + 12v GDN signal from the key and temperature sensor and alternator excitation ...
  • Omega auxiliary heater needs +12V on pin G below 4°C
    #4 17659785
    GrzegorzWo
    Rate: 9
    What signals and where they go to the auxiliary heater depend on the specific model and car model. It is similar with the plug and its pin layout.
    In my Omega from 2000 (additional heater in version D3WZ 25 2008) it is exactly like in the attached PDF. In my case, all the following conditions must be met to start the stove:
    - Power supply to +12 V and GND (pins A and B from the diagram)
    - Connecting a working fuel pump (pins D and E in the diagram) - in some versions only one wire from the stove goes to the pump, while the other pump pin is connected to the vehicle's ground
    - Connecting the alternator excitation (+ 12V to pin K from the diagram)
    - Connecting the signal from the air conditioning (+ 12V to pin G from the diagram)
    In my case, the last signal comes directly from the air conditioning panel (in the end, it is the air conditioning that decides whether to turn on the stove or not). The climatron will not give this signal if it is turned OFF or the outside temperature is above 4 degrees Celsius. To get around this limitation and start the stove for tests at a higher temperature, I disconnected the plug from the air conditioning panel and made a short circuit on it between pins 3 (power) and 19 (signal to the stove).
    From what I read, an alternative solution used in Omega was a simple thermal switch, located near the pollen filter (I guess it was used in models without climatronics, but that's just my guess). This switch tripped at temperatures below 4 degrees.
    Whichever solution was used in the car, it ultimately resulted in the appearance of + 12V on pin G when the temperature dropped below 4 degrees.
    One more thing - if you have an unfastened (inoperative) pump, I would not expect the stove to respond.
    • omega-standheizung-d3wz-25-2008.pdf (472.62 KB) You must be logged in to download this attachment.
