[Solved] Audi a6 c5 - Battery of the remote control discharged, how to code with one key
kilun1 5976 4
  • #1 16888403
    kilun1
    Help: 5
    Rate: 64
    I can't close the car with the remote control and I'm afraid to start it, because I only have one. I read on the forums that you need two keys. Will the immobilizer decode when I remove the batteries? I won't start the car anymore?
    bodzio012
    Help: 161
    Rate: 780
    Immo is a completely different story, fire up.
    zibi999
    Help: 10
    Rate: 60
    Imo is not a problem, my ignition is rubbed off the key when I tried to turn the key a piece broke with great difficulty I pulled out ;) ,
    I broke the steering lock and even fired with the same key with the same key, I managed to know then I had to add a key but I managed ;)
  • #4 16897095
    kilun1
    Help: 5
    Rate: 64
    And if I buy another key, it is about electronics, you know, the tip will have to make some extra, can you code it somehow? This immo is some tablet after night? In bmw e36 you could code yourself from what I remember. And how does it look in audi?
  • #5 17068735
    kilun1
    Help: 5
    Rate: 64
    Comfort module replacement
